lights
skoda fabia 2017  my head lights wont turn off   thanks
@ahancox
Sounds like the light switch might be faulty then.
You will need to have an auto sparks or someone that knows about cars to look at it if you can not.
Worth putting the posts about your Mk3 Fabia in the Fabia Mk3 section.
should the light switch turn on and off head lights with  motor running thanks
Yes you should be able to turn off the head lamps and side lights. or just the sidelights with the engine running, but then the DRL's will be on / stay on.  (Daytime / Daylight running lights, front only)
Maybe you are confusing daytime running lights with headlights? Just a thought as they are very  bright.
NO ITS HEADLIGHS
WHERE IS RELAYS ON A 2018 SKODA FABIA I THINK ONE HAS STUK ON THANKS
Most of them are under the steering wheel, atleast on EU models.
thanks
