Octy II Fire extinguisher - How to.
Right well since our lovely Belgian friends make great chocolate I decided I'd be going there for a few days over Christmas. They also however require a car to have a fire extinguisher in reach of the driver.
Since I didn't fancy taking chunks out of the car or having it go off with the thing rolling about in the foot well and also didn't want to leave holes I set to with the Skoda extinguisher and brackets. I'm fairly certain the ones for the Fabia/Roomster that mount under the seat are pretty much the same.
The bracket can mount under either of the front seats, so I put mine under the drivers seat, meaning I could retain the storage bin on the other side.
(Thus giving me somewhere to store the required high vis jacket :rolleyes:)
So anyway you will need the following parts for an octy II:
- 10mm spanner
- torx driver set
- M10 spline tool
- Small screwdriver
- Skoda Extinguisher P/Number : GCA000001 (Approx cost £30 from dealer)
- Skoda Extinguisher Bracket P/Number : GCA600001 (Approx cost £5 from dealer)
To make life easier you will also want a torch and detailers will want their hoover handy to clean around the seat ;)
You do not need a power drill, even though the Skoda instructions kind of imply you do.
The bits should look approximately like the items shown in the attached images
Disclaimer: Everything shown in this how to is based on the experience of members here and is carried out at your own risk. I or briskoda.net are not liable for any problems, injuries or costs arising from the use of this how to.
18203.attach
18204.attach
First thing to do is to disconnect the negative lead of the battery using a 10mm spanner.
This step is incredibly important and failure to do this could result in serious injury or even death.
I placed the negative lead in a small plastic sandwich bag and made sure it was placed in a position such that it could not touch any metalwork or either of the battery connections.
Once done, the next step is to disconnect the airbag and seatbelt wiring from the seat.
If you look at the front of the seat (on the door side) you will see a small black plastic cover approximately 2" wide and 4" long. Press the lever catches on either side of this and pull it out.
In here you will see the airbag wiring connector (yellow) and the seatbelt warning wiring (2 pin black). (See attached images)
Carefully detach these connectors by pressing the locking tabs on the connectors and move the cabling out of harms way.
Next undo the 4 M10 spline bolts that hold the seat rails in place, there is 1 in each seat corner (can be seen in the attached image), and gently tip the seat slightly backwards.
With the front of the seat in the air you can now see a clip that holds the wiring in place. Gently push a screwdriver into either side of this clip to release it and pull the connector upwards taking car not to damage the wiring.
Depending on how you wish to work you can now either tip the seat backwards and work in the car, or remove the seat from the car and find somewhere warm to go and work.
With it being cold and getting dark, there are no prizes for guessing which option I took and if you do this it makes life easier if you remove the head rest and slide the seat forward on the runners before you take it out.
18205.attach
18208.attach
Now you have your seat up and can expose the base of it the first thing to do is to undo the two screws that hold the plastic trim at the front in place (see attached image).
For this you will need a torx screwdriver set.
Once this these screws are out you will now see that the plastic trim is held in by two clips on the door side going into the other trim piece.(See attachment) Much as i tried to get these out I couldn't so took to them with a Jnr Hacksaw and cut the clips off so freeing the trim and then pulled the clips out from the other side.
If you have to cut the clips take care not to damage the piece of trim that will remain on the seat.
18209.attach
18210.attach
18211.attach
Once this piece of trim is off you will need to place in the two white plastic screw clips at the front of the seat base and slide over the two black metal screw clips towards the rear of the seat.
The holes for these are already in the metal seat base and they should just push the foam out of the way.
To determine which holes you need offer up the bracket and note the holes it lines up with.
If you find the black spring type holders hard to get in open them up very slightly first using a screwdriver and slide them in the square hole and push upwards such that the screw hole on the clip aligns with the circular hole in the seat base.
Once the clips are in again offer up the bracket and screw it into the newly installed screw clips. I found this easiest to work from the side where you have the seat rail slider control at the rear of the seat and then to do up the other rear screw. Once these two are securely attached you may find the bracket needs slight adjusting to line up with the other screw holes, so do this and then screw in the final two screws.
The location of the four screws and the final installed seat bracket can be seen in the attached images.
18216.attach
18217.attach
Once the seat bracket is attached to the seat the next step is to attach the extinguisher bracket to the seat bracket.
To do this offer the extinguisher bracket up to the two holes on the seat bracket, using the `long` holes on the extinguisher bracket not just the circular holes.
Use the black screws and washers, making sure the recess in the washer is on the screw head side, to attach the two brackets together.
The holes and screws in question can be seen in the attached images.
Once you have the bracket installed test to make sure the fire extinguisher fits.
The trigger should sit behind the remaining plastic trim so that it can not be accidentally kicked etc. (See attached image of extinguisher in place)
If the extinguisher fits correctly, remove the extinguisher and place it to one side.
18219.attach
18220.attach
18221.attach
The next step is to take the seat and place it back into the car (or just back up if you did it in the car).
Once you have the seat back in the car line the seat rails up correctly using the locating tabs on side of the seat by the exhaust tunnel.
When doing this take care to make sure the small piece of plastic that protects the carpet from the runner slides into the locating hole on the plastic at the front of the seat trim.
