How to Reset the Engine ECU!
The main correct procedure is as follows!
Turn off all electrical items, stereo, heating to cold, fan speed to "0", etc.
Disconnect battery negative (earth) clamp for 40mins.
FROM THIS POINT ONWARDS DO NOT TOUCH ANY OF THE PEDALS!!!!
Reconnect battery.
Start engine and let idle for 30mins (during this time it will sound as if it will stall, and it will "hunt", this is normal!)
Switch of engine.
Job done!!! B)
This process wipes the learned values from the ECU and resets to factory defaults. Then it relearns the idle values, and "adjusts" the throttle valve, which it needs to do to operate properly!!! This is a usefull "trick" for most engines, but works very well on VAG cars....got it from the head mechanic at local dealership years ago! B)
Now you will have to reset the upper limits of the electric windows, and reset the central locking, reset the time on the clock, reset any HIFI settings, security codes etc.!!
To reset the electric windows insert the key into the drivers door lock, and turn the key so that the windows fully wind up and the motors stop, then hold the key in this turned position for a further 4 secs. Job done :thumbup:
Edited by fabdavrav
  • Replies 67
  • Views 119.4k
  • musicmaster5000
    musicmaster5000
    Okay, just done it and left the battery disconnected for about 40-45mins and it didn't work :S
  • was thinking of a pipercross induction kitt and heard best to reset the ecu after fitting so it can adjust is this true? i have it remapped will i lose the map
  • greenline 11
    greenline 11
    You say 'don't touch any of the pedals from this point on' my Fabia Greenline 11 won't start without depressing the clutch. Is there another way of starting the car?
This is a work in progress, but the main correct procedure is as follows!
Reconnect battery.
Switch of engine.
Job done!!! B)
Now you will have to reset the upper limits of the electric windows, and reset the central locking, reset the time on the clock, reset any HIFI settings, serurity codes etc.!!
Would this involve having the immobiliser reset or anything?
No need to reset as it can cope with this procedure...don't worry never had any problems with mine...unless you have an after-market one...when follow the manufacturers instructions. B)
Thinking of doing this later on today, I was just wondering what you mean by resetting the central locking?
It has to be resynced...details in the owners handbook B)
I don't have the owners hand book :/
Okay I do have, ignore that.
Edited by musicmaster5000
Found it down the back of the sofa????
I will eventually post up details when I next have my book to hand. B)
LOL! Nah I wasn't sure what books we had with it. It just says Press any button of the remote control and open the car door with key within 1 minute.
sounds about right from memory!
I'm not sure disconnecting the battery does run a throttle body adaptation. I'm guessing it can only be done with VAG-COM/VCDS. Also,I believe it relearns values best when you drive normally, as well as idling the car a short time.
To be 100% certain the learned values clear it's probably best to disconnect and leave it overnight.
The only way to fully erase learned values is adaptation channel 00 with diagnostics.
If doing a terminal 30 reset (disconnecting the battery) shorting the two terminal clamps together with the battery disconnected with discharge any capacitors and reset systems.
is this true?
is this true?
You shouldn't loose the map and it might make no differnce as you have a map!....no real harm in trying tho'! B)
  • 6 months later...
Not sure if I'm doing something wrong but I'm just sat following your guide now. Upon reconnecting the car has just sat at idle no change in revs at all, hasn't really come close to stalling either as you mentioned it might. It's just sat idling. Trying to get rid of the slight juddering it has at idle. So far it's still juddering!
All the OHV engines normally have a slight judder at idle, it's a feature not a fault.
Ross
Does this info apply for all models ??
So in VCDS engine controller> 00 run adaption = reset values ???
Thanks tech1e although mine is a 1.2 htp, is that still normal?
I'm inclined to think it hasn't reset to ecu despite leaving it disconnected for 45 mins. The key didn't need resyncing and the windows seemed to just go up and down with the key thing.
RE: post#1
Why aren't the pedals to be touched?
It's obviously very important but for the life of me I can't work
out why?
They all have an input into the ECU, the clutch switch, the brake light switch and the drive by wire throttle.
Ahh... Cheers, that makes sense :thumbup:
Ross
Normally yes and in most systems
No, but I was going by your profile.
Ha sorry haven't updated it yet! So it's not normal?! Fairly sure it didn't actually reset my ecu based on the fact that it didn't do any "hunting" or require me to resync my key etc. I assume the above instructions would be correct for all fabias?!
Ross
Hi, would this work with 2002 octavia 1.8t 4x4 with me7.x ecu?
Best wishes
John
