Installing TMC Tuning Box - MK2 Fabia vRS TSi **GUIDE**
Tools/Parts needed :
Torx screwdriver (T30)
Large Flat head screwdriver
Small Flat head screwdriver
Pair of latex gloves
TMC Tuning Box Kit
Car used :
2011 MK2 Skoda Fabia vRS 1.4TSi
Time needed :
About 20 minutes but allow a bit more
Difficulty :
3/5 - A couple of plugs are fiddly
**MAKE SURE THE ENGINE IS COLD WHEN INSTALLING OTHERWISE YOU COULD END UP GETTING BURNT**
You'll have this to start with :
Engine bay should look like this :
First thing you will need to do is remove the engine cover, this is done by gently but firmly lifting the bottom left and right corner then then pulling the cover towards you :
The three plugs that need to change :
Turbo boost pressure sensor plug
Camshaft sensor plug
Manifold air pressure sensor plug
Let's start with the turbo boost pressure sensor plug, you will need to remove the turbo air intake pipe by removing the below Torx screws (some already removed but locations shown) :
On the top end once you remove the two torx screws you will have to lift off the plate helps hold the pipes together. Now you will need to wriggle the pipe while turning it towards the engine so it becomes loose like so :
Edited by VRS-Powered
Now that's out the way you can get to the turbo boost pressure sensor plug, you will need to take the large flat head screwdriver and use it to remove the clip. This should then allow the plug to push off :
Now connect the turbo boost pressure sensor plug on the TMC harness to where the OEM one was and connect the OEM plug to the other connector on the harness :
You then have to refit the turbo air intake pipe by using the steps above in reverse. You should be left with :
Now move onto the camshaft sensor plug, you will need to take your large flat head screwdriver and unclip it :
Now connect the plug on the TMC harness for the camshaft sensor to the OEM port and the OEM plug to the TMC harness.
Last plug now, the manifold air pressure sensor plug. Much like the camshaft sensor plug you will need to unclip it with the large flat head screwdriver :
Connect the plug on the TMC harness to the manifold air pressure sensor port and the OEM plug to the TMC harness.
You then need to connect up the tuning box itself, you do this by pushing in the plug into the box :
Then pushing down on the purple securing pin :
Should be left with this :
You can now tweek the setting to which one you would like to run, 0 being the lowest power to 9 being most power, you will need to use the small flat head screwdriver :
At this point turn on the car to make sure no faults come up, if they do it might be best to remove the tuning box and investigate further.
Time to tidy it up and secure the tuning box. I cable tied the cables (provided in the TMC kit) to the air intake pipe leading the airbox and cable tied the tuning box to the car :
(I will be securing this more at some point today)
Finally we have to put on the engine cover back on, push the bung at the top of the cover into the slot for it and then push down the bottom left and right corner :
Step back, pat yourself on the back and go and get yourself a nice cuppa............or take the car out to feel the extra ooommpphh!
great guide mate :)
great guide mate :)
Thanks mate :thumbup:
Can really feel the difference? And is it better than getting a remap?
Yes I can feel it pull a lot harder now, the engine feels like it has got a bit more urgency to it.
I can't comment on whether it is better than a remap, it hasn't been run down Pod' or on a RR yet (was supposed to be this month but not sure now) so haven't got figures to compare. Obviously the difference is the box is a generic design where as the map is custom.
All tidy and secure :
  • 1 year later...
Sorry to dig up an old thread.
Did you get this on a dyno?
What was the cost?
I found this one in Germany
https://www.tuningkit.de/index.php (need to change the lingo and find the correct box by choosing car model - direct link to the unit doesn't work for some reason :( )
Any thoughts?
I think it is Briskie sponsor as well.
Delivered at current exchange rates is £272 :)
sorry for n00b question. Does it connect to the fuel rail sensor? What is this thing altering a I assume it works on intercepting and conditioning the original ECU signals.
Edited by Jabozuma
For the TMC box it connects to :
Turbo Boost Pressure Sensor
Camshaft Sensor
Not sure what the Tuningkit.de unit connects to, might be worth emailing them to ask. Looks like it could be a good alternative and, like I did, it's worth trying something different.
Are you still running it mate or went re-map land?
Still running it buddy, with all the problems with the engine I didn't risk spending anymore on it.
It's a good solution to be honest and does give a massive improvement vs stock. You're around my way, if you ever fancy it I can always take you out in it.
We need to organise a little "drag race" or "follow each other" so I could see the difference between your car and mine vanilla stock one :). Then you will take me for a drive!
LOL no worries mate :)
  • 5 months later...
I heard that a tuning box can improve your mpg as less need for the engine to change down because of the more torque, have you noticed a better mpg and what do you get combined?
MPG is mostly dependant on your driving style. Tuning (be it box or re-map) can improve mpg by leaning out the mixture a bit on certain points in the AFR map. However, If you keep giving it a plenty it will burn much more fuel than stock - power desn't come from nowhere you see :).
Sorry what's AFR?
Sorry what's AFR?
Air Fuel Ratio - how much fuel injectors squirt in at particualr throttle opening position, engine rpm, temperature, knock sensor input etc, etc,
They also play with boost levels, ignition timing, accleration enrichment maps, knock sensor learning tables and other bits and bobs.
Its a great build thread and how to's.
It needs to be remembered that this car ended up requiring a new engine.
Not down to tuning box, but still engine was replaced.
http://www.briskoda....mc-itg-2116-bhp
  • 4 years later...
What's this 3rd party hosting? I want to see the posted photos otherwise ruins the point of the forum.
Remember - A picture is worth a thousand words.
Things change in 5 years,
members leave, take down pictures and then the likes of Photobucket hold people to ransom or try to....
Thanks George (hope calling you 'George' is okay).
It's a shame that newbies coming to the site, possibly, as in my case with an elderly car, cannot get the full benefits.
My interests obviously are with the 2011 Mk2 car - with posts between 2010 and the demise of the excellent Fabia VRS.
I understand that people move on - but their posts should remain in tact for all to enjoy in perpetuity.
Perhaps it would be better to get rid of incomplete posts as they serve as an unwelcome distraction and would avoid disappointment.
A terrible shame.
