Engine failure
Recommended Posts
51 minutes ago, lichfielddriver said:
Seems the cambelt tensioner fell apart, belt shredded, engine dropped its lunch down below
How fragile these things are...
Come back crossflow pushrod Ford Cortinas
Was it changed at the 5 year interval as recommended by Skoda UK?
  • Like 1
Link to comment
Share on other sites
Over 25 years ago I had exactly the same thing happen on a Vauxhall Corsa GSi 16V, so this isn't a VAG specific issue. The cambelt tensioner failed one week after a cambelt change (the main dealer replaced the belt but not the tensioner).
We want high compression engines for efficiency, emissions, power, etc and that means having valves that will hit the pistons if incorrectly timed - we can't have our cake and eat it.
Link to comment
There are non-interference engines out there
For sale Inc 2 year skoda warranty on engine...
Link to comment
1 hour ago, lichfielddriver said:
Only 3 years old
Hi, very unfortunate, but you say 'only 3 years old' - your profile does say 2015 1.6 TDI.
Link to comment
On 08/03/2022 at 22:34, roottoot said:
They are not fragile but not 100% bulletproof and not engines with 1 in 5 failures as in your other thread.
http://briskoda.net/forums/topic/502054-i-am-the-1-in-5
Well let's look at it...
Engine block cast metal
Crank forged and machined
Camshaft solid steel
Crank shells high quality bronze/phosphorous?
What operates the important valve openings on this interference engine?
£5 worth of 1" wide nylon webbing as strong as my braces..
Another big earner for garages either to replace or fit new engines when they fail..
Manufacturers must award designers for the best revenue streams in parts and labour
DMF
DPG
VGT
EGR
Edited by john999boy
Quoted post removed
  • Confused 1
Link to comment
I had a cambelt fail on a 1.8 Sierra turbo diesel, £400 skim head/new valves, back on the road, the 2.5di transit could shed a belt and be running again with a set of cam followers fitted
we are going backwards not forwards
Special Award if anyone can tell me the special secret of the FWD Vauxhall Cavalier (at least the petrol models)
Edited by lichfielddriver
Link to comment
Some of the engines were "cam safe" and would survive a belt fail. I had several Cavaliers through the 80s and had a single failure. Only damage was the oil pump.
I seem to remember that the clutch could be changed without separating the engine and gearbox - very clever.
Link to comment
Thats its trick
I did mine, £40 job
Link to comment
Correct term is interference or non-interference
Link to comment
True, but the term "cam safe" is good for non-technical people and a marketing phrase
Link to comment
15 hours ago, lichfielddriver said:
Thats its trick
I did mine, £40 job
I've still got the "clutch changing kit", ie short slide hammer with adaptor to fit shaft and a set of clips for the clutch - unused, they were bought just in case, but car, a 1991 Cav GSI 4X4 2000 16V, was just too reliable and never ended up needing a new clutch!
Link to comment
On 09/03/2022 at 20:22, lichfielddriver said:
Thats its trick
I did mine, £40 job
They copied Saab from about 15 years before
Link to comment
Easy clutch replacement? Access panel in inner wing so that input shafts etc can be removed easily.
Didn't work with all though - for some reason on the very latest versions they did away with the inner wing access panel!
In the past I had a Datsun 100a that had a similar clutch arrangement - replaced is less than 20 minutes even as a one off DIY.
Edited by bigjohn
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
