How To Set Valve Clearances
Looking at this it seems to say that the clearances are different based on what tappet rods you have. I've always just followed the Haynes specs which say .20 exhaust and .25 inlet. Anyone have all steel tappet rods or is that dead uncommon?
  • 2 years later...
Would this be exactly the same for the favorit 1.3 GLXIE?
Yes, the engines are more or less the same.
my Felicia has them all steel.
in this regard is the valve if the steel as all 0.20, as shown below is also important to know how to calibrate the valves. has a sequence that is in the haynes manual is excellent
reads this post that I found it here looking:
experiment
felicia right to calibrate the valves according to the metal you have and the year
