Vrs 230 electro mechanical diff
Does anyone know what year if the electro mechanical diff was fitted too?
im looking at purchasing one and notice it was fitted when launched but dropped at some point.
was this when the 220 was dropped or the 245 launched?
VAQ was fitted to the pre-facelift 230 and the facelift 245. Pre-facelift 220 and facelift 230 do not have them.
MY19 245s which are the MY18 230 replacement models due to WLTP emissions have them standard. This is what I just got this week with VAQ and 7 speed DSG.
If you buy new vRS, they should all be with 245 HP and with VAQ differential, as a standard.
Someone please correct me if I am wrong.
Yes you are correct as I said basically this above :)
Thanks .It will be a used buy. I was hoping to get a facelift 230 but might have to be a pre facelift or try and find a 245!
Definitely worth finding one with VAQ. I've had many FWD hot hatches and in comparison, this 245 is remarkable around corners in the dry (granted it's no Quattro or X Drive etc.)
Excellent decision by Skoda to equip the new petrol vRS with it.
Isn't this the same as xds? I've got a FL SE Tech coming soon and it's listed in the specs?
A can only agree a says the man who just got one. It's doesn't a handle like any other fwd car I've ever owned before! :)
20 minutes ago, pist0nbr0ke said:
Nope - XDS just uses the ABS system to brake an inside wheel, there's no mechanical diff element.
This explains it in brief:
https://www.pacificvolkswagen.com/blog/benefits-of-golf-gti-xds-cross-differential-system/
Gotcha. Cheers
Edit: is vaq the unit that attaches to the gearbox and acts as an e-diff? When previously looking, it came up but not sure if that's xds+ or something different?
Edited by gRoberts
22 hours ago, gRoberts said:
Gotcha. Cheers
Vaq is attached to the gearbox. Sooooo much better than without.
Xds is just  through braking the wheels.
  • 6 years later...
Does VAQ have oil that needs to be changed?
Yes a Oil & filter service, @ 3 years / 30,000 miles or sooner. Hard use @ 20,000. & now for a VAQ with a Mk4 it is @ 2 years / 20,000 miles.
As above. It is made of Haldex bits, so needs the oil replaced and the pump gauze/screen cleaned out.
Where are you based @MrRee? The Phirm in Camberley are excellent, and used by several members on here.
