A Guide to Yeti DNA, MY10 & 11
My take a while to put together fully but I will endeavour through part numbers to trace the origins of the major components that make up the Yeti.
Body
Upper body panels
All = 5L Yeti (obvious really)
Engine bay structure and plenum chamber
All = mix of 5L Yeti & 1K Golf V
e.g. suspension strut dome Golf, side member Yeti
Floor pan
All = 1K Golf V (front seat supports; 5L Yeti)
Rear seat base, boot floor and rear wheel wells
All = 5L Yeti (odd bracket; 1K Golf V)
Door hinges
Front upper
All = 8K Audi A5
Front lower
All = 7N Alhambra
Rear (upper & lower)
All = 8K Audi A5
Seats
Front seat base; manual & electric (+ rails)
All = 8R Audi Q5
Note: other lower sear components including draw primarily; 5N Tiguan
Front seat backrest frame
All without lumber support = 5L Yeti
With Lumber support = 3T Superb II or 5N Tiguan
Note: lumber support mechanism 5N Tiguan
Rear seats
No parts brake down of outer seats; listed as full assembly 5L Yeti
Centre rear seat backrest frame
All = 1K Golf V
Steering
Steering wheel and multi function controls (if fitted)
All = 3T Superb Mk2 (some 3 spoke wheels could be 5L Yeti)
Steering gear, column and tie rods
All = 1K Golf V
Front Axle
Assembly carrier
All = 1K Golf V
Note;
Cast alloy carrier 5 piece (production start to 01/08/10)
Pressed steel single piece (02/08/10 to date)
Wish bones
All = 1K Golf V
Note;
Rear wish bone bearing console design (production start to 01/08/10)
Additional note; Although the new pressed steel carrier and wish bones have a Golf V component part number, the Yeti and Superb were the first vehicles to be fitted with these components (in Europe anyway). At the end of October 2010 the VW Caddy also started to use this new arrangement.
Anti roll bar
4x4 = 3T Superb Mk2
2wd = 1K Golf V
Wheel bearing housing
All = 1K Golf V
Wheel bearing
All = 1T Touran (possible in some specifications 1K Golf V)
Shock absorber
All = 3C Passat or 1K Golf V (various ratings depending on specification)
Coil spring
All = 1K Golf V (various ratings depending on specification)
Drive shafts
All = 1K Golf V
Rear Axle
Support frame
4x4 = 5N Tiguan
2wd = 5N Tiguan (production start to 31/05/10)
2wd = 1K Golf V (31/05/10 to date)
Note: Tiguan frame uses a 'floating' system of mounting to chassis via rubber vibration mounts. Golf frame mounted directly to chassis.
All = 3C Passat
Wish bones upper, lower, axle guide, track rod and anti roll bar
All = 1K Golf V
Wheel bearings
4x4 = 8J Audi TT Mk2
2wd = 1T Touran
Shock absorber & coil spring
Rear drive shafts
4x4 = 3C Passat
Cardan shaft
4x4 = 1K Golf V
Wheel rims
All 17" alloy = 5L Yeti
All 16" alloy = 3T Superb II
7Jx16 steel = 3C Passat
6Jx16 steel (spare) = 8P Audi A3 Mk2 (probably why it's so expensive)
Brake system
Master cylinder
All = 1K Golf V
Servo
LHD = 1K Golf V
RHD = 3C Passat
ABS + ESP
All = 1K Golf V
Note:
ABS+ESP system updates 02/11/09, 31/05/10, 13/09/10 & 08/11/10
ABS updates 02/11/09 (for system without TPM)
Brake pipes and hoses
All = 1K Golf V
Note: rear brake hoses from production start to 01/11/09 = 1Q Eos
Electric vacuum pump (automatic models)
All = 1J Golf IV
Vacuum pipes
All = 1K Golf V
Brake discs, front & rear
All = 1K Golf V
Front cover plate
All = 1K Golf V
Front brake carrier housing
All = 1K Golf V
Front calliper carrier
280mm discs = none fitted
288mm discs = 1K Golf V
312mm discs = 1K Golf V (production start to 24/05/09)
312mm discs = 5N Tiguan (25/05/09 to date)
Front brake pads
280mm discs = 1K Golf V
288mm discs = 5K Golf VI
312mm discs = 3C Passat
Rear cover plate
253mm discs = 1Q Eos
272mm discs (2wd) = 1Q Eos
272mm discs (4x4) = 1T Touran (4x4; 02/11/09 to date)
282mm discs = 5N Tiguan (4x4; production start to 01/11/09)
Rear brake carrier housing
253mm discs = 1K Golf V
272mm discs = 5K Golf VI (4x4; 02/11/09 to date)
282mm discs = 1K Golf V (4x4; production start to 01/11/09)
Note: have come across a TDI 170 built late November 09 with the Golf V rear brake arrangement.
Rear calliper carrier
Rear brake pads
Hand brake lever
All = 1Z Octavia II
Brake pedal, accelerator pedal and clutch pedal
All = 1K Golf V
TP
Wow. Audi TT! I can see this becoming a great thread.
Thanks Plumber,
Excellent article, Even though I am still well in warranty it is great to see where it all comes from and I will print a copy for future reference.
Now I know why it drives like a sports car with a lid.
Regards,
iamgeob.
Steering
All = 1K Golf V
Front Axle
Assembly carrier
All = 1K Golf V
Note;
Wish bones
All = 1K Golf V
Note;
Additional note; Although the new pressed steel carrier and wish bones are listed as a Golf V component the Yeti and Superb were the first vehicles to be fitted with these components. At the end of October 2010 the VW Caddy also started to use this new arrangement.
Anti roll bar
4x4 = 3T Superb Mk2
2wd = 1K Golf V
All = 1K Golf V
Wheel bearing
Shock absorber
3C Passat and 1K Golf V (various ratings depending on specification)
Coil spring
Drive shafts
All = 1K Golf V
Rear Axle
Support frame
4x4 = 5N Tiguan
All = 3C Passat
All = 1K Golf V
Wheel bearings
2wd = 1T Touran
Rear drive shafts
4x4 = 3C Passat
Cardan shaft
4x4 = 1K Golf V
Wheel rims
All 16" alloy = 3T Superb Mk2
Brake system
Master cylinder
All = 1K Golf V
Servo
LHD = 1K Golf V
RHD = 3C Passat
ABS + ESP
All = 1K Golf V
Note:
All = 1K Golf V
All = 1J Golf IV
Vacuum pipes
All = 1K Golf V
TP
  • 5 weeks later...
Great work Tim.
Thanks.
Mike
