BRISKODA.net: DashBoard Creak (Fabia) - BRISKODA.net
  • 2 Pages +
  • 1
  • 2
DashBoard Creak (Fabia) Rate Topic: -----
#1 User is offline   PEMBO
  • Briskodian
  • PipPipPipPipPip
  • Group: Members
  • Car:Octy vRS 2010 2.0 CR
Posted 02 November 2006 - 21:21
Its been annoying me for weeks, and I decided that while Im off college with man flu, Ill fix the creak. Armed with 6 plastic cards, I managed to get the vents out and (hopefully) fix the problem. Heres a guide avec pictures...
To stop anything that may snap (god forbid) falling into an abyss, put the heaters onto the feet position.
Heres the hard bit. Use the cards to release the retaining clips which are circled (there are another 4 under these too in the same positions).
http://i66.photobucket.com/albums/h259/mikepembo/DSC00061.jpg
If its too tight a fit with 3 cards under and 3 cards above just use 3 under, and gently prize the top part away (this is abit more risky as you need a fair bit more force and the clips could snap). The top should protrude about 3-5mm, then you can "wiggle" the bottom out fully.
http://i66.photobucket.com/albums/h259/mikepembo/Untitled2.jpg
Heres some close up pics of the clips:
http://i66.photobucket.com/albums/h259/mikepembo/DSC00058.jpg
http://i66.photobucket.com/albums/h259/mikepembo/DSC00059.jpg
Dont pull the vents fully out, as you need to unclip the hazzard light switch from the vents first!
http://i66.photobucket.com/albums/h259/mikepembo/DSC00071.jpg
Once you have the vents out its plain sailing.
Now you need to choose your method of taking up the gap.
Quote
From awt41 - If you use a long thin screwdriver or something similar, you can just manage to push some foam into the gap between the bracket and the top of the dashboard. Pack it in tight.
I know it looks daunting, especially with the ventilation cups and the metal bracket down the middle - but it can be done!
It cured the problem on mine - see recent thread.
Regards, awt41
Alternativly,
Quote
From Bingyp - Hi there everyone,
I've also used the cork method, and so far it is a succcess. Dash seemed to be getting noisier and was driving me potty so I gave it a go.
I didn't use the same method as the above, slightly more unusual tools!!
On removing the vents, the bracket to wedge is central, about 6 inches in and underneath where the ridge on the dash is. I say central but I got better access from the driver's side vent.
Looking at the bracket, there is a gap at the bottom about 2-3 mm.
I cut the cork length ways. The cork is then 'D' shaped. the flat part goes to the bottom.
Thanks to skomaz' excellent advice I tried it with a small chamfer but couldn't get the cork to go in very far. So I then cut a much flatter angle, leaving the leading edge around 2-3 mm as per the gap.
To offer the cut cork to the bracket, I used a wooden chopstick about 10 inch long. Sticking the cork onto the pointy end of the chop stick firmly gave good control as the cork is put in position.
Once the cork is where it needs to be, I slowly rotated the chopstick to release the cork.
To push the cork more firmly home, I used the shaft of a small-headed hammer to gently, repeatedly knock it home. Securing the shaft with a 'pool-cue' type grip gave nice control as I tamped the cork home.
And that's it. The cork seems nicely seated, wedged in the bracket. There are now no squeaks from the dash so I can now hear all the noises from the trim/seats etc!!
It was a simple, painless job. If I can do it then anyone can.
Hope this helps someone.
Regards,
Bingy
Whichever you choose, your aiming for this part which looks like a top hat metal section, its behind a greyish plastic vertical support strut. I cant really describe it, but youll know what part when you see it. :D
http://i66.photobucket.com/albums/h259/mikepembo/DSC00055.jpg
Oh, and I thought it would be ideal if I sorted out my head unit at the same time and heres the result:rolleyes: :
http://i66.photobucket.com/albums/h259/mikepembo/DSC00070.jpg
Hope this helps everyone who is turning deaf because they had to turn the radio so loud in order to drown out the mouse under the dash! :rofl:
Mike Pembo
#2 User is offline   seano47
  • Briskodian
  • PipPipPipPip
  • Group: Members
  • Car:Fiat Bravo
Posted 29 November 2006 - 14:14
Thanks alot i thought it was just my VRS that made this noise lol
will av a go at sorting it at the weekend
#3 User is offline   PEMBO
  • Briskodian
  • PipPipPipPipPip
  • Group: Members
Posted 29 November 2006 - 22:31
Your very welcome! PM me if you need anymore info. :thumbup:
#4 User is offline   lakeywhite
  • Briskodian
  • Pip
  • Group: Members
Posted 05 December 2006 - 14:10
My set up seems to be different to this, when I start to remove the fascia part of the vent it seems to leave behind the louvre and adjustment dials. I have not looked further into it as I didn't have much time, so I put it back.
