Fault code help
Hi ive got a Oktavia mk 11 2.0tdi sport 06 my engine light came on and got my friend to plug it in and the following codes came up 17075 -engine cooling blow on motor 1-short to earth= wiring short to earth ,engine cool on blow on motor
19557 intake manifold air control actuator-short circuit to earth=wiring short to earth ,intake manifold air control actuator
19558 intake manifold air control actuator -no signal =wiring open circuit ,intake manifold air control actuator
i appreciate any help or advice you guys can give me on this it would be greatly appreciated thanks for any time you can spare .
no1 seen these errors before would appreciate any help thanks
Hi Gearo,
It could be what I had on mine, it turned out to be the Intake manifold flap actuator. £12 to buy, but the manifold has to be removed to get it fitted. So about 1.5 hours in labour. I hope this is the same codes, but My Indie cleared, so I cannot say exactly. But from memory, the error seems the same.
Or you could have a Jammed Flap.
If it is what I had, Disconnect the vacuum pipe at the actuator (Left of the manifold, near the front of the engine) aand suck. If you find you are sucking air (like through a straw) the actuator is no good.
Edited by Deneo
Thanks for your help friend i will check it tomorrow
What did it turn out to be then mate?
