Vagcom needed to adjust idle
Hi could do with a little help to raise my idle speed (and the car's, LOL)
I pm'd a few briskodians close to me (via the "map") but they just haven't been active on here for a while so I'm asking a bit further afield now.
I'm in north derbyshire and dont mind a bit of a journey if someone can help.
VK
VK
Hi VK
I am in Glossop, How far are you away?
Radiotwo
Hi VK
Radiotwo
I'm just round the hill, New Mills.
Assuming you can help I can make it anytime except this sunday afternoon (mother's 60th birthday)
VK :thumbup:
VK :thumbup:
Hi Again
Yes I do have a lead, will have to get it from my son, but he lives in Hadfield.
I have only just got the cable, so hope you know what to do !!!
Saturday sounds a good day !!
Radiotwo.
Hi Again
Radiotwo.
Saturday good for me too (I'll PM you)
All I know is you find it in adaption channels?
Lummox posted that there was a thread on it so I'll try find it and I have now! Info now copied down and ready to go!!
Thanks again
VK
Had the car hooked up to Vagcom today and tried to use the info in Roo's sticky post.
Instead of finding values between 124 and 132 we found a value of 32768! = 840r/min
Entering a value of 124 resulted in a drop to 750 r/min
Entering 132 did nothing and would not allow to be saved anyway
After experimenting with a few values we got the revs upto 882 r/min with a value of 32800
Was hoping to get them up to around 1000 r/min, anyone help?
Should I join Freedom and ask a tech? (silly question)
VK
Adaptation channels can have different value ranges this is where the difference between 127/32768 comes from. Adjusting the idle speed is natively a (sorry to say that) dumb idea, because it doesn't fix a problem it only hides it. As you experienced there is only a limited range of possible values and there is no way around this.
My suggestion would be to start from scratch...
Why did you want to alter the idle speed? Any problems with the car?
What is the part number and software version of your engine control module?
Natively? Did you mean naievely?
As for the values what's the point in having a Sticky thread that, clearly, doesn't work for my car?
In my case, raising the idle speed isn't a dumb idea because I have fitted polyurethane dogbone mount that has resulted in bad vibes at my current idle speed, unless I have a particularly rough idle? How would I check this?
A little pressure on the throttle to raise the revs to 1000 r/min and everything's sweet.
Of course if I go back to standard then I have no problem.
Any more suggestions? Anyone?