#5 User is offline   PEMBO
  • Briskodian
  • PipPipPipPipPip
  • Group: Members
Posted 05 December 2006 - 16:25
Sounds like the facia clips are detaching instead of the full unit coming out.
These are the locations of the clips that are coming undone I presume on yours:
http://www.briskoda....=1&d=1165335814
It may be easier to remove the radio and put your hand up behind the vents and push it out that way :confused: Give it a try :P
Attached image(s)
  • Attached Image: 1/2/2/9/0/12276.attach
#6 User is offline   echase
  • Briskodian
  • Pip
  • Group: Members
Posted 03 June 2007 - 18:52
Not quite clear where to put the half cork. I have put mine 6" in front of the greyish plastic vertical support strut. It's inside the top hat and underneath 2 diagonal plastic struts that slope down from above.
Photo (double click on it) taken from left vent shows the top hat to right of cork and one of these sloping plastic struts above it. Is this the right place?
When pulling out the vents 4 of the spring clips detached from the vent and one fell inside. Maybe I had got the credit cards below the top clips rather than above them. Took me 3 hours of dismantling the central fascia to find it. Not helped by Halfords selling me the wrong radio removal tool.
Attached image(s)
  • Attached Image: 1/2/7/2/0/15259.attach
#7 User is offline   Rob.
  • Humbug!
  • PipPipPipPipPip
  • Group: Members
  • Car:04 Black Fabia vRS
Posted 07 October 2007 - 10:11
Well, that's where I stuffed an almighty amount of packaging foam from a HDD! Seems to have fixed my squeek... Now to cure the 2 other major noises (the plastic trim that goes over the high level brake light rattles between 1000-1500rpm.. and summint aint down proper like, in the boot!
anyways.. just wanted to confirm the location as correct and your description as perfect!..
two plastic supports come down from the dash at an angle.. the aim is to stuff something under these and in the top hat metal bracket to push UP on the plastic supports! and stop the flexing.. wherever it actually is!
#8 User is offline   linc1
  • Briskodian
  • Pip
  • Group: Members
  • Car:Fabia 1.9TDI
Posted 02 August 2008 - 20:25
Thanks everyone for this info about the source of the squeak! I followed the directions and stuffed some packaging material underneath the two plastic struts and it seems to have pretty much cured the noise for now. The method I used was to cut a long (about 1.5 metre) strip of thin packaging foam, about 5cm wide, and then push it into the gap using a cutlery knife, starting from one end of the strip and feeding it in gradually. This has the advantage that you can't drop it inside the dash by accident as you have hold of one end!
#9 User is offline   dxg
  • Briskodian
  • PipPipPipPip
  • Group: FREEDOM
Posted 08 August 2008 - 23:26
Is this to cure a "mouse-like" creak or a loud "plastic on plastic" rattle?
I've got really bad rattling coming from this area (and now from in front of the dash pod) and am wondering if it's the same thing (I'm beginning to fear it's the dash support / cross-brace)...
BTW I've been using bits of pipe insulation to cure the other creaks and rattles with pretty good success so far...
#10 User is offline   fabiash
  • Briskodian
  • PipPipPip
  • Group: Members
  • Car:Fabia 1.4 MPI
Posted 16 March 2009 - 19:28
I put an uncut cork just behind the plastic pillar in the centre in each of these pics at the bottom.
Is that right?
BTW I thought the hardest part was taking the hazard out from the middle.
#11 User is offline   PEMBO
  • Briskodian
  • PipPipPipPipPip
  • Group: Members
Posted 17 March 2009 - 12:15
Is that right?
Yes, should be. If it stops the squeek then WINNER:D
#12 User is offline   fabiash
  • Briskodian
  • PipPipPip
  • Group: Members
  • Car:Fabia 1.4 MPI
Posted 17 March 2009 - 18:35
Well it has reduced it alot.
I dropped one cork down the back into the ablyss.
Is there anything it could get caught on?
