Proper Coding For The Rns 510 And Bt 5N0 035 730 D Without Phone Cradle
Hi, I have just replaced on my Superb II, 2010, the old Bluetooth 5N0 035 730 B module with 5N0 035 730 D. I changed because the latter supports both rSAP and iPhone. Following replacement, everything works very well but I have one problem. The guy, who made replacement, could not set proper coding with VAG COM. Apparently, he had to code manually and he set the coding for the system that has a telephone cradle. In fact my car does not have the phone cradle. Since system cannot find the cradle it gives a fault. I have RNS 510, white Maxidot, MDI, aux, TV tuner.
Can anyone post the proper VAG COM coding for RNS 510 with BT without phone cradle?
You will need to recode your phone module adr 77 using VCDS. VCDS is selfexplaing on that point. If you cant set the proper coding it is probably because your VCDS is running in stealth mode.
The coding I have in my Superb II (2008MY) is as follows:
Columbus:
Address 37: Navigation (J0506) Labels: 1T0-035-680.lbl
Part No SW: 3T0 035 680 HW: 3T0 035 680
Component: RNS-MID H03 0904
Revision: AB001001 Serial number: SKZxxxxxxxxxx
Coding: 040600000000008300
Bluetooth module:
Address 77: Telephone
Control Module Part Number: 3C8 035 730
Component and/or Version: Telefon 2800
Coding: 0020121
This came from a log a friend took of my car about 6 months ago. I've since upgraded the Columbus firmware to 2764, but the coding hasn't changed. Like you, I'm about to upgrade to the newer bluetooth module, and my understanding is that no recoding is required. You simply plug it in, and it should work.
Hope this helps,
Andy.
Hi,
For what its worth, here is what I get when I scan using the vcds cable. I cannot get the climate control or reverse sensors to show (the * special functions listed on page 8 of the Columbus manual) and am having issues with the maxidot as well. Am at a loss now. (car is a pre-fl Octavia RS)
Address 37: Navigation (J0506) Labels: 1T0-035-680.clb
Part No SW: 3T0 035 680 A HW: 1Z0 035 680 A
Component: RNS-MID H05 2764
Revision: AB001001 Serial number: ZZZZZZZZZZZZZZ
Coding: 0C0004000001000200
Shop #: WSC 00865 211 90681
ASAM Dataset: ------------------------- ------
VCID: 2E59F9F6C091
Address 56: Radio (J0506) Labels: 1T0-035-680.clb
VCID: 2E59F9F6C091
Tom
Edited by Tom707
Columbus:
Bluetooth module:
Coding: 0020121
Hope this helps,
Andy.
Thanks a lot, tomorrow I will see if it works. Re: to upgrade to the newer bluetooth module. I had to change wiring to from BT to RNS, as it was explained, in order to have stereo audio streaming.
Cheers,
Edited by toplogin
Hi, I tried to recode the BT module. It did not help. The module was not coded at all. I need LONG CODING for the module 5N0 035 730 D (address 77). My car is SKODA Superb II LA 118KW CDAA.
Edited by toplogin
Cheers,
Hi toplogin,
Could you give me a pointer to the extra wiring that's needed to get bluetooth stereo. This is the only remaining issue that I have with my unit.
Thanks,
Andy.
Hi toplogin,
Thanks,
Andy.
Okay. Found it now:
4 Audio RF Signal Out + connected to be connected to pin 11 con 3
5 Audio RF Signal Out – connected to be connected to pin 5 con 3
Topline this should help I'm not sure of your specific vehicle but if you don't have these options in VCDS then you have an old version and need to update to the latest.
Byte 0 Language:
00?
01 German
02 English
03 French
04 Italians
05 Spanish
06 Portuguese
08 Czech
07-09-FF not allowed
Byte 1. Voice Command:
00 activated
01 disabled
Byte 2.Type Microphone:
00 Parameter 1 / microphone VW
01 parameters 2 / microphone VW
10 parameters 1 / microphone Audi
02-03, 11-13 parameter set 3-4 / VW and Audi
Byte 3. Diagnosis antenna:
00 active
01 inactive
Byte 4. Diagnosis fixing Laptop (Überwachung Baseplate):
00 active
01 inactive
Byte 5. Mute (cooperating):
00 active
01 inactive
Byte 6. Control unit for the mobile phone preparation (module three keys):
00 Module 3-button activates / SMS possible
01 Module 3-button inactive / SMS possible
10 3-button activates / SMS is not possible
March 11-button inactive / SMS is not possible
Byte 7. Multimedia function:
00 BT Audio Active / Active Multimedia Context
01 BT inactive Audio / Multimedia Assets Background
10 BT Audio disabled Active / Inactive Multimedia Context
11 BT inactive Audio / Multimedia Background Off
Byte 8. Type of registration of mobile phone:
00 Supporting THB
01 VDA Support
10 Support Paragon
Byte 9. Function call for help:
00 people with disabilities
01 activated
Byte 10. Fuel Type:
00 Unknown
01 Gasoline
04 Diesel
05 LPG
06 natural gas
08 Electricity
10 hydrogen
Byte 11. Vehicle type:
00 M1
01-05 M2 and N1-3-3
  • 2 months later...
toplogin: Did you get proper longcode combination for your setup ? I got the same one , and just cant properly configure phone module to get it working with VAGCOM
Try this. 020000000100010000000000
Tried 020000010100010000000400 and 020000000100010000000000 with VagCom 10.64 , but can not see any bluetooth sid/network in range on all my phones at home.
I have a feeling that the unit is just DOA , or I need to enable bluetooth via adaptation channel 133 like old modules (but I can not due to absence access to the channels for this module on 10.64 or even 9.08) , or I just start thinking that maybe the unit is not working because I do not have maxidot , just standard white display.
My config is:
1.9 FL octavia , 2009 , Ambiente
RNS510
and of course 5N0035730D
Do anyone have 5N0 035 730 D working with standard white display on FL octavia ?
The unit itself respond:
Saturday,14,May,2011,17:35:41:64979
VCDS Version: Release 10.6.4
Control Module Part Number: 5N0 035 730 D
Component and/or Version: Telefon 009 0511
Software Coding: 000100010100010000000400
Work Shop Code: WSC 73430
VCID: 295205AAF969
Advanced Identification/FAZIT
Serial number: 35909603117854
Identification: NGD-B01
Revision: --------
Date: 21.02.11
Manufacturer number: 0021
Test stand number: 7854
Flash Status
Programming Attempts(application): 0/0/0
Successful Attempts(application): 0/0/0
Programming Status: 00000000
Software
Theft prot.: 00.01.00
BAP: 04.01.02
UDS: 00.00.00
Diag: 00.01.00
CAN: 02.04.00
ISO15765: 00.00.00
OSEK-OS: 02.02.01
OSEK Net: 00.00.00
OSEK-Com: 00.00.00
Misc.
Hardware number: 5N0 035 730 D
Workshop System Name: J412
ASAM Dataset: EV_UHVPremi
ASAM Dataset Revision: A01005
Car Info
Chassis Number: -----------------
VCDS Info:
Labels: 3C8-035-730-A.clb
ROD: EV_UHVPremi_VW36.rod
Looks like for retrofiting ANY of the VW bluetooth modules MaxiDot is prerequirement.... ;-(
Edited by Shahoff
  • 8 months later...
Does anyone know how to re-activate voice control for the Bluetooth module?
I replaced my bluetooth module with one that will work with my iPhone and all seemed to work ok, other than when I did an autos can with VCDS I got 4 error codes. I have recoded using the information above and all codes gone now but I have no voice control anymore!
Thanks,
Mark
