1.2 TSi DSG Limp mode
Had the box in S mode and floored it to pass a dawdler. As it changed gear the dash lit up like a christmas tree and the power disappeared. Fortunately I had enough momentum to complete the overtake and then pulled in further down the road. If I pressed the throttle it would stutter as if running on maybe 2 cylinders. I shut the car down then re-started it, it was fine, no lights and perfectly as normal. I know one or two of the vRSs have had DSG limp mode moments but has anybody had an engine go into limp mode?
Would take it in and get them to hook up the computer and see what happened. Better safe than sorry.
No limp mode on mine todate (touch wood)
Plugged it in on VCDS and it showed 3 engine faults: a misfire on cylinder 4, hopefully a spurious 1 off, a boost error that seems to have happened earlier and finally disablement of cylinder 4. A further error showed up against the ABS system on the engine control module. Three of those happened at the same time but the odd one is the boost error that I have no recollection of feeling anything and showed no lights at the time. I'm not sure I understand the date format?
3 Faults Found
6353 - Cylinder 4
P0304 00 [096] - Misfire Detected
Intermittent - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 21737 km
Date: 2017.14.18
Time: 21:10:28
11830 - Boost Pressure Regulation
P0299 00 [096] - Control Range Not Reached
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 21416 km
Date: 2017.14.17
Time: 12:21:10
11836 - Cylinder Disabling
P130A 00 [096] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 21737 km
Date: 2017.14.18
Time: 21:10:28
Readiness: 0000 0000
Address 02: Auto Trans Labels: 0AM-300-04x.lbl
Part No SW: 0AM 300 049 T HW: 0AM 927 769 D
Component: GSG DSG AG7 403 2110
Revision: 00040034 Serial number: 00001006030910
Coding: 0000020
Shop #: WSC 13765 790 00052
VCID: 428F4E3B1E94CEE
No fault code found.
Address 03: ABS Brakes (J104) Labels: 6J0-907-37x-ESP.clb
Part No SW: 6R0 907 379 AA HW: 6R0 907 379 AF
Component: ESP8.2i front H05 0003
Revision: --------
Coding: 430144DB417100B9C22922E582D200801100
VCID: 7DF5FDC7E0EA716
1 Fault Found
01314 - Engine Control Module
013 - Check DTC Memory - Intermittent
Freeze Frame:
Fault Status: 00101101
Fault Priority: 0
Fault Frequency: 1
Reset counter: 211
Mileage: 21737 km
Time Indication: 0
Date: 2017.14.18
Time: 21:10:28
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x8000
Hex Value: 0x1207
Hex Value: 0x13B6
Hex Value: 0x7480
Hex Value: 0x8079
Hex Value: 0x8400
Perhaps a slightly loose connection on C4's coil pack?? Could be the kickdown pulled it away slightly?
(Sorry, I'm guessing)
