Cornering fogs light up in reverse
Is there any way to stop cornering front fogs from lightning up when select reverse. I have an SE Sport.
I think the idea behind it is to generally light up the whole area around the car.
Maybe it can be disabled with VCDS if you want to mess around with that?
I had to enable this on Mk3 Leon so that fogs would work when reversing - it was enabled automatically on the Octavia Mk3 when the cornering fogs were activated.
VCDS Coding for Seat to switch off is here - might be similar for Octavia but have not tried:
09 central electric >>
16 security access code 31347 Unlock>>
10 adaptations From drop down select - (1) static AFS light-at Rueckwaertsfahrt - Set value to 'Off' from 'Double Sided' then >> Do It
I think the idea behind it is to dazzle you with excess light in front, so you can't see in the dimly lit area behind you
Correction in-line.
