Upgrade to spare wheel
I have a 2017 Superb with 18" wheels fitted with 235/45 R18 tyres. I want to replace the puncture repair kit with a spare wheel and tool kit. I'm a bit confused as to whether I need a 16" or 18" wheel. I assume the 16" spare comes with a 205/55 16 tyre and the 18" spare with 205/50 18 tyre. According to my calculations both of those give close to the rolling circumference of the original tyres. So does it matter which I go for or am I totally barking up the wrong tree!?
Depends on what engine you have (therefore the size of the brakes)
The 2.0 petrol engines need a minimum of 17" wheels to clear the brakes, whereas the 2.0 TDi can run 16".
A 205/50/18" would be closer circumferance than the 205/55/16" to your current 235/45/18", however I thought all the 18" spare wheels were the really skinny 125/70/18"???
Thanks Gizmo
2.0 TSI Petrol engine so looks like it will be the 18". You're probably right about the tire size as I was only guessing! 125 is certainly narrow!
The 220TSi spare wheel is a 16" one - at least it is on mine and I have used it!
Thanks 100andthirty
So it looks like the 16" will fit over the brakes. I assume the tyre size on your spare is 205/55? According to my calcs there is only 1% variance between the circumference of that size and the road wheels. But then I did fail O level maths twice!
The 280/272 engine has bigger brakes, hence they require a 17" spare to clear the brakes.
All the others can have a 16" spare.
size of disk is less important than size of tire
16" can be installed even on 280/272 version, just install it on correct place - rear axle
stock size of spare wheel's rubber is lot smaller than normal tire and that disables usage of cruise control
On 14/04/2018 at 08:09, MartiniB said:
replaced stock 205/55r16 by full diameter 205/65r16
weren't easy put it in cause back side plastic
diameter comparison to 215/55r17 and 225/55r17:
205/55r16 _ -5.3% _ -6.7%, this huge size difference cancels usage of cruise control
205/65r16 _ +0.8% _ -0.7%, not tested yet
On 10/12/2020 at 09:39, MartiniB said:
there is no space for 215 mm width under floor cover, but is enough room for full diameter tire
i have replaced to 205/65r16 (not tested on the road yet)
because stock 205/55r16 disables Cruise Control (were installed on rear axle)
Thanks all for the input. Just going off to Ebay to see what I can find in the way of 16". If there is an 18" wheel on there can I still fit one of those as an alternative or stick to 16"?
Cheers.
Still confused! Just rang Hortons Skoda with a view to getting a new wheel and kit and they say I need an 18" spare ! Tyre and kit £220 inc VAT.
14 hours ago, RolandK said:
Thanks 100andthirty
Yes, that's the tyre size and there's 1 50mph warning sign on the wheel
Thanks Gizmo
I am on the lookout for one for mine but i am going with like for like, There's one in birmingham for £80 but he wont post it. Hills in ormskirk have a few mk3 cars ive emailed them with my request just waiting now.
Hi Paddy
Are you going 18" then?
What benefit has 18"?
32 minutes ago, RolandK said:
Hi Paddy
Hi Roland the wheels on mine are 17" mate, I don't need a new one its just incase i get a flat in a place where i can change without waiting for the RAC, So i then can drive my local tyre fitters the next day, I don't do big mileages so a used one will do me just fine.
Ok. Same as you I don't do much mileage these days but I'd much prefer to have a spacesaver than using the foam. Although I'd rather not be using either on a motorway hard shoulder! Only ever changed a wheel there once. It was offside and very scary. Even worse these days where the left lane is also the hard shoulder. Crazy idea that's going to cost lives.
 I had a blowout  at 70 in a hilux invincible on the m6 when i used to work, sh%%%t myself and it was so loud but me and my apprentice changed it on the hard shoulder very scary indeed, my car which i have only had a week only has a can of glue stuff and a mini compressor which is not worth a blow of a ragman's bugle.
