Octavia: Useful part numbers for Octavia DIY servicing and mods
  • 2 years later...
  • Replies 178
  • Views 213.8k
  • Heyup, Just spent an hour or so getting together all the part numbers etc. you would need for OEM service filters/fluid replacements, these numbers are for my MkI vRS - when referring to fluid's and
  • I've just put this in the octavia technical guides and thought I'd put it in here as well as it might get missed. Rear wiper motor rebuild kit Available from; TPS/Dealer and eBay Price; £31.91+vat
  • It is but for £40 I'll just hang my finger on the stalk !!!
Made this a sticky.
Please feel free too update and let me know if there are any changes too the number already up and I'll edit accordingly :)
Edit 29/01/10
I've tidyed this thread up, add anymore numbers and I'll have another tidy when it gets messy again
HTH
Edited by fatty5000
Update
  • 1 year later...
Anyone have the part number for the thermostat? AUQ engine
Also after the metal retaining clip that connect to the electrical plug on the air temp sender, mine was cable tied on :dull:
Cheers!
Cheers!
thermostat 050 121 113 C
Mucho gracias amigo, just ordered one
The thermostat is £19.10 + vat ouch
I know i could get a pattern one for less than half the price but i don't wan't to go down the 'pattern route' anymore
Just oredered a couple of the clips too @ 51p, i'll put the part number on when i i confirm they are the correct ones.
Thanks again
Hi can you tell me if the plastic window guides are the right ones for a octavia estate 1998 model?
Throttle Body Gasket??? I coudnt see it
028 129 0748
HTH :D
Danka!
it does cheers,
  • 4 weeks later...
Hi guys and gals can anyone confirm that the Warning light (ie modified hazard warning light/indicator relay) 1U0 953 235E 300 - £28.36 listed above in the list is a direct replacement for 1U0 953 235B please as i need to grab one as both the indicators and hazards are not functioning on my sisters 52 plate Octavia VRS. Anyone know if you can get these from a VW dealership parts dept? Thanks in advance Al.
Edited by Al Wyn
no the one you require is 1U0 953 235 B 300, the other one with the E is for cars with towing equipment attatched, and these are skoda specific unfortunately £27.25 + VAT
Thanks for clarifying that...much appreciated ;)
Does anyone know the part number for the Secondary Air system pipe that goes into the airbox?
Many Thanks
I do love this list!!
Got a few questions?
Im guessing the golf mk4 wipers are an easy think to do and a direct replacement?
The strut brace is off tha S3?
And lastly the rear lights is so can you do the mod to have them in the rear headlining?
Adam
Adam
Yes, yes and yes.
have a look at my website for pics of all of these things (link below)
I would like to know the OE part number of VRS 1U shock obsorbers (F&R) or it is common for both normal and RS?
fronts 1J0 413 031 CM rears 1J0 513 025 BH
Hi,
Anyone know the part number for the drivers door mode switch on the mk1 Vrs? the interior light doesn't come on if i open the drivers door, also locks itself which is a pain in the rear.
Cheers :thumbup:
can anybody help with part number for convenience unit part number as my drivers door wont lock and mirror not working its for mk 1 vrs
Edited by copycat999
vRS Gear Oil for 02J (EHA) gearbox - G 060 726 A2 (confirmed by dealer)
  • 4 weeks later...
Gear shift cable to gear box linkage fitting.
For future reference,if someone needs them,there are 2 part No's,as one pin on the gear linkage is small (8mm) and the other is larger(10mm).
1J0 - 711 - 761B(Bowden Cable Catch) 10mm bush
1J0 - 711 - 761C (Bowden Cable Catch) 8mm bush
N 908 - 159 - 03 (Lock washer) which is the same for both.
Fuel filter
1J0 201 511A
£7.42 or £8.72 inc. VAT (August 2010)
Recently bought items from TPS (late June early July)
8N0804583 mechanism bracket x4 TT jacking pads to you and me £16.05+vat
8N0803855 mechanism bearing x4
1ML805903 front spoiler Front splitter £19.22+vat
8L9806529A bracket £57.18+vat S3 strut brace upper and lower with fixings
8N0199403B support £25.80+vat
N10467901 bolt-hexagonal head x2 56p
N90914701 rivetted cap nut x2 £3.46
6U0601151LMHB wheel cap £5.30each +vat Wheel centre caps
1J0971658L harness £17.66+vat Coil pack wiring loom
8N0407181B bush £15.69+vat TT solid bushes for front wishbones(rear bush)
Fuel filter from Eurocarparts (Bosch) £5.30+vat
Hi, Can anyone tell me the part no./dimensions for the front brake rotor for a 2003 1.6 octavia. Thanks in advance
Mr Haynes says you need a 256mm disk 22mm thick. min thickness is 19mm
hth
billy
