BRISKODA.net: The latest VCDS Releases are 11.11.2 and VCDS-Lite 1.1 - BRISKODA.net
  • 3 Pages +
  • 1
  • 2
  • 3
The latest VCDS Releases are 11.11.2 and VCDS-Lite 1.1 Rate Topic: -----
#1 User is offline   DGW
  • PipPipPipPipPipPipPip
  • Group: Honorary
  • Car:2010 FL Octavia 1.8TSI 4X4 Estate
Posted 04 April 2007 - 19:17
As the title says. This sticky will be updated whenever later releases of VCDS and/or VCDS Beta and/or VCDS-Lite are announced.
http://www.ross-tech...ad/current.html
#2 User is offline   VRStu
  • Txt Spk Police
  • Group: Moderators
  • Car:MY11 Audi S3 Sportback S-Tronic
Posted 18 March 2008 - 08:12
The auto update still doesn't seem to work for me under Vista - Anyone else got issues?
#3 User is offline   Uwe@Ross-Tech
  • Briskodian
  • PipPipPip
  • Group: Members
Posted 19 March 2008 - 00:21
Auto-Update works fine on my home machine which runs Vista Business (32-bit), but we did find a machine at the office this evening on which it doesn't work, so we'll be trying to figure out why.
Work-arounds: If it leaves a file called VCUPG.EXE in the folder where you've got the software installed, you can just run that. If that doesn't work, head for the Beta Page and download and install manually.
Sorry for the inconvenience.
-Uwe-
#4 User is offline   VRStu
  • Txt Spk Police
  • Group: Moderators
Posted 19 March 2008 - 08:05
Uwe
I've spoken with Sebastian about this before actually. With VAG-COM it did used to leave the VCUPG file and I used that no problem. Since the latest couple of Beta's with the rebrand I don't get to see the VCUPG file anymore.
#5 User is offline   splinter
  • Briskodian
  • PipPip
  • Group: FREEDOM
  • Car:SUPERB ELEGANCE CR170 DIESEL 4X4 HATCH
Posted 19 March 2008 - 08:33
auto update didn't work for me either (Vista Home Basic)
used manual update.
no problem now
#6 User is offline   Uwe@Ross-Tech
  • Briskodian
  • PipPipPip
  • Group: Members
Posted 19 March 2008 - 23:23
OK, we've figured out that the problem is User Account Control. Automatic Updates work on systems with UAC off, but fail on system with it turned on.
Although I run my home system with that nagging b*tch turned off, I would not recommend this to everyone, so we are looking for a solution.
Please be aware that even if we find a solution tomorrow, it may take an additional update cycle for it to become effective. In other words the next update may not work automatically even if we've found a fix, because the code on your PC which is actually performing the update doesn't have the fix yet.
-Uwe-
#7 User is offline   Hedge
  • TSI powered
  • PipPipPipPipPip
  • Group: FREEDOM
  • Car:;-)
Posted 19 March 2008 - 23:50
Hi Uwe, I have UAC turned on on my laptop and I still got prompted to update this evening after a reboot.
This is with 803 and Vista Home Premium.
Not sure if that helps or not.
#8 User is offline   VRStu
  • Txt Spk Police
  • Group: Moderators
Posted 20 March 2008 - 07:13
I was still getting prompts but when you check the version it has downloaded the file but not actioned it.
#9 User is offline   Hedge
  • TSI powered
  • PipPipPipPipPip
  • Group: FREEDOM
  • Car:;-)
Posted 20 March 2008 - 09:47
Ah. Looking at it now that is what appears to have happened for me.
I'm assuming it would have overwritten the directories for logs and scaling with the new install but they still contain my data.
#10 User is offline   VRStu
  • Txt Spk Police
  • Group: Moderators
Posted 20 March 2008 - 14:05
As Ewe says above if you have the upgrade file in the directory then run that and it will upgrade.
#11 User is offline   Uwe@Ross-Tech
  • Briskodian
  • PipPipPip
  • Group: Members
Posted 20 March 2008 - 17:39
VRStu said:
As Ewe says above
Baaahhh!
This is a Ewe:
http://upload.wikimedia.org/wikipedia/commons/thumb/1/1c/German_ewe_grazing_closeup.jpg/180px-German_ewe_grazing_closeup.jpg
My name starts with a 'U'. :)
-Uwe-
#12 User is offline   Uwe@Ross-Tech
  • Briskodian
  • PipPipPip
  • Group: Members
Posted 20 March 2008 - 18:08
Right, that's be behaviour we have seen here.
We think we've found a solution, but have some more testing to do.
-Uwe-
#13 User is offline   VRStu
  • Txt Spk Police
  • Group: Moderators
Posted 20 March 2008 - 18:36
Uwe@Ross-Tech said:
Baaahhh!
This is a Ewe:
-Uwe-
:rofl::rofl:
Sorry - That'll teach me to write in a hurry. :P
#14 User is offline   VRStu
  • Txt Spk Police
  • Group: Moderators
Posted 14 April 2008 - 15:17
Mine failed to install after the update again - Anyone else?
#15 User is offline   Theresias
  • Briskodian
  • PipPipPipPip
Posted 14 April 2008 - 15:19
Mind elaborating "failed to install"?
#16 User is offline   VRStu
  • Txt Spk Police
  • Group: Moderators
Posted 14 April 2008 - 15:26
Yes sorry Sebastian -
It's been discussed before and I believe Uwe had an idea of the cause but under Vista in some circumstances the update doesn't initialise and install following download so you have to manually run it from th Ross-Tech folder.
#17 User is offline   Theresias
  • Briskodian
  • PipPipPipPip
Posted 14 April 2008 - 15:31
Ah, you mean 803.3 found it but didn't start the installation? That has been fixed in 803.4 but since the "existing" version is starting the update from 803.3 to 803.4 the problem is still there. As of 803.4 updating to future versions should work.
#18 User is offline   VRStu
  • Txt Spk Police
  • Group: Moderators
Posted 14 April 2008 - 15:33
Good news - Look forward to it then.
#19 User is offline   DGW
  • Group: Honorary
Posted 14 April 2008 - 18:44
My laptop running XP Pro SP2 was offered an update to 803.4 at the same time that XP decided to update then reboot. After the reboot there was no further prompt to update to 803.4 so I launched 803.3 and tried via the Options button and check for releases and beta updates. The server reports no update is available at this time. Do I need to download 803.4 from Ross-Tech or will an update be offered tomorrow, ie is the check for version carried out once a day on first switching on?
#20 User is offline   sms
  • 2.0 FSI Sport.
  • Group: Members
  • Car:Mk2 Octy Sport
Posted 14 April 2008 - 19:45
my vista gave me a pop up to say a new version is available do i want to install and i said yes, havent had time to see if its actually running yet.
Share this topic:
  • 3 Pages +
  • 1
  • 2
  • 3
Fast Reply
Loading