Me too have used to stock 205/55r16 spare wheel just for ~80km,
mounted on two line higway ~20 min PM
And as i wrote above, that ~80km without Cruise Control were enough big motivation to replace rubber by 205/65r16
I don't think there will be a lot alternative tire sizes for 18" disk
I'm not sure if there is a benefit over the 16" spacesaver. However, having spoken to Hortons Skoda today they were adamant that an 18" wheel and kit was what I needed. Also looking at the Caffyns website the categorically say the 16" fitting kit is not for cars with 18" or 19" wheels. It says
Restrictions: Not suitable for vehicles with 2,0l TSI/ 206 kW engine or models with 18 or 19″ Alloys
Possibly an 18" spare is the current recommended kit? In the meantime I've ordered a 16" spare which, according to guys on here should fit and if it does then I'll worry about getting the related kit. Only had the car 3 weeks so not exactly a Skoda expert yet!
On 18/04/2021 at 18:23, RolandK said:
I have a 2017 Superb with 18" wheels fitted with 235/45R18 tyres. I want to replace the puncture repair kit with a spare wheel and tool kit. I'm a bit confused as to whether I need a 16" or 18" wheel. I assume the 16" spare comes with a 205/55R16 tyre and the 18" spare with 205/50R18 tyre.
No one makes a 205/50R18 tyre size. You might be thinking of 205/50R17 which has a similar outside diameter to 205/55R16.
However, both these tyre sizes are too small for the Superb MK3.
Someone was saying that a 215/60R16 was just slightly too wide to fit flush in the spare wheel well, and that 205/65R16 fitted.
Maybe try a 195/65R16 92V fitted to a Superb MK1 6Jx16 ET40 steel rim.
https://www.camskill.co.uk/m62b0s8631p114095/Michelin_Tyres_Car_Michelin_Energy_Saver_-_195_65_R16_92V_(MO)_TL_Fuel_Eff_%3A_B_Wet_Grip%3A_A_NoiseClass%3A_2_Noise%3A_70dB
It's got to be better than using one of those skinny space savers.
Edited by Carlston
Yes you're right there don't seem to be any 205/50R 18 tyres!  I think the 205 width is the most you can get in the well. I've established that the 16" spacesaver comes with 205/55 R16 tyre and the 18" with the skinny 125/70 R18.
As I said before - the 280/272 (206kW) engine has bigger 340mm brakes which the 16" rim will NOT clear it.
If u've got a 280, then get a 17 or 18" spare.
Or if u want cheaper, get a 16",  but u'll b able to use it on the rear.
The 2.0L 220 (162kW) engine has 312mm brakes, hence the 16" rim is fine, front or back.
I don't know wat size the TDi versions have.
Edited by JR RS
Yes I saw that thanks but my car is 220 BHP so front brakes shouldn't be an issue.  312mm discs I think. I'm going to try a 16" spacesaver first to see if that fits as it puts a bit more rubber on the road  than the skinny 18".
Skoda Octavia 2020 1.8TSi
Tire
Rim
Vehicle's recommended cold tire inflation pressure. It is measured in bars or PSI (pounds per square inch).
205/55R16 91V 6.5Jx16 ET46 2.2
225/45ZR17 91W 7Jx17 ET49 2.2
225/40ZR18 92Y 7.5Jx18 ET51 2.2 / 2.3
https://www.wheel-size.com/size/skoda/octavia/2020/#trim-18tsi-eudm-177
It looks like the Octavia MK3 6.5Jx16 ET46 rim with 205/55R16 is being sold as a spare for the Superb MK3.
Superb MK3 tyres such as 215/60R15 have an outside diameter about 5% bigger than 205/55R16.
However, 205/55R16 is a cheap tyre size (it's Europe's most popular car tyre size).
For the Superb MK3, I would choose the Superb MK3's 6.5x16 ET41 rim size over the Octavia MK3's 6.5Jx16 ET46 rim size, even if I fitted a cheap 205/55R16 to use as a spare.
Octavia MK3 6.5Jx16 ET46 Spare Wheel with 205/55R16 tyre
https://eshop.skoda-auto.cz/cs_CZ/kompletni-rezervni-kolo-16/p/5E0601011J
Edited by Carlston
Tire
Rim
That's useful info thanks. I'm going to try the 205/55 R16 route.
