Skoda Fabia Reseting Service Light
Hi All,
Is there any way I can manually reset service interval light just done oil change cannot reset as had soft key buttons not stocks like older models
Pete
isn´t it descriped in the manuel? I have the model with stocks and it is descriped in my manuel.
Bgds Dan
There is a combo of ignition/reset odometer, push in/twist to reset. Otherwise, find someone with VCDS :D I don't remember the service reset twisting being in the manual,
All vag marques use the same method, seat forum have it up
So why didn't you copy paste it in here then? ;)
If I could I would ;) I'm a Neanderthal with tech, I'm sure someone can sort it !, I've just done mine :) sorry :(
A link even? I wouldn't know where to start looking for it.
Copy and paste the instuctions...If you cant do that..... How did you turn the computer on?? :think:
Only thing I could find was:
Switch ignition off
Press and hold the odometer trip reset button (next to the speedometer)
With the button still pressed, turn ignition on (do not start engine)
You will see "SERVICE" appear on the display.
Turn the button to the right (clockwise) for about 5 seconds
Must be something very similar to our cars too.
Called my service advisor. He told me how to reset the service-minder. Here's how to do it:
With the car off, press and HOLD the 0.00 button for the odometer reset
Continue Holding the 0.00 button and turn the ignition key to on. MFD reads "Service Now!". Keep holding the 0.00 button and then press the MINUTE button for the clock set. Let go of everything and you're done
Hi Seb, do you know which is the minute button in my dashboard? Thanks in advance
0.0 I think then stalk on the right or the reset button underneath the right stalk
I pad. No pc lol
This is correct for re-setting 'variable service intervals', and returns it to 'fixed service intervals', as Screwloose pointed out.
The instructions are in the owners manual (page 15 I think).
If it's showing 'Insp', then:
Press and hold down trip reset button.
Turn on ignition, while still holding down reset button
After ten seconds (says the book) it will be reset, and return to trip reading, release the trip reset.
Let us know how you get on.
Edited by bathtub tom on 24/02/2008 at 10:46
Reply to this message | Report message as offensive | Link
Thank you very much Seb. I also read the owner's manual (English page 18, Greek Page 20) and it refers only to the 0.0 button, but nothing about keep it down and turn on the ignition. So, time will tell, or dealer at about 3.900 Km from now .
  • 1 year later...
Yes you can!....
I have just reset my wife's Fabia 2 1.2 (51KW) 2011 'Monte Carlo' 'service' warning text (non-dot matrix type). I have changed the oil with a recommended grade and used Mann filters to replace the ones from the last service our last Skoda dealer did.
I have been reading various 'blogs' all morning as I had tried to re-set it the same way I used to re-set my 2006 Fabia Vrs but to no avail.
The manual says that you can re-set it by pressing the '0' button......and that is it!, it does not tell you exactly how for obvious reasons!!.
So I tried holding in the button first before turning the ignition to 'on', I switched on whilst holding my finger on '0'', waited for 'service' to show up, released the '0' button and..... nothing! the 'service' warning came up again, so the next time I did it same method, I turned the engine on , 'service' showed up, after I already released my finger!, so I quickly pressed '0' button again, and then the 'menu' button to the left at the same time, and ....Presto!, the next service due mileage came up!, so I switched off the ignition, switched back on, and no more 'service' text came up, all set , so I scrolled through the menu to see next service due at 9400 to check all was good,
Yep!, long winded I know , but it can be done without using a fault code reader, or dealer. I hope this helps, and you obviously do this at your own risk.
  • 4 weeks later...
Hi there how do you reset the fabia 1.4 2002 service light? Also the odometer thanks
tried as you did above didnt work for me have tried all sorts no good any ideas anyone
  • 9 months later...
ignition off
press reset button keep it pressed
ignition on
pause 5 seconds
release reset button
turn it clockwise
release
job done on our fabia II....hope it works for others
  • 3 months later...
just done this on our 2009 fabia 1 ? 1.2 estate worked perfectly
job done after trying vw code readers and other methods
thankyou
I have a link to my tut in my signature, I opened up the book for my dads VW Jetta, tried the same thing on my Fabia but with the different button for min and it worked. It's a shame they don't put it in the Fabia manual to be honest.
