Skoda Running costs
I've noticed in the past that people ask about the running costs for various models, so I thought I'd try and create a thread where the info could be stored in one place.
Please add as much detailed info as you can.......
  • Replies 54
  • Views 44.6k
  • 2002 1.8T 4X4 Estate 1st variable service including Haldex oil change (own LongLife supplied) - 9263 miles - Main Dealer since closed -
  • I know this hasn't really been added to much of late, but as my car is getting on a bit, figured I'd post the work it's had done over the last 9 years/100,000 miles. It's a 1.4 16v (AUB) Fabia estate
Had mine for 32 months, did 138k miles in it.
Fuel economy; motorways cuising at 80-85 indicated, I'd get about 38mpg, A roads about 35, brisk driving on A roads about 30-32, trackdays about 12 and the Ring about 8-10 mpg.
Servicing costs: You can either go variable servicing or fixed 10k servicing. I went 10k due to my mileage and needing to know when it would need a service. Costs were:
10k =
This is based on a friend
Ooooh , nice idea.
My 1.9 tdi elegance (110bhp) is about to go , so over 3 years and 80000 miles I paid out the following
10k - £90
20k - £230
30k - £90
40k - £260
50k - £90
60k - £240 including free cambelt change (Would have been £250)
70k - £90k
4 new tyres , fronts at 40k rears at 60k - £360
Brake pads - £22
Warranty fixes were an air vent and a switch on the clutch pedal
Fuel consumption averaged at 52mpg which is about 7000 litres of diesel. At a rough average of 90p a litre that was £6300
Depreciation was £8k , so my 80000 miles cost me in total £15772
Is it a 110?
Is it a 110?
Yes , I've edited my post accordingly
My Octavia Elegance 1.8T Estate
- Current mileage 96,000
- Cam belt changed with main dealer service
Any Fabias costs available? They've been around for a while now.
Denis, any 4x4 costs?
Can't add much for the Superb pd 130 now one year old and on variable service
Cost
Fabia vRS PD130 fixed 10K service (only option)
10K Service - £167 Warranty = Replaced engine mount
20K Service - £167 Warranty = new seat base and gear **** under warranty
30K Service - £167 warranty = Front ARB Drop Links, rear washerjet sticking, N/S/F outer CV boot replaced
35K Warranty = Replaced ARB Drop links, new seat base, refitted rear washer pipe
40K Service - £250
50K Service - £180 Warranty = New D/S/F Headlight, Heater fixed, Driver seat base replaced, fixed intercooler pipe leaking.
57K Warranty = Turbo bearing failed. Turbo replaced
60K Service & Cambelt Change - �525
70K Serivce - £140. EGR leaking (not replaced). Intercooler pipe leaking (fixed)
75K ish = Camshaft position sensor replaced, Alternator wires repaired DIY
80K Service - £137 Lower boost pipe leaking (not replaced), bonnet release sticking (not replaced)
84K - £115 Front lower rear wishbone bushes replaced along with N/S console (damaged bolt) DIY
87K - SuperPro dogbone mount
90K - DIY Service £30 oil (5L), oil filter, sump plug and 1l screen wash. All from local dealer. Bonnet released fixed. DIY
92K - Genuine lower gearbox mount (replaces Superpro)
Tyres
0 - 17K = Michelin primacy 205/45 16 83W
17K - 30K = Falkern 451 205/45
30K - 50K = Toyo Proxy T1R's 215/40
50K - 58K = Toyo Proxy T1R's 205/45 (Front)
50K - 70K = Toyo Proxy T1R's 205/45 (Rear)
58K - 70K = Bridgestone RE300 205/45 (Front)
70K - 84K = Pirelli P Zero Nero 205/45 16 83W Front
70K - Present = Pirelli P Zero Nero 205/45 16 83W Rear
84K - Present = Pirelli P Zero Nero 205/45 16 83W Front
Brakes
Front
0 - 17K = OEM front pads, front discs Changed to 312's
17K - 50K = Ferodo DS2000 front pads
17K - 70K = EBC OEM front discs
50K - 86K = Ferodo DS2500 front
70 - 86K = EBC OEM front discs
86K - Present = Pagid OEM front discs
86K - Present = Unknown oem front pads
Rear
0 - 50K = OEM rear pads, rear discs
50K - Present = Ferodo DS2500 rear
50K - Present = EBC OEM rear discs
Fuel
Day to day driving to and from work which is 50 miles of both motorway and country lanes = 45-50mpg.
Brisk country drive high 30's to low 40's mpg
Track driving 17mpg
Edited by faboka vrs
Model in post title
Nice one John, thanks.
just paid £180 for 2nd service,brake fluid and that [3rd oil change] but thats a fixed service so oil a lot cheaper and no air filter [green 1] :thumbup: [john mulholland. Ulster. ]
  • 4 months later...
:bump:
So we can get some more numbers.....
planning on updating mine soon. Just need to dig out all the records.
:) Its cheaper to service the car yourself and look after your own baby if competant as most servicing is oil and filters. :thumbup:
'04 Fabia vRS over 60K miles:
Oilman supplies oil cheaper than my dealer, so I supply the oil for services.
February 05 – 10K service
Skoda Elegance 110tdi registered Nov 2000
18,500 Set of tyres uniroyals
Thanks Martin and Bryan.
Any more Superb and Fabia ones?
  • 3 months later...
Updated my main post.
For info the flywheel (which was going to cost
  • 2 months later...
Fabia 1.9TDi Comfort Estate 2001
10000 - Cost Kc 4399 ! (was in Czech Rep so had it done there - biggest part of the bill was the oil!)
18863 -
Updated main post.
  • 3 months later...
:thumbdwn:
Motorline in Canterbury are qouting me 336.00 for a 20,000 mile service on my two year old Furby Vrs!
Absolute robbery - I have found cheaper already - hope your listening:D
I would say a mark 1 OCT VRS is not bad on fuel:
Around town your lucky or very light footed to get in the 20's
On a motoway 35 is average
Not bad for a turbo i guess
  • 4 months later...
Updated
