Karoq in the snow
Does anybody actually know the difference between Snow Mode and Off road mode when driving in the snow.  There are a various videos with the Karoq in the snow, most are completely  useless, all they do is drive round in the snow with music.  There is no explaination of what button does what and the effect it has on the car.
You do seem to ask the same question time and time again :)
There's a Skoda explanation here https://www.skoda-storyboard.com/en/models/skoda-4x4-your-best-bet-in-the-snow/ which talks about how to drive a Karoq in the snow, and it mentions that "Of course, the throng of electronic stability systems, combined with the Snow driving mode, have got your back and will help to keep the car under control even in fraught situations. On the other hand, if you switch to a sportier mode for wheel spins and bigger skids, you’ll find gliding and watching snow fly in all directions a lot of fun."
It then goes on to say that "Needless to say, 4×4 drive ŠKODAs are not afraid of off-road terrain, even when it’s covered in snow. As with on-road driving, when you’re off-road, fluidity, correctly gauging your speed and sensitive handling are essential. The wheels need to be in constant rotation because if they lock or spin you won’t be able to actively control the car." and "Turning on the Off-road driving mode can be a great help as it allows the car to overcome obstacles that would otherwise be insurmountable. And if you’re unsure what exactly is lying in wait for you ahead, don’t hesitate to get out of the car and walk some of the route on foot – this is still easier than having to shovel your car out if it gets stuck. “If you know what your car is capable of and what its limits are, you’ll be able to enjoy your 4×4 ŠKODA to the full,” explains Stuck."
I've also seen it stated that "Off-Road mode is an extraordinarily complex assistant for more challenging off-road situations. The Off-Road Mode works at a speed up to 18mph, and its function can be divided into three main groups: start and traction support, braking support, and steep downhill support. When it’s activated, all the related assistance systems are switched into a special setting suitable for off-road driving.
It is only suitable for driving on unsurfaced roads, and when switched on, it alters the characteristics of the ESC, ASR, EDL and ABS systems to give improved traction. (ESC helps to stabilise the vehicle by braking an individual wheel, ASR reduces the power to the wheels when they spin, EDL brakes a spinning wheel and transfers power to a different drive wheel, and ABS prevents a wheel locking under braking.)"
While "Snow mode changes how the assistant systems behave so that they help the driver as much as possible on low-adhesion surfaces. The ABS anti-lock braking system, for example, allows for more wheelspin when braking to allow snow to accumulate in front of the tyres to increase the braking effect (the “wedge effect”). In turn, the anti-skid system allows for greater wheel rotation for better grip on winter tyres. The transmission shifts to higher gears at lower speeds than usual, and the accelerator pedal responds more slowly so as to prevent the wheels from jumping into spin with the added torque."
Chris
One of the great answers to a motoring question.  I shall now enjoy the snow if we get any in N wales.  At the moment it could do with a run anywhere, as currently it is doing about 2 months to the gallon!
John
There are quite a few videos out there that show road testing of 4x4 suv type vehicles to find out whether they will drive off a roller when they are put under one, two or three wheels.  The track is a slight slope and the only vehicle to make it was the Subaru.  None of the others with lots of convincing names describing their systems made it.  This appears to be that the others do not transfer enough power to the wheel or wheels with grip.  Must get a set of rollers.
