Fabia II power steering?
I'm looking to change the steering assistance in my Fabia vRS (II) 1.4 TSI towards a heavier - less assisted setting.
I suspect this would be located at
44 - Steering Assist
Recode - 07
But once there, what are the exact values to use? On Fabia-vrs.com the steering assistance is described as ranging from 1 to 5 with 5 being the heavier setting but this is for Fabia mark I. Anybody knowing the correct values used in the Mark II vRS?
Thank you!
  • 6 months later...
Hiya, you don't know what the original code is? I had a dealer make mine heaver, but all he did was give it a non VRS code & which took the progressive out. I now have VDCS & have made it heaver by altering the 4th digit & the range is 1 to 9, 1 being very heavy & 9 very light.
  • 4 months later...
Any one got any updates on this?
I'm all sorted with mine now : ) ( had to search the web to get the origanal code as I got no help here).
What do you need to know Gregs?
I tried this but didn't notice any difference going from 4 to 2!
The standard code for mine (2011 1.4 Vrs) is 11241 & I set mine at 11221, but the wife kicked off saying it was way to heavy :( So it is now set at 11231. it is made heaver or lighter by altering the 4th digit.
Address 44: Steering Assist Labels: 6Q0-423-156.lbl
Part No: 6R0 423 156 B
Component: LenkhilfeTRW V277
Coding: 11231
Shop #: WSC 15288
VCID: 2F670D65EA066D1
No fault code found.
