1.8TSI and 2.0TSI engine failures
  • Replies 1.9k
  • Views 892.5k
  • streetfighter73
    streetfighter73
    Well after 2 years we finally won our case through the motoring ombudsman against my Skoda dealer.Originally I had a strange rattle on startup .l took the car into the garage twice worried it was the
  • SKODA UK ARE AWESOME.......!!!! I asked, they responded. Whether I should shout about it or not, I don't know. I think they have been generous and I wouldnt want to give others false hope but it got
  • FWIW, I've just rolled past 57k on my 2.0T vRS, which was remapped in Mansfield at 1200 miles 18 months ago. Nothing untoward has happened to it, oil change every 10k main dealer service more for the
I think its very public spirited of you to try to correlate these problems.
Equally as an owner of a 1.8 tsi I am even more enthused by the fact that the problem seems to crop up across VRS models. (Selfish swine that I am).
I have to say, however, that I did copious research before I bought my 1.8 and cannot recall any noteworthy trend of warnings acrosss petrol TSI models. (March to april 2012 research time). Perhaps I glossed over the VRS references.
Just a thought, statistically is this not a small number of problems as a percentage of all VRS models out there. Its well known people contribute much more with hard luck stories than satisfaction.
Every manufacturer has engine failures. It is a very small percentage. People will post on forums when their engine blows up but they won't when it's running fine.
I've been keeping tabs on this too - Dennis I'm pretty sure you have the full list there as far as I can see.
Would be a good idea to match up with catastrophic faults on the TFSI. If the numbers are similar then it's probably no worse than anything else.
Would also be worth matching up with the same engine in the other VAG marques.
MrMatt. Octavia VRS TSI. 39000 miles. It's 2 months out of Skoda warranty. I purchased it from a dealer less than 3 weeks before the problem occurred. I have not yet had the report of what's happened. Suspected timing chain tensioner issue. The dealer has informed my Skoda will not help regarding the cost, repair etc..
Get on to Skoda Customer service and speak to them about a known fault with the timing chain tensioner.
If you have only had the car 3 weeks & it was from a skoda dealer you should have a years warranty as part of the sale,if it was a motor trader you should still have a 3month warranty on the car.
I have Dec 2009 registered Octavia VRS which is two months out of warranty. Just 36000 miles - full service history.The timebelt tensioner has just gone (Ive been told by an independent VAG specialist) and so has the engine I'm told. Its with a Skoda dealer right now who has told me they will charge me for three hours work (i.e. £240.00) to tell me what they already know is wrong with it and that then they will go to Skoda UK and see if they can recompense given that its just out of warranty. Sods law !
like most owners of a Tsi engined vrs I too am becoming more worried about a tensioner failure. So I spoke to Suk today (again) asking / telling about my concerns only to be told to take my concerns to the dealer where I bought the car and have a nice day. I think a well worded email to the papers and auto express is required informing the general public about the real views of existing customers
Am I the only tsi owner that isn't "worried"? I'm more concerned about being hit head on and dying in a blazing fireball tbh, though I do hold my breath for a fraction of a second every time I start the engine!
Sent from my GT-I9300 using Tapatalk 2
I ain't worried about Tbh if it goes wrong ain't much I can do about it
1.8TSi has chain driven camshafts while the 2.0TSi in the VRS is belt driven so they are totally different series of engines. These problems sem to only affect the VRS (same engine as in my Eos, my Scout is a 1.8TSi).
No. The 2.0 TSI in the current vRS is chain driven. It's the older 2.0 TFSI that appeared in the pre-FL vRS that uses the belt.
Oh and as to the "am I worried?" question.
No, not really. There are obviously far more "silent majority" engines that are having no problems, so odds are that all will be fine.
If it goes wrong within the original 3yrs I'm covered and I nearly always extended warranty to 4 years (my planned length of ownership on this one) so will make sure such an issue would be covered by warranty for all the time I own the vehicle.
Edited by Stoofa
Email the papers to say what? 10 failures isn't a large number given the volume of TSI engines that must be out there, and SUK appear to be funding all that are under warranty and most of the cost for those that are out of warranty but have been maintained in the dealer network, plus they've changed the design for the replacement part/later engines to corect the problem.. so what exactly would you complain about?
I think this needs to be kept in perspective.
Maybe the mods should make this a sticky, and Dennis could edit his first post with a summary that recognises the issue but makes it clear that its not that common and most failures have been resolved etc? Otherwise there is a danger that this becomes one of those internet urban myths.
Is it possible that the extra grunt from the vRS causes more trouble than in the 1.8TSi ?
Plus maybe that by its very nature the sporty vRS encourages driving more towards the extreme end of its power range?
Just a thought that maybe the 1.8 TSi is more within the mechanical limits of the general design.
. go onto some american sites where the TSI engine has been in use a bit longer and you find it is a lot more than 10 failures
Edited by swany
and your point is what exactly? Every manufacturer has some problems on some model or other at some point - from what I've seen SUK are not being unhelpful in resolving the issues, but they have to make a call as to whether financially and based on level of risk, number of failures etc it makes more sense to recall every one or just pay on a case by case basis. obviously in this case its more cost effective to fund individual failures.
If you're really that worried replace the part yourself, or buy an extended warranty when your factory cover runs out, or buy something else? TBH if you look on google you'll find "issues" with just about every vehicle ever made!
Not in my case. :giggle: Sorry, couldnt resist. :happy:
Its the usual story of anyone thats got a reliable motor; takes it for granted. Anyone thats had an issue heads straight off to complain about it on the forums. Im sure ultimately theres nothing to worry about and the overall statistics probably back that up but at the same time, I love these threads as they are great support when SUK or the dealer are saying that your failure is a one off incident etc.
Asked exactly the same point ages ago and never got a direct response to it... so don't hold your breath!
Rob e, I know what you are saying and yeti man makes a valid point too. What I am saying is it is a worry when you read as much hype on forums about the failure, all be it its only 10 on here, the issue is when you phone the dealer they say they know nothing about the problems although there has been at least 2 tech bulletins about it, and suk wont even or cant tell me if my car, being a late 2011 is fitted with one of the up dated tensioner. Too cut a long story short, if I had the cash to change the car I would, my faith in the vag group cars has faded over the last 5years due to the usual problems that are noted on briskoda.net
I looked and only found 5
...if I had the cash to change the car I would, my faith in the vag group cars has faded over the last 5years due to the usual problems that are noted on briskoda.net
Best thing you can do is stay off the forums because you'll find endless complaints about problems with any make of car you choose to buy.
I checked the small print in my Skoda Extended Warranty, it says they don't cover "inherent design faults". Ummm, I expect this is on many other warranties.
If I found the fault to be "an inherent design fault" that causes any "pricey" damage to my car then I'd be seeing Skoda in court if they failed to stump up the full cost of repairs.
