Skoda Octavia Interior Illumination Conversion by EddyH
  • Administrators
Guide researched and written by EddyH.
This how-to covers all the work involved in changing the interior illumination in an Octavia to
W8 light link is dead.
All the photos are missing too. :(
I'll try to find the link for you.
Edit: This one's pretty good: http://www.borabase.com/w8.htm
  • 11 months later...
Thanks mainly to Eddy's help, i'm nearly complete on my Golf Mk4 illumination conversion.
I have everything complete now except for the Clocks and the centre console switch LEDs.
The clocks are nearly there too - I have a set of half-FIS clocks which just need coding plus some EPROM code changes to enable RTE (Range To Empty) and the illuminated dial needles, and we're done !
I got Motometer Clocks (seems that many of the UK Immo3 TDi / half-FIS are of this make) - but the PCB will fit inside the Skoda VDO casing.
The only minor niggle is that using the Golf foils (which are a little plain) - the shape of the Skoda centre minor gauge aperture reveals a cutout in the Motometer foils.
I will see if there's some matt black plastic I can fix over this for now to hide it.
W8 - if you would like a fitting guide - have a look at my website. It's been there for years !
W8 Inner Light
Glad to help Jon. Thanks for the new link to your W8 interior light how to.
How are you geting the emprom coded for RTE? That's a feature I'd quite like.
  • 4 months later...
Eddy, I'm interested in how you hooked the FIS up to the Stereo/MFD. Have you still got the pics?
J
J
PM me your email address and I'll send some through.
Eddy, if you start a new thread and copy the above in, you could add the pictures to it? We can then close this one.
I went to alot of effort in the first place including pictures and they were removed. I'm over my attachment limit and I don't have alternative hosting setup.
I'm well under my attachment limit, if you send them my way :)
J
J
You should have an email.
Pictures here. You can edit the links in the original post now if you like. A bit clumsy, but at least they're on the server!
J
15658.attach
15659.attach
15660.attach
15661.attach
15662.attach
More pics.
J
15663.attach
15664.attach
15665.attach
15666.attach
15667.attach
And some more.
J
15668.attach
15669.attach
15670.attach
15671.attach
15672.attach
All done :) Plus a PDF of the whole lot together, so you can print it and take it to the car!
J
15673.attach
15674.attach
15675.attach
15676.attach
  • 3 years later...
hopin someone can help me out here..just got a vw climate display to replace my ocy one but wont show up temp and led's wont work is there a specific one needed to work on ocy? i have noticed that mine is einstelleinheit (adjusting unit) II and the vw one is adjusting unit III also software(i think thats wat it is)is diffrent mine is c2.0.0. and vw 0006 ??? does this make any sense and can anyone help? is it possable to recode vw one??
aghh so many questions.....
  • 4 months later...
Can you send more pics from changing LED on gasoline tank button and button for rear window?!
