Rear door lock not popping up and cannot open door
Hi, sorry if this is a rather blonde question but the back door is stuck shut on my Fabia (2003). When I operate the remote control all the locks pop up except this one. The garage said it is probably just something stuck or needs adjusting and said they could hopefully sort it in an hour (£64+vat) - does this sound correct or is it likely to be something more than this. Thank you very much.
Not a blonde question at all. It may be simple but there is a good chance that the deadlock is stuck in. If that's the case it's a 2.5 hr job plus a new door lock. It has to be chiselled off as the fitting bolts are totally inaccessible if you can't open the door. Be prepared for £200 plus.
Thank you very much for the info.
