Wheel Covers (hub caps) for 16 inch Steel Wheels
I think a tin a silver wheel paint would be cheaper! :giggle:
I'll get my coat.
  • Replies 66
  • Views 23.9k
  • I've left the plastic nut covers from my alloys on, then fitted the centre covers over them. They then fit perfectly!
Well, well. VW liked my black on black wheels so much they've just launched this new T5 sporting the same. emoticon-0136-giggle.gif The Rockton. WOW! It even has a Yeti Rough Road pack!
Looks like it is a 4x4 as well. Those tyres look pretty aggressive.
Mike
I can't wait to see them! Did the glue you suggested stick them well and truly? Did you have to bend the badge to take the shape of the cone?
Oh, alright then, a sneak preview before they are fitted to the SM. Here you are:
I just covered the hub cap and the back of the badge with Evo-Stick Instant, left for 5-6 minutes, then applied the badge to the hubcap, left it for a little while then went round the edges to make sure they were stuck down.
It is a bit lumpy because of the raised VW underneath. I was going to use a dremel to smooth it down, but realised the the underside goes up, so there would be nothing left to fit the badges to, so I'll have to live with the 'bumps'.
I used 75mm dia badges Fred.
Mike
Mike
ohhhh... I'm jealous! Looks very smart! I will have to buy some Evo-Stick and start doing the same on my side. Though might need to "flatten" the VW badge first if I was to use my with-nuts hub caps instead of the circle-VOLKSWAGEN ones (which are much smoother)...
Thanks for that Mike.
They will look even smarter when they are fitted to my white SMemoticon-0140-rofl.gif
Mike
Mike
Here they are:
Mike
Looks great Mike! Those huge wheels certainly fill the arches. 215 and 60 profile too. Are they bigger in circumference than the original's?
I've not had time to put them beside each other, as I ran out of time after the handover, so just dumped all the wheels in the house and left for my 1st client.
When I have a bit more time I'll do a comparison photo.
Mike
I just got a set of old transporter hubcaps. Pcd is right but anyone know how you secure these to the wheel? They seem a little loose to me. There is no snap as they go on.
Sorry but as per quite a few threads now the VW T5 has a PCD of 5x120 and not 5x112. They sort of clip over but WILL fall off over the first speed bump.
ONLY VW Caddy van centre caps will work. Just do a search on here to find the part numbers.
Having today fitted my steel wheels and winter tyres, I think the bare steel wheels look as if they are there for a reason and most people will be correct that they are there for the winter. My wheels happen to be silver rather than black but I would have been happy to leave either colour exposed. Quite often trims look the plastic things that they are!
Hi, Interested in your SILVER coloured steel rims for the Yeti. Assumed they were only available in BLACK. Have you any pic's? Would you please give details of supplier/price/spec/ etc. Like you I am in the North East so am hoping you sourced them locally. Thanks
Some of the T5 centre caps fit better than others. I lost one in bad weather and the other one on Salisbury Plains. So only 2 left on the offside.....and 1 spareemoticon-0106-crying.gif. Need another one, or take all off.emoticon-0149-no.gif
And I've got three redundant T5 centre caps sitting in my garage if anyone wants any! But, as Johann says, they do not fit properly unless you silicone them on as they have the wrong PCD. Only Caddy ones fit securely!
See this thread: http://briskoda.net/forums/topic/217147-black-winter-wheels-finally-going-silver/ for how I painted my black ones silver. VW sell silver ones. See the VWCaddy club link in the first post of this thread: http://briskoda.net/forums/topic/217746-vag-group-steel-and-alloy-wheel-part-numbers-and-specs/
Sorry, should have clarified but was posting from a mobile. I'm aware that T5 ones have a PCD of 120, but these don't as they are old T4 transporter/caravelle ones. I measured and check out this site for PCDs of wheels on various cars etc:
http://www.carlsalter.com/volkswagen-wheel-fitments.html
The T4 has a PCD of 112.
So my question is, how do they fit on? There's a small diagram on the inside of the hubcap that doesn't mean much to me. I've got "normal" nuts on the car as far as I'm aware so how to they attach? Here are some pics if it helps?
http://www.flickr.com/photos/16677168@N02/6701140411/
http://www.flickr.com/photos/16677168@N02/6701140799/
The five caps seem to have a lip on them to "clip" onto something. Perhaps a certain type of nut?
http://www.flickr.com/photos/16677168@N02/6701140603
Cheers!
|Just fiited my winter shoes, uk bounbd next week, and have used 4 x caddy centres - fit well, need to think about using filler to level the surface then fit some skoda overlays - the caps fit with a definite click!
Cheers!
Yes the T4 ones do fit. But I'm perplexed by how they fit too! The Caddy ones have nibs like yours one all sides of the nut with the ends having a definite 90 degree raised bit tapering to the ends. Thus when you put them on the ends bend out until that 90 degree bit clips back behind the nut to secure the trim.
Hmm so my old octavia steelies would fit my t4? Might Get some winters on the van too rather than parking it up all winter
Sent from my motorola xoom using tapatalk
Looking at it, I wonder if because the T4 trims are flat and the steel wheels are quite "sunken" where the nuts go, whether the hubcap is sitting too far on top of the wheel to be able to click onto the nuts then. Might need to shave a bit off the side perhaps so the cap sits "deeper" into the wheel...
Pa. What a palava!
There's a small diagram on the inside of the hubcap (...)
I'd say the diagram shows air valve and specifies hubcap's intended position in relation to valve. Someone has already posted something about the VAG one and only correct position of hubcaps. Don't remember who it was and when however :giggle:
T'was me! The diagram on the back of the T5 caps show where to position the cap in relation to the valve so that when the valve is at it's lowest point (adjacent to the ground), the VW logo is the right way up! Such attention to detail is amazing. :giggle:
When my friend worked at the Rolls, Bentley, Ferrari dealer in Knutsford they used to jack up each wheel of the cars in the showroom to turn them so that the centre logos were always "correct".
