disable esp vcds
hey can  anyone help me disable the esp on my car?
Wednesday,23,October,2019,17:18:02:05787
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 19.6.2.0 (x64)  HEX-V2 CB: 0.4508.4
Data version: 20190930 DS308.0
www.Ross-Tech.com
VIN: TMBLE73TXD9042836   License Plate: CV68133
Mileage: 143190km-88974mi   Repair Order:
Chassis Type: 3T-SK46 (7N0)
Scan: 01 02 03 08 09 10 15 16 17 18 19 22 25 36 37 42 44 46 47 52
          55 56 62 69 6D 72
VIN: TMBLE73TXD9042836   Mileage: 143190km-88974miles
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
18-Aux. Heat -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
22-AWD -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
37-Navigation -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
69-Trailer -- Status: OK 0000
6D-Trunk Elect. -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine (J623-CFFB)       Labels:. 03L-906-018-CFF.clb
   Part No SW: 03L 906 018 EF    HW: 03L 906 018 BR
   Component: R4 2.0l TDI   X25 9977
   Revision: 42X25---    Serial number:
   Coding: 001D001A042600080000
   Shop #: WSC 00440 218 00000
   ASAM Dataset: EV_ECM20TDI01103L906018EF 003008
   ROD: EV_ECM20TDI01103L906018EE.rod
   VCID: 72BDDBA4242E4827CF3-8026
No fault code found.
Readiness: 0 0 0 0 0
Address 02: Auto Trans        Labels: 02E-927-770.clb
   Part No SW: 02E 300 015     HW: 02E 927 770 AL
   Component: GSG DSG AG6     512 3519
   Revision: 05651213    Serial number: 00001212201998
   Coding: 0000020
   Shop #: WSC 33361 790 00052
   VCID: 50F9712C86E25A37197-8004
Address 03: ABS Brakes (J104)       Labels:. 1K0-907-379-60EC1F.clb
   Part No SW: 1K0 907 379 BL    HW: 1K0 907 379 BL
   Component: ESP MK60EC1   H31 0152
   Revision: 00H31001
   Coding: 843D6016192600FC211306E7981F0042350000
   Shop #: WSC 33361 790 00999
   VCID: 7DA7F8986DF0075FA21-8028
Why would you want to disable it? It's unlikely you will be able to do this with VCDS, you would probably need a tool capable of editing the EEPROM on the appropriate controller, and it may not be trivial depending on how much integration there is between ESP and other vehicle functions.
i live in norway, and we have alot of snow. disable it can hep me up,and around corners, and i like to drift 4x4.
You could try 843D6016192680FC211306E7981F0142350000
It's should allow 'two stage ESP defeat' - hitting the traction control button once will disable traction control and holding it should also disable ESP.
Just to point out, I don't think the ESP is every truly disabled but it might be OK for your needs. If you need it fully disabled, you'll need to pull a fuse but you'll loose ABS too.
Thanks. I will try that.
Is it esp sport?
I come back to you, on how it went.
I believe it's how the 2012+ Scirocco R, Golf R and Golf GTI were configured out the factory. Given that, it's probably ESP sport rather than true ESP off.
It workes very good.  Thanks for your coding.
I did that on mine long time ago and it worked. (On Octavia 2 it can work too)
But what actually is deactivated, as you say "not truly disabled"?
You say it is some kind of sport mode, what kind of ESP is it then?
What is still active after the button is pressed for 5 seconds?
What varies between the settings is how much the controller will allow the car to slide before it intervenes to bring things under control. Even in the default setting it will allow a small amount of sliding before it acts.
It drifts like a shame.
Mine drifts with TCS and ESP on - when we have snow.... It is the TCS that cuts the power a little - not ESP. That just saves your life and keeps you on the road.
The ESP acts by selectively applying the brakes and will also intervene at some point in a slide, it's just there's a degree of slide allowed by the system before it acts. These days ESP and TCS are designed to operate as a single system with the intention of keeping the car pointing the right way on the road either by applying the brakes or cutting engine power, and additionally on haldex equipped cars changing the power distribution between front and rear.
  • 5 weeks later...
Can you tell me what option in that coding needs to be changed?
It has many differences to mine and I would like to change only what needs to disable ESP .
Sadly my VCDS is older and it doesn't have descriptions for this coding.
Thanks.
try to set, byte 6 bit 7 and byte 14 bit 0
Coding not accepted.
I have:
   Part No SW: 1K0 907 379 BM    HW: 1K0 907 379 BM
   Component: ESP MK60EC1   H46 0164
   Revision: 00H46001
   Coding: 843D6016192700FA210C06ED98200052A1080023
Tried to change the last two digits from 23 to 73 or 70 coding is accepted but cannot disable with long press.
Then I would guess, it is not possible with this one.
It was written, these bytes/bits would be unnamed and if accepted one could test, if not accepted, not possible.
