Skoda Fabia Dash insert EEPROM reprogram
Hi All! im looking for someone that is able to reprogram the EEPROM in my fabia vrs dash as when installed into my standard 1.9TDI dash its fuel gauge works backwards (says full when its empty etc..)
if anyone can help that would be great!
Thanks!
It does work backwards, i found this when making the vRS estate, you need the tank sender from the vRS and it will work correctly.
There is a fuel gauge 'lookup table' in the cluster (0270h-027fh -> 0280h-028fh), but IIRC, you can't make it work in reverse. It's the same problem as swapping Mk.III and Mk.IV clusters. As far as I remember, most owners who did that, modded the gauge or let it run in reverse.
You could try PMing shark_90 as he may be able to help, but the obvious solution is to swap the sender as Tech1e suggests.
ah sounds like i will be looking for sender unit! i work down at a skoda dealership in kent we did think this but was then told that it has no difference! whoever told me that is one usless idiot! anyway thanks for the help! and tech1e ive had a look at you car looks great i have the same front bumper with vrs rear bumper, we have a vrs rear bumper thats slightly cracked for sale at work on ebay take a look we have had it for a while so they will proberly let it go a little cheaper would look great on your car! :)
Thanks but I've got a full accessory bodykit in the loft waiting for when the paintwork gets sorted :)
oh right ill keep a look out for when its done! :p also just thinking when you say sender unit do you mean the hole thing or just the little unit on the side of the lift pump?
just ordered lift pump £30 from breakers now its a waiting job.. wow i hate being so impatient! :giggle:
