Karoq "drumming" noise
I have a brand new Karoq and have a bad "drumming" (resonance) noise on the car. It is apparent at low speeds on all but very smooth roads. It is very annoying and spoils a nice car.
What are the tyre pressures set at?
Just "standard" pressure as car brand new only done 200+ miles.
Standard as in the over inflated pressure that the car is transported to the dealer at, and not set correctly during PDI?
PDI report shows all tyres at 2.2 however I shall check tomorrow in daylight.
My tyres were all at 50psi when I picked mine up new from the dealer. I didn't know that at the time, I just assumed that as it was new the tyre pressures would be correct. When I did check them out of curiosity a few weeks later I couldn't believe how over inflated they were!
Thank you will check my pressures in the morning
just in case - double check that the suspension transit blocks haven't been left in / missed on PDI, not unheard of!
1.0 engine?
A mild resonance at lower revs is typical on 3 cylinder engine
It might be worth looking at the 'Road Noise' thread started here by icebun 6 January see previous page.
It's brand new?  Do you have the SE-L or Edition by any chance?
Edited by Guest
Yes it is SE-L 1.5 petrol DSG
Just a hunch it may be the rear parcel shelf - might not be seated properly or the flap might be rubbing against the seats. ( because thats what happened to me ). Try removing the shelf altogether to see if noise still there.
4 hours ago, croquemonsieur said:
icebun
Thank you, I shall try this.
