What oils meets specs VW 504 00 / 507 00 and are VW approved?
The following oils meets specifications VW 504 00 and 507 00 and are VW approved. All are 5W-30 oils. Those highlighted in bold are or were available to buy in the UK.
Addinol Mega Light MV0539 LE
Agip 7008
Autol Carrera Longlife III
Aral SuperTronic LongLife III
Astris Matro L-3
Aviasynth 5W-30 LongLife 3
BP Visco 7000 Longlife III
Bucher AG Motorex Profile V-XL
Castrol EDGE 5W-30
Castrol SLX LongLife III
Castrol TXT 507 00
Castrol LongLife III Hochleistungsmotorenol
Castrol SLX Longlife III Topup
Cepsa Star TDI Synth
Divino Syntholight 03
Elf Solaris LLX
Eurol Syntence Longlife
Fuchs TITAN GT1 Longlife III
Galp Formula Longlife III
Gamaparts Super Longlife III
Havoline Ultra V
Madit Gold Longlife
Megol Motorenol Compatible
Millers XF LONG LIFE 5w30
Mobil 1 ESP Formula 5W-30
MOL Dynamic Gold Longlife
Panolin Avanis SV-X
Pentosin Pento Super Performance III
Q8 Formula V Long Life 5W/30
Quantum Longlife III 5W-30 - 504 00/507 00
Repsol Elite Longlife 50700/50400
Shell Helix Ultra Extra
Shell Helix Ultra VX
Statoil LazerWay LL
Tecar Motorenol 504 00 / 507 00
Top Tec 4200
Total Quartz Ineo 504-507
VAPS Vapsoil 507 00
Volkswagen LongLife III
Wintershall ViVA1 SLV Plus
Zeller+Gmelin Divinol Syntholight 03
VW 504 00 covers the following VW-specifications for petrol-engine cars:
VW 501 01
VW 502 00
VW 503 00
Vw 503 01
VW 507 00 covers the following VW-specifications for diesel-engine cars:
VW 505 00
VW 505 01
VW 506 00
VW 506 01 (See Post #10 below for important exceptions which apply to this spec only)
  • 8 years later...
Hi, Can anyone say whether the oil that Kwik Fit offers is good for Octavia II 1.6 Petrol, ie: they offer:
Titan Super F 5W30  ( I presume it's TITAN Supersyn F 5W30)
5W30 sounds ok as per manual, but that particular Fuchs oil isn't listed anywhere as approved by VW.
Thanks for any advice.
If the oil you are talking about is as per the following link then it isn't approved:
http://www.fuchslubricants.com/titan-supersyn-f-sae-5w-30
The full list of approved oils and which oils are needed for which engine / servicing regime are in the following post:
http://www.briskoda.net/forums/topic/320854-octavia-mk2-engines-dpfs-cambelts-oils-brakes-and-servicing-info/
Note that you can use longlife oil for fixed interval servicing if you want.
Thanks to all who replied to my question.
As I suspected it's mainly for Fords and according to the link
from Owl it's VW50200 standard not VW 50400
even though it's 5W30 how strange ...
Thanks again
FYI, there is no issue using VW504.00 for fixed interval servicing. VW502.00 meets the requirements for fixed interval servicing only whilst VW504.00 meets the requirements for both fixed and variable interval servicing on petrol engines.
I wouldn't substitute 507.00 for those engines that have a specific need for 506.01.  V10 Toureg & T5 Transporter spring to mind.  It's just asking for trouble.
I did say on petrol engines in my post above :)
I agree with what you are saying though with regards longlife requirements on some vw diesels. The reason I don't mention it in my post on oils, servicing etc is that I was only talking about requirements for octavias and the octavia has never been fitted with any of the affected engines.
VW 507.00 oil
"The oils in this section meet the VW 507.00 specification. These oils are suitable for almost all VAG diesel engines from 2000 onwards with extended service intervals, unitary injector pumps and also Pumpe-Düse ("PD") engines.
Excludes V10, R5 engines and VW Commercial vehicles without fitted DPF (diesel particulate filters) – these must use a 506 01 specification oil."
Never knew this!
I wasn't referring to your post.
referring to this:
VW 505 00
VW 505 01
VW 506 00
VW 506 01
It's 90% right but there's just those few "gotchas"
gm dexo 2
  • 9 months later...
The following oils meets specifications VW 504 00 and 507 00. All are 5W-30 oils. Those highlighted in bold are known to be available in the UK.
Agip 7008
Astris Matro L-3
Bucher AG Motorex Profile V-XLCastrol EDGE 5W-30Castrol SLX LongLife III
Castrol TXT 507 00
Elf Solaris LLX
Eurol Syntence LonglifeFuchs TITAN GT1 Longlife III
Havoline Ultra V
Madit Gold Longlife
Megol Motorenol CompatibleMillers XF LONG LIFE 5w30Mobil 1 ESP Formula 5W-30
Panolin Avanis SV-X
Pentosin Pento Super Performance IIIQ8 Formula V Long Life 5W/30Quantum Longlife III 5W-30 - 504 00/507 00
Repsol Elite Longlife 50700/50400Shell Helix Ultra ExtraShell Helix Ultra VX
Statoil LazerWay LL
Top Tec 4200
VAPS Vapsoil 507 00
Zeller+Gmelin Divinol Syntholight 03VW 504 00 covers the following VW-specifications for petrol-engine cars:
VW 501 01
VW 502 00
VW 503 00
Vw 503 01VW 507 00 covers the following VW-specifications for diesel-engine cars:
VW 505 00
VW 505 01
VW 506 00
A bit of a thread resurrection but a very useful post :)
Dave
  • 2 months later...
Can anyone tell me if "fuchs titan gt1 pro flex 5/30 xtl" is good enough for my fabia vrs?
It's 502.00 / 505.00 / 505.01  so it's at the minimum.
TITAN GT1 PRO C-3 SAE 5W-30  would be a better choice (IMO)
Guest
