reduce one touch indicator flashes
I am fed up with the number of indicator flashes when stalk is touched, I am sure it can be reduced, I have a VAGCOMM so can somebody give concise instructions how to reduce one touch to minium number of flashes.
Not sure why you would want to reduce it, it only flashes 3 times anyway.............now I have read this, might increase mine to 5.
have a look here, probably similar for Fabia.
It is doable as I had a nice guy do mine on his VCDS. It used to do the three flash and off, now it only flashes if you lock it on or hold it. No counted flash. As mentioned above by Urban Panzer, you can have 0, 3 or 5. Thats the lot of adjustments, I think.
All done, thank you Ubanpanzer it was indeed the same as the Octavia shown in the You Tube video.
