Just got VAG-COM and have the following errors
Address 01: Engine Labels: 038-906-019-130.LBL
Part No: 038 906 019 LA
Component: 1,9l R4 EDC 0000SG 5405
Coding: 00102
Shop #: WSC 13765
1 Fault Found:
17911 - Load Signal from Alternator Term. DF: Implausible Signal
P1503 - 35-10 - - - Intermittent
Readiness: 0 0 0 0 0
Address 08: Auto HVAC Labels: None
Part No: 6Y0 820 045
Component: Klimaanlage X0840
1 Fault Found:
01596 - Motor for Outside/Recirculated Air Flap (V154)
30-10 - Open or Short to Plus - Intermittent
Address 09: Cent. Elect. Labels: None
Part No: 6Q1 937 049 D
Component: 0000 BN-SG. 1S34
Coding: 25754
Shop #: WSC 13765
1 Fault Found:
01117 - Generator Terminal DF Load Signal
27-00 - Implausible Signal
When you turn your ignition on do you get a battery light come up?
Nope.....oh thanks for removing my chassis number from my original post :thumbup:
Thats your alternator issue then, they alternator has a link to the engine ECU and dash, this has gone down.
First place to check is the connector in front of the gearbox for correded/broken connections. If all that checks out ok then it could be a faulty alternator.
Kool....thanks for the help Lummox. I haven't had any issues with the battery not recharging or anything though but will check it out.
I would check the charge rate, if the light isn coming on then it isnt charging. You may find the battery will die in the not too distant future.
Now VAG-COM doesn't seem to want to work ....anybody any idea what appears to be the problem? Not sure why it's saying the CAN is not ready
The fabia isnt can , works on the k line so it shouldnt be ready
Hmmm well nothing is working...autoscan etc. I have the ignition on.
Got it working again, don't know what was going on. Had some fun last night testing my 0-100kph, best I could achieve was 9.1seconds (on a private runway of course :D) but I know I can improve that as I didn't get the perfect start and could improve my gear change a bit.
Just seen your post, I still have your disk :o, give me a shout next time your out my way :thumbup:
Yeh no bother I should be back home over the bank holiday weekend, will give you a shout then :D
