Fabia Vrs Carista Customisations List
The following settings were available specifically to your vehicle using Carista:
This is based on a 2011 Fabia Vrs using a Wi-fi OBD2 (£10 eBay) and the app Carista (£15)
Doors / Windows / Remote
Auto-lock doors when moving
*YES* / NO
Auto-unlock doors when key is taken out of ignition
*YES* / NO
Auto-lock trunk when moving
*YES* / NO
Unlock trunk when doors are unlocked
*YES* / NO
Blink turn signals when locking/unlocking with remote
*YES* / NO
Beep when locking with remote
*YES* / NO
Beep when unlocking with remote
*YES* / NO
Beep when alarm is armed
*YES* / NO
Unlock doors via remote
DRIVER'S DOOR ON 1ST PRESS, ALL ON 2ND / *ALL DOORS ON 1ST PRESS*
Enable settings for opening/closing windows and sunroof
YES / *NO*
Open/close windows via long-press on remote
*YES* / NO
Open/close sunroof via long-press on remote or key
YES / *NO*
Open sunroof via long-press on remote
YES / *NO*
Close sunroof via long-press on remote
YES / *NO*
Open/close windows by holding key in door lock
*YES* / NO
Blink turn signals when done closing windows via remote
YES / *NO*
Re-lock doors automatically if you unlock, but don't open a door
*YES* / NO
Enable remote control buttons when ignition is on
YES / *NO*
Instruments / Display / Dings
Instrument cluster language
CHINESE / CZECH / DUTCH / *ENGLISH (UK)* / ENGLISH (US) / FRENCH / GERMAN / ITALIAN / NORWEGIAN / POLISH / PORTUGUESE / RUSSIAN / SPANISH / SWEDISH / TURKISH / NONE / SYMBOLS (NO TEXT)
Instrument cluster region (affects ext. lights too)
GERMANY / *EUROPE/OTHER* / USA / CANADA / GREAT BRITAIN / JAPAN / SAUDI ARABIA / AUSTRALIA
Multi-Function Display
*ENABLED* / DISABLED
Gauge needle sweep at startup (req. instrument cluster support)
*YES* / NO / NOT AVAILABLE
Seat belt warning
Lane-change turn signal auto-flasher
Lane-change turn signal auto-flasher count
1 FLASH / 2 FLASHES / *3 FLASHES* / 4 FLASHES / 5 FLASHES
Lights
Daytime running lights
Allow configuring daytime running lights via dash display
*YES* / NO
Coming-home lights (req. auto headlights or manual flick of high beams)
ENABLED / *DISABLED*
Leaving-home lights (req. auto headlights)
Coming/leaving-home lights use…
LOW BEAMS / *FOG LIGHTS*
Turn off front fog lights when high beams are on
YES / *NO*
Turn on interior lights when key is taken out of ignition
*YES* / NO
Flash brake lights in emergency stopping
*YES* / NO
Flash hazard lights in emergency stopping
*YES* / NO
Brake lights work even when ignition is off
*YES* / NO
"Euro" parking lights when ignition off, turn signal on
Other
Activate side mirror heaters when rear window defroster is on
*YES* / NO
Automatic wipers (using rain sensor)
Speed-dependent windshield wiper speed
YES / *NO*
Additional 'tear' wipe after windshield washer use
*YES* / NO
Auto-enable rear wiper when front wipers on and reverse gear engaged
*YES* / NO
Horn works even when ignition is off
YES / *NO*
I used this app the other day and it worked a treat. Highly recommended.
Its just a shame it doesn't have some more of the advanced settings like steering weight and xds otherwise it would be an immense app.
Sent from my SM-N910F using Tapatalk
So basically it's for the people who don't have Vagcom/VCDS?
I struggled to find someone near me with vag com/VCDS so tried this instead.
basically it's doing the same thing for hell of a lot less....VAGCOOM might have a few extras that i'm not aware of mind, but more popular bits like the above it's blooming good idea.
Does the coming home lights work?
That'd be awesome if we could get the DRL's to shine up.
Unfortunately they don't as you need automatic lights.
I might look in to getting the kit that does the auto lights.
Also can you have it where the left mirror drops when in reverse
It doesn't have that feature I wish it did to keep an eye on the rear alloy
Been wanting to use this on my Monte but can't find a OBD2 device that Carista supports. Thinking of getting this one as some googling found an Audi forum with people that said this one worked well. What OBD2 device do you use?
Edited by dan4291
Mine is one of these: http://www.amazon.co.uk/dp/B00DYOVXZ0
Worked perfectly. Just trying to figure out if coming home lights are possible... The "manual flick of high beams " wording has got my hopes up.
Great find OP
Great find OP
Just be aware one of those links is for Bluetooth,the one below is wifi version for iPhones
Good app tho
Good app tho
Yeah the one I linked is a Bluetooth adapter, that doesn't work with iPhones. The WiFi one should work with both though
Anyone know if it will work on a 2013 vrs cthe engine
Sent from my SM-T530 using Tapatalk
Hi grant your only in doncaster you can pop over to Wakefield and I can have a look if you want pal?
Great find OP
I tried the going home lights but it didn't work on my 2013 Monte. No amount of flicking the headlights worked.
Got the other stuff done though, minus the mirror dip, which I would really like!
Sent from my SM-N9005 using Tapatalk
Appreciate that would you really do that
Sent from my LG-D802 using Tapatalk
Pm'd you pal
Just downloaded and tried. Have the beep when locking the car, doors lock when moving off and unlock all doors with one press. Happy days....
Ive bought two obd things now and the app tells me theyre both defective and can only read the fault codes, Really want the needle sweep and all doors unlocking at the same time
Jim this is one I purchased from the bay of e
I've customised 4 vag cars with this now using Carista and iPhone 5s hope this helps.
That is a 'ELM 327A OBD2 V1.5'
Edited by goneoffSKi
That looks like the one ive except its bluetooth not wifi iirc and im on android
Edited by jimdiesel
would anyone know if these units would talk to say a sat nav head unit on the canbus? i need to enable a feature in the background but dont want to pay an arm and a leg for the ross tech cable etc.
