Fabia with odd scan results
Here's the scan result from my wife's '03 1.4MPi petrol Fabia.
The main reasons for posting are a few oddities:
Does it have a CAN Gateway (I thought this vehicle pre-dated that standard)?
Most people seem to have 01 - Engine / 16825 - EVAP Emission Control because they have Air COn problems, this car has no air con! There is no MIL so what could it be?
09 - Cent. Elect. / 00511 - Selector Lever: There is nothing on the ROss Tech Wiki (unless I missed it)
Likewise 01324 - Control module for all wheel drive (It barely drives the front two wheels!)
Does anyone have any thoughts on these issues? It seems as though the vehicle is coded incorrectly, but I can't see what to change to sort it...
Saturday,07,January,2012,16:28:33:13904
VCDS Version: Release 11.11.0
Data version: 20111111
Chassis Type: 6Y - Skoda Fabia I
Scan: 01 02 03 08 09 15 17 19 25 37 44 46 55 56 76
VIN: TMBPB46Y3******** Mileage: 143090km/88912miles
Address 01: Engine Labels: Redir Fail!
Part No: 047 906 033 H
Component: 1,4l SIMOS3PA 00HSSJ4G
Coding: 00031
Shop #: WSC 13765
VCID: 183531947888B4E
TMBPB46Y323587017 SKZ7Z0B1517595
1 Fault Found:
16825 - EVAP Emission Control Sys
P0441 - 35-10 - Incorrect Flow - Intermittent
Readiness: 0000 0000
Address 03: ABS Brakes Labels: 6Q0-907-37x-ABS.lbl
Part No: 6Q0 907 379 G
Component: ABS 5.7 FRONT V20
Coding: 00044
Shop #: WSC 13765
VCID: 4183BCF04B92D56
No fault code found.
Address 09: Cent. Elect. Labels: 6Qx-937-049-C.lbl
Part No: 6Q1 937 049 C
Component: 00 BN-SG. 1S33
Coding: 09226
Shop #: WSC 13765
VCID: 3B7FCE18297EBF6
4 Faults Found:
01598 - Drive Battery Voltage
07-10 - Signal too Low - Intermittent
00511 - Selector Lever (E313)
49-00 - No Communications
00778 - Steering Angle Sensor (G85)
01324 - Control Module for All Wheel Drive (J492)
Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
Part No: 1C0 909 601 C
Component: 02 AIRBAG VW51 0004
Coding: 12338
Shop #: WSC 13765
VCID: 20451974A0D8FCE
Address 17: Instruments Labels: 6Yx-9xx-xxx-17.lbl
Part No: 6Y2 919 860 C
Component: KOMBIINSTRUMENT VDO V12
Coding: 16441
Shop #: WSC 27012
VCID: 458BA8E05FBAF96
Didn't think this car had a CAN Gateway!
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: 31 GATEWAY CAN 1S33
Coding: 00014
Shop #: WSC 13765
VCID: F0E5A934B0B88CE
3 Faults Found:
Setting lost? Faulty? Implausible signal?
Address 44: Steering Assist Labels: 6Q0-423-156.lbl
Part No: 6Q0 423 156 M
Component: LenkhilfeTRW V210
Coding: 00140
Shop #: WSC 13765
VCID: 3973D41023428D6
Address 46: Central Conv. Labels: 6Q0-959-433.lbl
Part No: 6Q0 959 433 E
Component: 31 Komfortger·t 0002
Coding: 00067
Shop #: WSC 13765
VCID: 3D7BC000376AB16
Subsystem 1 - Part No: 6Q2959802
Component: 31 Tırsteuer.FS TFK 0002
Subsystem 2 - Part No: 6Q2959801
Component: 31 Tırsteuer.BF TFK 0002
End
Your car uses K line for the diagnostics but the control units communicate with each other using the CAN system. Power train control units use a high speed CAN, the others use a cheaper lower speed CAN. The gateway allows these different speed systems to communicate.
The Evap fault has nothing to do with the air con, it is basically the vent for the fuel system. The fuel vapours are not vented directly to the atmosphere, but through a carbon filter, which is periodically purged through the inlet. Your fault is intermittent, so it may well clear and if live will likely put the light on.
Your 09 and 19 faults show systems not fitted to the car, the way to get rid of these is to recode the gateway with the same code 00014. this will refresh its installation list.
Fantastic quick response fordfan. Much appreciated.
I'll get on to this tomorrow morning and see what happens.
