LED Daylight Running Lights kit for Octavia
Hi
LED daylight running lights kit?
Advice please.
Yes, I have read the threads which touch on this subject, but have not come to any definite conclusion, so I need a simple answer from those of you in the know about these things
I wish to know if there is a kit out there that can be fitted to an Octavia Estae (mine is a 4x4 1.9 MkII Estate, 2007) which could be fitted by any reasonably competent garage and will be legal and will not cause any other electrical problems.
Many thanks
:wonder:
If you want to be seen and to avoid looking like a 'wannabe' just use dipped headlights until you replace your Octavia with a newer model that has them already :thumbup:
to be fair, it would be a bit more expensive to replace the whole car for just some lights!
Definitely, that's why I'd avoid the hassle and the "crashed through Halfords window" approach and just flick on my dipped headlights.
Has anyone retrofitted the FL running LED lights to a Mk2 car?? Can it be done? You should be able to buy the bits direct from Skoda.
Not sure they'll fit?
Best option would be to retrofit the entire FL bumper if possible?
Another problem will be getting them to work properly. The FL LED DRL's double up as sidelights and dim when in sidelight mode or when dipped headlights are on.
Also you'll need to wire them to come on with the ignition and dim when the lights are turned on.
A challenge but an impressive retro fit if possible :thumbup:
I reckon fitting the FL bumper would be the way to do it, if you were that way inclined!
:thumbup: Carl.
When I did some a while ago on my vRS I used CCFLs (Cold Cathode Fluorescent Light) but they proved to be unreliable. I'm fitting some LED units soon though.
The big problem I found was locating an ignition switched feed in the engine bay. I wanted the lights on all the time (not just with the side lights). After hours of poking around in the fuse and relay box with a multimeter and test lamps the canbus logic got the better of me. What appeared to be switched feeds suddenly became permanent when a load was applied and vica-versa..... :doh:
In the end I ran a feed from the dash fusebox through the engine bay to provide the switched feed.
Just wondering if anyone else has found one in the engine bay??
:thumbup: Carl.
Yes
I remember your post aswell.
I had the same problem as you. In the end i wired them into the Headlight connector block. (i think it was the black wire in posn 3 but if you have a multimeter that will tell you better) The posn i wired it into is a switched live with the ignition. So as soon as you turn the key they come on.
That kit i linked also provides wiring and instructions so you can have it that they come on with the igniton, On with the sidelights and dim with the headlights. I did a tutorial on here on the installation. Have a search in the Octavia 2 Section. It was titled something like Blue Bullet DRL version 2 ( i tried a different set of LED first and they looked carp so changed to these)
If you get stuck mate just pm me and i'll help wherever i can
Oh bugger, I've only gone an bought exactly the same LEDs you rejected, but only paid £20ish quid but still..... :dull:
Lovely write-ups, but I did notice that you haven't given us a clue to where the High Pressure AC connection is in the fuse box..... ;)
I'll press on with the 8 LED versions I've got and see if I'm happy with them (although knowing that the 5s are even better will gnaw away at my brain)
The High Pressure AC Connection is not in the fuse box :p
Get the LED i linked above. Then use the others you have in the boot or as footwell lights :thumbup:
IIRC terminal 2 on the alternator goes low when the alternator (i.e. engine) is running. You could wire you lights to the battery via a fuse and then switch the low side?
  • 8 months later...
