Help solving a door locking problem
Hi all,
On Friday I met up with Skinnyman and scanned his car with VCDS Lite in the hope that something would show up to help the faultfinding for his locking problem. The symptoms are that when he locks with the key, all doors lock as expected. If he locks with the remote, the drivers door does not lock.
I scanned controller 46 and got this:
Friday, 08 July 2011, 14:10:31.
VCDS-Lite Version: Release 1.1
Control Module Part Number: 1C0 959 799 B
Component and/or Version: 3Y Komfortgerát HLO 0004
Software Coding: 00259
Work Shop Code: WSC 73430
VCID: 361FA5DB0149
Additional Info: 1U6959802D 3Y Tõrsteuer.FS KLO 0004
Additional Info: 1U6959801D 3Y Tõrsteuer.BF KLO 0202
Additional Info: 1U0959811D 3Y Tõrsteuer.HL KLO 0202
Additional Info: 1U0959812D 3Y Tõrsteuer.HR KLO 0202
6 Faults Found:
01336 - Data Bus for Comfort System
80-10 - Single-Wire Operation - Intermittent
00932 - Shareware Version. To Decode all DTCs
62-10 - Please Register/Activate - Intermittent
00928 - Shareware Version. To Decode all DTCs
27-10 - Please Register/Activate - Intermittent
00943 - Heated Exterior Mirror; Driver Side (Z4)
35-00 - -
00929 - Shareware Version. To Decode all DTCs
00931 - Shareware Version. To Decode all DTCs
I also got this from Controller 19
Friday, 08 July 2011, 14:12:53.
Control Module Part Number: 6N0 909 901
Component and/or Version: Gateway K<->CAN 0001
Software Coding: 00006
VCID: F093D3C3A3AD
4 Faults Found:
49-10 - No Communications - Intermittent
01336 - Shareware Version. To Decode all DTCs
80-10 - Please Register/Activate - Intermittent
01304 - Shareware Version. To Decode all DTCs
49-00 - Please Register/Activate
01331 - Door Control Module; Driver Side (J386)
Now, I cleared all the faults and the only one to reappear was the one regarding the drivers mirror. But the locking still has the same problem. I suggested to Andrew that we do another scan in a week or so to see what else has come up. Andrew has done some disconnecting/reconnecting to do some fault finding so this might have caused the errors logged I suppose?
Can anyone assist with interpreting these error codes please?
Martin
Have you not looked on the Ross-Tech wiki?
This is the 1st place to start when you have the fault codes.
[/url]
01336 - Data Bus for Comfort System: Faulty
Possible Causes
Possible Solutions
  • Check CAN-Gateway Coding
  • Check Measuring Value Blocks (MVB)
  • Check Wiring/Connectors from/to Control Modules
01336 - Data Bus for Comfort System: Single-Wire Operation
Possible Symptoms
  • Data Bus Comfort working in Single-Wire Mode
Possible Causes
Possible Solutions
Special Notes
00928 - Locking Module for Central Locking; Front Driver Side (F220)
[/url]
00928 - Locking Module for Central Locking; Front Driver Side (F220): Implausible Signal
Possible Symptoms
Possible Causes
  • Wiring/Connectors from/to Locking Module for Central Locking; Front Driver Side (F220) faulty
  • Voltage Supply for Locking Module for Central Locking; Front Driver Side (F220) faulty
  • Door Lock Mechanics are stiff/partially seized
  • Locking Module for Central Locking; Front Driver Side (F220) faulty
Possible Solutions
00928 - Locking Module for Central Locking; Front Driver Side (F220): Incorrectly Equipped
Possible Symptoms
Possible Causes
  • Incorrect Door Lock installed
Possible Solutions
Special Notes
00943 - Heated Exterior Mirror Driver Side (Z4)
[/url]
Possible Symptoms
Possible Causes
  • Wiring/Connectors from/to Heated Exterior Mirror Driver Side (Z4) faulty
  • Heated Exterior Mirror Driver Side (Z4) faulty
Possible Solutions
Special Notes
  • Sometimes the switch button for the mirror has 'L', 'R' and '0'. When switched on '0' the mirror heating is on!
00943 - Heated Exterior Mirror Driver Side (Z4): Electrical Fault in Circuit
Possible Symptoms
Possible Causes
Possible Solutions
00929 - Locking Module for Central Locking; Front Passenger Side (F221)
[/url]
00929 - Locking Module for Central Locking; Front Passenger Side (F221): Implausible Signal
Possible Symptoms
Possible Causes
  • Wiring/Connectors from/to Locking Module for Central Locking; Front Passenger Side (F221) faulty
  • Voltage Supply for Locking Module for Central Locking; Front Passenger Side (F221) faulty
  • Locking Module for Central Locking; Front Passenger Side (F221) faulty
Possible Solutions
00929 - Locking Module for Central Locking; Front Passenger Side (F221): Incorrectly Equipped
Possible Symptoms
Possible Causes
Possible Solutions
Special Notes
00931 - Locking Module for Central Locking; Rear Right (F223)
[/url]
Possible Solutions
  • Check Door Contact Switch (F11)
  • Check Central Locking Module Rear Left (F223)
  • Check Central Locking Motor (V97) with Actuator (Lock) Rear Right (F134)
  • Check Central Locking Motor (V164) with Actuator (Safe) Rear Right (F246)
  • Check Child Safety Motor Rear Right (V143)
00931 - Locking Module for Central Locking; Rear Right (F223): Implausible Signal
Possible Symptoms
  • Door Locks not working properly
Possible Causes
Possible Solutions
  • Check Wiring/Connectors from/to Locking Module for Central Locking; Rear Right (F223)
  • Check Voltage Supply for Locking Module for Central Locking; Rear Right (F223)
  • Check Door Lock Mechanics/Operation
  • Check Locking Module for Central Locking; Rear Right (F223)
00931 - Locking Module for Central Locking; Rear Right (F223): Incorrectly Equipped
Possible Symptoms
Possible Causes
Possible Solutions
    • Check Door Lock Part Number
Special Notes
Sorry Gizmo, lazy git am I!! :doh:
@2SkodaFamily, we'd appreciate if you'd just link to the wiki pages instead of copying the content. ;) The idea of a wiki is that it's being updated constantly and therefor the contant will change sooner or later making the copy you made outdated and even misleading in cases. :)
oops. Sorry! :blush:
  • 6 months later...
Did you ever get to the bottom of this problem as I am having the same issues???
Remove the door panel on the drivers door and disconnect the Electric Window Motor/Door Control Module you will find some connectors corroded and pins broken on the motor, you can buy the repair connectors from your local dealer and a new motor
You will need special tools to remove the connectors like these:
http://www.lasertools.co.uk/item.aspx?item=3175
