Mirror indicator not working
The left door indicator has stopped working and I can't see an obvious way to get to the bulb. Can somebody help?
You cannot get to the bulb, it's a sealed unit. You need to remove the mirror case and unplug the electrical connector, the indicator section is held on by two torx screws. A replacement indicator unit is about £20, I have just done the same job after somebody clipped the door mirror and smashed the indicator lens. Hope this helps.
  • 9 months later...
I have no entry or indicator lights on this mirror and no visible damage, I have stuffed a bag over it till I can test for power in the daylight!(cover removed)
