CD magazine won't eject, HU says "mechanic"
Hi All,
as title, CD was playing fine, then it stops & "mechanic" pops up on the display.
I open the boot to eject the magazine, but it won't eject (you can hear it trying though)
thanks
ps.standard Skoda stereo with 6 disc changer
Edited by Jonathan_1.8T
Try Disconnecting the changer lead from the changer and leave it 10 mins then try again hopefully it will work. Once the cd cassette is out check for dirt/dust in the changer :thumbup:
When you're in there, check for water in the well under the stacker. The rear washer pipe is rooted through there, and there's a joint which may have come un-moored.
There might a small hole near the eject buttun where you can insert a paperclip - this should eject the cartridge.
nice one, I'll try that, thanks.
I see 2 screws on each side...I take it I need to remove them with a stubby to get at the plug in at the bottom.....which I'm assuming is screw fixed to the changer?
Or is it not screw fixed & will it prise off without removing the changer? (can't see under changer, there is only a 1 inch gap between the bottom where the cable connects, & the boot floor/carpet)
thanks
thanks
as an update to this, nothing worked, so I decided no option but to remove it & take it apart, which to be honest was fairly easy,.
The hardest bit was finding the right tools, most specifically my t25 torx bit & small ratchet to get the 4 cage screws out.
Once the changer was out, I took the front off, then the top (need small Philips head screwdrivers to remove side screws), only to find with those bits off, the magazine part is still inaccessible & I still could not get the mag out.
So I plugged it back in several times to try it to no avail (it made noises but no ejection & no CD playing)
Eventually, while it was making noises (after pressing the eject button yet again) I twiddled a white cog on the opposite end of the unit to the magazine, & hey presto, the magazine came out.
I then took it back indoors, vacuumed inside it, & cleaned (with a cotton bud & meths) the CD grabbing arms.
Then reassembled/ refitted & it's all good again (so far)
Edit;
This link was usefull, ta to OP
http://briskoda.net/forums/topic/163781-how-to-fix-the-cd-changer-mechanic-error/
