Does Octavia II TSI engine have an oil quality sensor , interpreting message in VCDS log
I own a 1 year old Octavia II 1.8l TSI . I got this service a month back. I now see a flashing Service message when I start the car. I assumed the dealer had not reset the Service Interval but when I did a scan with a recently purchased Ross-Tech HEX-CAN interface cable and VCDS, I see a message "poor quality " in the measurement log against oil quality.
I want to know from the experts in this forum :
1. Does the TSI indeed have an oil quality sensor that can detect saturation of suspended particles ?
2. If so could the service indication a result of this even though the dealer may have reset the service interval indicator after the first service? To the suspicious eye the oil seemed a little dark.
or
3. Is it possible the dealer did not reset the service interval indicator (shown by the interval from last inspection showing 412 days) and the poor quality message is a result of the system concluding the quality must be poor because the max interval has been exceeded. I cant recollect when I first the saw the flashing service indicator - it may have been around the completion of 1 year.
Would appreciate your help in interpreting the log to confirm one or the other.
See the log below - the poor quality message is in bold
Friday,11,February,2011,17:43:22:09132
VCDS Version: Release 10.6.3
Data version: 20101206
17:43:00
104.1 ° Fuel gauge needle position 017
17000 km ESI: Max lower limit of maintenance intervals distance 038
372 Days ESI: Max lower limit of maint intervals time interval 039-1
372 Days ESI: Min. oil level in service interval 039-2
372 Days ESI: Max. oil level in service interval 039-3
N/A ESI: Upr-limit of serv. int. driv. dist. 040
N/A ESI: Upr-limit of serv. int. time int. 041
N/A ESI: Lwr-limit of serv. int. driv. dist. 042
N/A ESI: Lwr-limit of serv. int. time int. 043
7400 km ESI: Distance driven since inspection 044
416 Days ESI: Time since inspection 045
0 km ESI: Soot entry 046
Friday,11,February,2011,17:46:39:09132
17:46:20
1080 ml ESI: Max. oil level in service interval 039-3
13900 km ESI: Thermal load 047
poor oil quality ESI: Oil quality 048
dyn. oil press. warn. ON; oil press. < syst.-spec. sw. thresh. Oil pressure switch 049
OK Oil fill level 050
Unknown Communication status of data bus 1 051
Unknown Communication status of data bus 1 052
0 ESI: Cum. total of fuel level values 126
N/A Analysis 2 127
N/A Analysis 3 128
Friday,11,February,2011,17:49:59:09132
17:49:40
0.0 km/h Speed Sensor Front Left (G47)
0.0 km/h Speed Sensor Front Right (G45)
0.0 km/h Speed Sensor Rear Left (G46)
0.0 km/h Speed Sensor Rear Right (G44)
Activated Parking Brake
Not Oper. Brake Light Switch (F)
OFF Brake System Warning L. (K118)
OFF ABS Warning L. (K47)
OFF ASR/ESP Warning L. (K155)
Not Oper. ASR/ESP Button (E256)
Friday,11,February,2011,17:55:52:09132
17:55:26
760 /min Engine Speed (G28)
89.0°C Coolant Temperature (G62)
0.0 % Lambda Control Bank 1
10110111 Basic Setting Requirements
15.8 % Engine Load
1.02 ms Injection Timing
2.42 g/s Mass Air Flow Sensor (G70)
2.4 % Throttle Valve Angle
0.0 °BTDC Ignition Timing Angle
Friday,11,February,2011,17:57:07:09132
17:56:50
720 /min Engine Speed (G28)
13.536 V Battery Voltage (Terminal 30)
94.0°C Coolant Temperature (G62)
58.0°C Intake Air Temperature (G42)
15.8 % Engine Load
0.0 km/h Vehicle Speed
Idle Load Status
15.8 % Engine Load
-0.8 % Altitude Correction Factor
17:58:21
15.8 % Engine Load
98.0°C Coolant Temperature (G62)
00000001 Operating Mode
66.5 mm Oil Level
51.5 mm Oil Warning Threshold
14176 Fuel Consumption Signal
14 Fuel Consumption Equivalent
15.0 % Engine Load
3.8 °BTDC Ignition Timing Angle
17:58:26
15.8 % Engine Load
66.5 mm Oil Level
52.0 mm Oil Warning Threshold
15258 Fuel Consumption Signal
15.8 % Engine Load
0.8 °BTDC Ignition Timing Angle
17:58:28
15.0 % Engine Load
66.5 mm Oil Level
15751 Fuel Consumption Signal
15.0 % Engine Load
1.5 °BTDC Ignition Timing Angle
17:59:32
15.0 % Engine Load
0 Misfire Counter
Enabled Misfire Recognition
0 Misfire Counter Cylinder 1
0 Misfire Counter Cylinder 2
0 Misfire Counter Cylinder 3
0 Misfire Counter Cylinder 4
It has an oil quality sensor fitted, for use with variable service intervals. As I understand it, this is able to measure the viscosity of the oil.
I suspect that the sensor has not been properly reset, or reset at all. As you say, if this hasn't been done and the car thinks a service is overdue. The sensor also needs to be reset so that it knows to expect oil of a different viscosity, as it's new.
I would advise taking it back to the garage you had the service done at. Was this a main Skoda dealer?
Hope this helps.
Steve
Hope this helps.
Steve
A simple SRI reset and writing "good quality" into the oil quality channel seems to have fixed this. My conclusion - the service reminder was not reset and the Computer concludes if the time since last inspection > the max interval and/or distance since last inspection > max interval distance, sets the oil quality to poor quality. I dont think it is a real sensor . It seems to be a computed ( derived) measurement.
