Removing coil packs how difficult?
Recommended Posts
2015 Octavia Ambition 1.4 tsi 103, how difficult is it to remove coil packs in order to replace plugs. There is a vw tool but this is unavailable to order from the dealer. Will a good pull do?
Regards
Roger
Link to comment
Share on other sites
Thanks for your replies.
I intend this car to be a keeper, 10 years, 300k kms and after the warranty runs out I do my own servicing as I have done with all my cars over the last 50 years. I am at 15k kms now so the plugs will require changing next year at 60k kms so I am just preparing early if you like. Never had trouble with the boots on my other cars before but the workshop manual does specify a special tool.
Very pleased with the car so far.
Regards
Roger
  • Like 1
Link to comment
Ah!  Makes sense now.
You'll want to do the fuel filter too (it's conveniently left out of the Service Schedule last time I looked).
IIRC, the air filter is something stupid like 90,000km - bring that forward to either 45k or 60k.
If you have DSG it's supposed to be 60k but if it's a keeper then do it at 45k.
Manual trans is supposed to be sealed for life but I'd be aiming at somewhere between 60k-90k.
I'd also consider fitting an aftermarket catch can to reduce the likelihood of build up of oily / carbony sludge on the inlets.
Link to comment
If its the letter generation tsi engine the coil packs are bolted down...
That's what I understand too.  A good pull will not be enough.  This is in Spanish, but you should get the idea:
https://erwin.seat.com/workshop/de/fichas/ficha_t10530_3576.htm
Edited by iriches
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