#13 User is offline   PhilTop
  • Briskodian
  • Pip
  • Group: Members
  • Car:Skoda Fabia 1.9tdi Elegance
Posted 18 June 2009 - 21:51
Thanks to this thread I fixed my rattle today. Lost one of the clips and 2 others broke so I had to super glue them but apart from that it was a success. Well, I haven't been on a long drive yet but when I popped down the road there was no longer a rattle.
It was harder to remove the vent than I expected and although I used 6 credit cards, I found that prizing out the bottom first was the easiest option. I used a plastic floor spacer cut in half and wedged it into the gap whilst loosely taped to a long screwdriver and it seems to be stuck well in there. Not sure if other people had to do this but I needed to guide the vent back into place using the credit cards positioned under the clips as they were catching.
Thanks to everybody who has contributed to the thread.:thumbup:
#14 User is offline   lennyoberon
  • Briskodian
  • Pip
  • Group: Members
  • Car:fabia
Posted 17 July 2009 - 20:54
Thanks for that PEMBO only picked our fabia up the other day and two things have been driving me mad!! 1) the engine light has come on (egr valve) and 2) the dashboard was doing my head in, at least one thing is off the list.
By the way I used about 40mm of hose pipe rammed full of cloth to stop it from collapsing. Went in really easy and squidged in nice and snug.
Thanks again, the radio can now be turned down to a sensible volume.
#15 User is offline   PEMBO
  • Briskodian
  • PipPipPipPipPip
  • Group: Members
Posted 22 July 2009 - 16:55
Not a problem :thumbup: I have the EGR issue too, but been ignoring it for sometime now as it occasionally goes back off.
If you do get any progress on your EGR though do send me a PM as Id be interested in how you manage with it.
#16 User is offline   glasgow-westend
  • Briskodian
  • Pip
  • Group: Members
  • Car:Fabia TDI Elegance
Posted 26 July 2009 - 10:49
I've been trying to fix the notorious dashboard creak on my 2002 Fabia TDI for years. Recently it has got a lot worse and has been doing my head in. Thanks for this thread the problem is now fixed! The key is to put the wedging material into the metal "top hat" bracket to stop the two horizontal plastic members above it creaking against it. So hats off to PEMBO for isolating the problem to this component, as randomly stuffing wadding in behind the heater ducts just doesn't work. I went in and removed a huge amount of sponge wadding my Skoda dealer put in when I first had the problem years ago. I then wedged a piece of folded over bicycle inner tube from a knackered tube into the top hat. My Fabia is now purring along with no irritating trim noises to spoil the driving experience.
#17 User is offline   vanagonjon
  • Briskodian
  • PipPipPip
  • Group: Members
  • Car:Fabia 1 1.9TDI Elegance Combi
Posted 16 August 2009 - 11:32
AMAZING!!! both of the Mk1 Fabias that I have owned have suffered from this blasted squeak and now it's gone!! Thanks for saving my sanity :-)
JON
#18 User is offline   Woolfy
  • Titter ye not
  • PipPipPip
  • Group: Members
  • Car:2001 Fabia 1.4 16v Elegance Estate, still missing my Audi A3 2.0 FSi Sport
Posted 20 September 2009 - 18:51
Fantastic guide this
My dash squeak has gone thanks to the clever positioning of a shaped to fit cork in just the place suggested.
I'd never have known where to start without this guide:thumbup:
#19 User is offline   Kablam
  • Briskodian
  • PipPipPipPip
  • Group: Members
  • Car:Fabia 1.4mpi (00)
Posted 21 September 2009 - 17:50
I'm either really stupid and am failing to follow this guide or I've got a special squeek, either way I haven't managed to stop it by padding out what I assume I'm supposed to.
Could someone do me a favour and take a picture of it finished before the vents go back in to confirm either of my fears.
#20 User is offline   Woolfy
  • Titter ye not
  • PipPipPip
  • Group: Members
Posted 21 September 2009 - 19:53
Hmmm. Me too, my squeak has returned, and after a whole journey without it, it is really annoying.
It might be that the cork has dropped out (as it did seem to cure it) or, like Kablam, I am really stupid or I have a 'special' squeak.
Piccies would be good, anyone?
This post has been edited by Woolfy: 21 September 2009 - 19:54
Reason for edit: still rubbish at typing - new fangled computers - humbug
Share this topic:
  • 2 Pages +
  • 1
  • 2
Fast Reply
Loading
