HOWTO: New Octavia - Headlight Bulb Change
  • Replies 131
  • Views 229.6k
  • Many thanks this must have took you some time and effort. j coll
  • I can't think of any reason why it wouldn't be ok to do just the dipped beams, indeed that's what I'm planning to do myself. There are various opinions on which are the best replacement bulbs, but I'
  • (google translation swedish-english) Replacing the xenon lamp on the Octavia II D1S bulb units for xenon dipped beam on Octavia II. Time to change - Max 15 min / lamp A Open the bonnet Unscrew t
j coll
Glad it was of use - other members on Briskoda have hekped me no end, so I thought it would be good to do something in return.
Excellent 'How To' :thumbup:
Very nice "How-to" excellent pictures also :thumbup:
I will get round to adding it to Octavia-vRS.com as discussed Andy but I don't seem to have so much time at the moment.
Excellent guide, thanks. I will be using this within the next week. :thumbup:
Andy
Fantastic guide, great pics and write-up. :thumbup:
My parents have an Octy 2, so I shall bear this in mind if any of their bulbs go.
I want to upgrade the bulbs in my Superb, but I don't think it is as straightforward as the Octavia.
Chris
Well done Andy:thumbup:
I changed mine in half light, wind and rain, and couldn't see how to release the connector.
Managed to do it with the connector in place, but there is a real risk of scratching the paintwork if the lamp slips.
How much leverage did you need on the connector tab? Are we talking fingers or screwdriver blades here? (Just so I know for next time.)
Thanks for the illustrated guide.
Managed to change my indicator bulbs today without removing the entire headlight, fiddly but possible :thumbup:
I did it with fingers, although if I'm honest I must admit I'm not quite sure how I did it!
Lots of pushing and squuezing and wiggling seemed to do the trick.
If you look at the picture under step 8, you can see the little wedge shaped piece of plastic that ensures the clip locks in place when it is pushed back on, ie it slides up the wedge until it springs into the lock position. I just played around with the tab whilst pulling at the same time until it came undone.
  • 4 months later...
Dear Andy.
I wish I had seen this before I found out myself how to do it! (Having not believed the owner's handbook which says it's a dealer job). I had even prepared text and pictures to post for others but they don't compare with yours so I've not bothered.
My only complaint with the Octavia is that the headlamps are poor so I've invested in Philips Xtreme + 80% for the dipped beam and some powerful bulbs for the main. Well worth the cost and effort if you use unlit roads at night.
Cool, thanks.
We need a Xenon guide too me thinks, as there are differences and IIRC you HAVE to remove the headlight.
Have a look on VRStu's site - Octavia-vrs.com. There is a guide on there for cars with Xenons which I used as a starting point for this one.
I think he is planning to add this one at some point, so that both options are shown on his site.
Ah, ok thanks again Andy. For some reason I tought Stu's guide was std too.
  • 3 months later...
Would it be okay to change only the dipped beam? I rarely get to use main and when I do it seems okay.
Which is the best replacement bulb for the dipped? Car is 2.0FSI Elegance, non Xenon.
There are various opinions on which are the best replacement bulbs, but I'm leaning towards the Philips X-Treme which were voted by Auto Express as Accessory of the Year 2007 and are completely road legal
They can be purchased from a variety of on-line stores such as Car Bulbs from Power Bulbs - upgrade xenon car bulbs, headlight bulbs, autobulbs and autolamps from Philips, Osram and GE or on ebay.
They are great photos! Do they also show the adjuster for the main beam height? I need to adjust mine down slightly without affecting the dipped beam so want to be sure that I'm turning the correct thing. Is it the white nut shaped thing on the bottom right of the rear of the unit shown? If so can it be reached with the unit in place?
Many thanks, useful info.
Dave
I've just replaced my bulbs and started with the intention of following this guide but then I thought I'd see how far I could get without removing the headlamp units themselves and I managed to do both sides. The drivers side is a bit more trickey as there is an obstruction making access difficult.
Just used your guide to replace my H7 bulbs for the dipped beams tonight, while parked outside my parent's house. Can't wait to drive home to test them out :-) I also went for the Halford's Super Brilliance on 2 for 1 so £20 for hopefully a much improved lighting over the OEMs.
Thanks again for taking the time and effort to make an easy to follow guide.
  • 2 months later...
Just want to say thanks for this guide, really was a big help as i had to replace an H7 bulb today, I also went for the Halford's Super Brilliance on 2 for 1. All i need now is some darkness for testing
Replaced the dip bulbs only with Philips extreme +80%, managed this fairly straight forward without removing headlamp. If headlamp is removed its recommended to get beam alignment checked afterwards.:rolleyes:
Information and technque as presented obviously took a considerable amount of thought and has resulted in a very informative product.
To all Skoda buffs, keep this sort of thing going.
Wacky Gulliver
  • 4 months later...
Phillips Extreme +80% H7 installed this afternoon. Got them for £19 off fleabay!
Was very straightforward thanks to the pics.
Anyone know which hex nut does what for re-aligning?
