Milltek sports cat downpipe Fabia vrs
If I were to fit a milltek downpipe with sports cat to the standard cat back would the car need remapping or would the standard software be fine?
Thanks, sib-rs.
You wouldn't HAVE to get a remap but the engine will end up over fueling and destroying the cat.
i have a TMC tuning box on it at the moment would that help..?
I wouldn't have thought so dude. Thing is with a stage 2 map the lamba sensor is turnt off so the engine doesn't inject more fuel to create more gases to reach the level it requires which a tmc prob doesn't do.
Ahh i see, what bhp would I be looking at achieving with a milltek sports cat downpipe and a stage 2 remap?
Around 220 225bhp. Could get anything upto 250 on some rollers but numbers don't matter. What I would say is if I started all over again I would have got coilovers first before the stage 2 stuff.
Unplug sensor??
Agree with pitbull i would definetly do handling/braking mods before speed, im only stage 1 and the brakes are just dangourse when driving fast
I have fitted eibach springs, RARB and front lower engine mounts..I have a TMC box on for the time being with a panel filter and custom intake with ngk sparks but I am looking to go further now both my engine and gearbox have been replaced!
I am waiting to see what forge release in regards with the intercooler to decide whether to go down the route of pace products IC & rad package or just intercooler alone from forge but they seem to be taking there time. I have thought about exhaust but I'd prefer an intercooler before I go down that route
It won't be a problem with a 200 cell SPORTS-cat, but if you have a 100 cell RACE-cat it would occasionally misfire.
There is ways around it, but like guys have stated before... The car needs handling-mods more then power-mods!
Weitec GT dampers and springs on mine, handles like a dream :)!
I had the very first Miltek system and I can assure you it will not be OK. Yesthe car will run but it will destroy your cat. Theres a reason miltek wont warrant a system without a map. The short time between me getting the exhaust and a map the car stank of fuel to the point you would think fuel is leaking out the bottom of the car.
Unplugging would make it worse as it would effectively be detecting no gas flow which is why it needs to be properly switched off.
Is there not 2 sensors? A pre cat and post cat one, i know you can get spacers to space out the second sensor so the light dosnt come on but like pit said that could eddect the running
Indeed there is 2 sensors and its the second that's turnt off
P1ttbull is correct. Its wiser to buy all the parts and then fit them in one go, other wise it wont run correctly plus you'll save on labour.
