Removing Swing Radio - MK2 Fabia vRS TSi **GUIDE**
Tools/Parts needed :
Torx screwdriver (T20 5x100)
Car used :
2011 MK2 Skoda Fabia vRS 1.4TSi
Time needed :
About 5 minutes, shouldn't be any longer
Difficulty :
2/5 - Not difficult just a little fiddly
This is what we are starting with :
To remove the surround just get your nails under it from the left hand side of the radio and lift. It should come off easily, there will be a few clips.
Next up you'll be able to see the 4 torx screws you need to remove :
You need to use a T20 torx screwdriver :
Once these are out you should see this :
You should now be able to wriggle the stereo from side to side while pulling out :
The main ISO block is on a swing hinge and comes off easy enough, the below comes off by just pushing up the plastic clip :
Now they have been removed you should have this :
And that, ladies and gentlemen, is that, you can now fit any radio you want!
**A Quick Note**
If you put the Swing radio back in you will be greeted with this :
It will then go to a code screen, do not worry, as soon as you turn the ignition on the car should recognise the unit and you won't have to put the code in :)
Nice guide :thumbup:
Will the Columbus sat nav plug directly into the original connectors
Thanks mate :thumbup:
Not too sure to be honest, I don't have one to try :(
  • 1 year later...
Just curious. Does the touchscreen radio from the Octavia Vrs fit straight in the hole and work? I use to have a MK3 VW Scirocco and I miss the light that came off the radio unit. And if it does fit with no hassle would the MDI and parking censer display work? Thanks
  • 7 months later...
Yes it will  but may need coding - and the trim will fit
Regards
Mike
Edited by killy
