Interior lights
I have replaced the bulbs in my interior light with leds map reading and central bulb.
Despite all this the rear of the passenger compartment still remained very dark
So I have fitted a light in the center of the roof lining and now the rear compartment is well lit
Rear passengers very happy
Any chance of a piccy of this?
I put a couple of these in the back of my car, I stuck them to the pillars with self adhesive Velcro, so that the fitting is entirely reversible should I change my mind -they're pretty bright but due to the angle and location they don't dazzle anyone.
Edited by greenstripe
Can you post a picture of them in the car so people can gauge how they look.
Will do -but will need to wait 'till it get's dark
Would like to see this too - if it looks nice and stealthy then I would definitely try it.
I hate it that it is so dark at the back. I usually at night when I return home put all my staff on the back seats, and when it is time to get them out it is like playing Alone in the Dark!!!
I have tried to add these pics but not very skilled at this.
I inserted the light in the roof lining just behind front seats.
Light has usual three positions
1 always off
2 comes on when doors open goes off shortly after doors close
3 always on
Seems like a good idea.
I'lve been wondering about fitting the Roomster rear headlining mounted light cluster in the Fabia. But it takes some bravery to just cut a chunk out and hope there's something to support it!
Edited by pearce_jj
My biggest problem "was there enough room between roof lining and metal roof"
What I did was take a 1mm drill and carefully drill through the lining until it reached the metal roof and from this I knew that there was enough room to fit my light. The drill is so small ae to leave no detectabl ehole in the lining.
Next I made a template of the light and stuck it to the lining in the desired place. Again using the drill I made holes over the area of the template to make sure there was no obstructions.
After that I cut a hole for the light and fixed it to thr metal roof.
Here's my simpler, somewhat less impressive solution:
Thanks, how did you attach it to the metal, not I presume with the aforementioned drill!?
Using the drill would be effective but a bit unsightly.
After cutting the hole I removed some of the sound deading material to expose the metal roof.
I then stuck two wooden blocks to the metal.
After that the light can be screwed to the wood.
When cutting the hole make sure you are towards the rear of the B pillars as there is a reinforcing bar across the roof.
Is that a dome light from a Felicia?
I have one from spare parts that a friend of mine gave me when I was looking into adding a light on the back but never got around doing it.
The light I used was from a VW Polo.
Did not some models of the Fabia come WITH a rear interior light? If so, the fitting of one should be quite straightforward. Sourse the part, find the standard location, cut, fit and wire! I wouldn't be too surprised if they already ahve the wiring... I have removed rooflinings on a few vehicles, including a VW Vento (To fit another sunroof) And there is often additional wiring for extra lighting where there may have been higher spec models to benefit! Worth a brief check first!
Edited by mrgf
I checked on my Roomster and the rear light is exactly the same part as the front. So maybe the front light set could be persuaded up there in the Fabia too.
SE and elegance
Not sure if it's blue line?, black line? It's a pre facelift but high spec so will have the rear courtesy lights ;)
no that's definately a blue line as it's got the white roof, the blue line alloys, blue line seats and it's blue. they didn't do a black line in the mark 2.
Ah there's your answer! Not sure about the silver handles though ;)
I wonder the rear dome factory cars what difference they got except the hole in ceiling?
Just a hole in the ceiling I've pulled it out to replace the bulbs with LEDs
