Yeti Bulb Numbers/Type
Zippyijk
Recommended Posts
Would some kind soul do me a favour and list the type of each of the yeti's bulbs please??
I'm waiting on mine, should be here any day, but I want to order up some new bulbs for it as the original ones are too yellow for my liking.
I took my bulbs from my Octy vRS before I sold it so I might have some of them already :)
Just need the types not alternatives....there's already a thread for that :D
Link to comment
Share on other sites
Hi Zippyijk
Try this link.
It's a A5 PDF document that I printed and laminated to keep with the owners / drivers manual in Tigger, (our Yeti). It has all the details of fuses and bulbs together with tyre pressures. Hope it helps....................Tony
Edited by Great Yeti
Link to comment
Hi Zippyijk
Try this link.
It's an A5 PDF document that I printed and laminated to keep with the owners / drivers manual in Tigger, (our Yeti). It has all the details of fuses and bulbs together with tyre pressures. Hope it helps....................Tony
That's a really useful document, - thanks Great Yeti.
Link to comment
Hi Zippyijk
Try this link.
The information is also in the owners manual which you can download from the Skoda website.
Brilliant, thanks guys :)
One other thing, I heard somewhere that some bulbs can't be replaced on the front....that can't be true??
Link to comment
No, not true, as various threads on here about changing head light, side light, fog light and DRL bulbs prove. I think the only "difficult" ones are the indicator bulbs.
Link to comment
I got this from another Yeti forum at some point but can't remember which one or post the link sorry! It was Finnish as Weasley helped point out below. Thanks.
Exterior bulbs:
Front:
Halogen lamp version:
Daylight P13W
Foglight H7
Short / Long H4
Parking Light W5W 12V5W
Indicator HPC24WY
Xenon light version:
Parking lights W5W BL
Day light P13W
Fog light H7
Xenon bulb D1S 12V35W
Indicator HPC24WY
Side lamp mirror W5W 12V5W
Back:
Parking Lamp W5W 12V5W
Fog lamp P21W-12V21W
Reverse light P21W-12V21W
Indicator PY21W
Brake light P21W-12V21W
License plate light C5WLL-12V5W
The interior light bulbs
2 x interior lights / reading lights in front of W5W 12V5W
1 pc Glove box light M12V3W
2 x reading lights rear L12V5W
1 piece Trunk light W5W 12V5W
Link to comment
Perutusvalo P21W-12V21W (not sure what this one is? It does not want to translate!)
By a process of elimination, it's the reversing light. May also be a mis-spelt version of "peruutusvalo" (Finnish).
Link to comment
Doh of course! Thanks. I'll fix it above.
Link to comment
Hi Zippyijk
Try this link.
But are the tyre pressures correct for all Yetis?
According to the label inside the fuel filler flap on mine, normal load should be 2.2bar and fully loaded 2.4bar
Link to comment
No, of course not. You should use the pressures quoted on your filler cap label. The information in the handbook refers each owner to the filler cap information sticker where the correct inflation pressures for the specific model that the label is attached too.
The original question by Zippyijk was regarding bulb types and I replied referring to a PDF I had done for our 1.2 TSI (DSG) [clearly shown at the beginning of the document and on each page] which also happened to include the tyre pressure information. That information regarding the tyres is model specific. - Not so the detail regarding the bulbs, which refers to OEM halogen bulbs for all Yeti models fitted with halogen bulbs. Hope that clears that up and avoids any misunderstanding..............................Tony emoticon-0144-nod.gif
Link to comment
Tony,
I wasn't havin a go, as they say.
Of course I realised that the OP was looking for bulb info and that the PDF you kindly provided included tyre pressures just because it was easy for you to have them on the same sheet for your convenience in your Yeti.
The reason I asked was just to see if the pressures were the same on all Yetis. I was sure not as a diesel engine is much heavier than a 1.2 petrol engine so would expect the pressures to be different as indeed they are.
Nice job on the bulb reference sheet :thumbup:
Link to comment
Tony,
Did not think you were emoticon-0148-yes.gif - You raised a valid point that needed clarifying............Regards.Tony
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