Failure to locate this piece of trim correctly will mean the seat does not line up with the bolt hole by this piece of trim.
Once the seat is located, place the two rear bolts in part way and then from the front of the seat push the airbag cable clip back into it's locating hole and tuck the connectors out of the way in the hole. Next attach the two front bolts, making sure that all 4 bolts have the washers attached, are correctly tightened and the seat does not move around at all.
Next reconnect the airbag and seat belt wiring taking care to double check that the connectors are correctly attached. Failure to carry out this step will result in the airbag light coming on and VAGCOM or a dealer visit to clear the fault.
Once the wiring is reconnected place the plastic cover back over the hole.
Reattach the battery and take the car for a short drive.
You will notice that the Power Steering light stays on (amber). This light should go out after a short drive and if it stays illuminated you should seek professional diagnosis.
Now you are happy with your car reattach the extinguisher to the bracket and make sure the clips are securely done up.
It is also worth making sure that the clips are in a position where you can release them quickly should you need to.
Stand back and marvel at your quite well hidden work (attached pic)
18218.attach
  • 3 months later...
Nice guide this Mark, and great for those who wish to travel on the continent. :)
might have to check this out as well then I guess :(
Got a high vis jacket, two of those lovely warning triangles, emergency hammer/seatbelt cutter as it is, suppose I'll have to drop this in as well then :rofl: - good thing I've got an estate ;)
  • 7 months later...
Well as an update to address the concerns of some people.
This has now been fitted for a while and there is no sign of any issue with the clips and belts holding it all in. It's also not causing any noises so all good :)
  • 3 months later...
Can I assume this will fit on an Octy II electric drivers seat? I also don't want to cover my storage compartment.
No Idea, it depends how much space the motors for the seat take up.
Probably worth asking your dealer if this fits your car as you'll need to order at least some of the parts from them any way.
  • 4 months later...
That is more complicated than I thought. Think I'll leave mine in the boot. I fitted one to my old Passat B5.5 but just used self tappers through the plastic trim and no dismantling was needed.And it did not rattle either.
Leaving it in the boot is fine in certain circumstances, but in the countries where they are required or recommended there is often a requirement that they are within reach of the driver.
  • 6 months later...
Tried to buy an Extinguisher from Caffyns Skoda in Tonbridge. They accepted my order without comment but will not allow me to take possession of the goods because "Skoda wont let them", because the parts concerned are "Dangerous" and need to be installed by them for £55. Good job I didnt pay up front. ;(
A quick fix, to maintain the legalities, is to buy a smaller 500g powder extinguisher. I've wrapped mine in a red microfibre duster and it fits snuggly in the drivers door pocket.
Odd, my dealer had no issue selling it to me.
Bearing in mind you can go and buy a fire extinguisher from any old motoring shop and take it away, I can only conclude they fancied some work.
My dealer supplied me with an extinguisher without any problem.
P.
i bought a powder one from argos for 12 quid and was just planning on attaching it to the throttle foot rest with a couple of small self tappers ... i've seen taxi drivers do this and it looks ok.
Maybe I'm missing something, but if that comes out for some reason, then it would be rolling around directly under your pedals. That seems a touch dangerous to me.
Is the argos one small enough to fit there as the skoda one certainly isn't/
oh i see what you're saying, and obviously if it were to break free it's going to become a huge issue, but the holder seems pretty good, and size wise it indeed looks like it could fit comfortably.
it was too dark to get a pic of the extinguisher in situ, but here's one that didn't require me crawling around the floorpan of my skoda at 11.20pm on a cold, wet wednesday night :)
please note that the item beside the extinguisher is purely to impart scale :p
Feck the extinguisher, give up driving and drink the bush mills. Use the money saved to replace said bush mills :)
The holder for the under seat one has a metal clip at the top and plate at the bottom then a couple of straps. Maybe it's worth putting a velcro strap or something around it so it can't come free.
that sounds doable :) unfortunately i have this little 2000 mile trip around france in july to do and i kind of need the fire extinguisher, if only to let off at my kids when they start making my head hurt with the constant "are we there yet / i'm bored / i need a pee / i'm hungry / i'm thirsty / he wont give me my..." .... well you get the drift :) i actually do have a roll of velcro for tying up cables which i could secure below the bracket if it's going in the footwell .... i could also look at mounting it under the seat somehow maybe with some large cable ties .... who knows, but where there's a will, there's a way... or more precisely, where there's a telecoms engineer, theres a daft, ugly but entirely workable way :)
and as for the bushmills .... there's ALWAYS a bottle of 10yo single malt in my house, sometimes several ... why do you think i cant afford one of these fancy VRS's like you blokes can ? :p
I don't have a vRS thank you very much :p
What about mounting it through the carpet in the passenger footwell?
As I sais above my worry would be it getting in the way or coming lose. That plus it's not exactly accessible and would get in the way of the bonnet release located near there.
no vRS ? apologies, i stand corrected :) a large proportion of the threads in here seem to be vRS related so i thought most of the regular posters were part of that happy club that i can only stand outside the window and stare forlornly at :D
i took a couple of pics to show you what i meant ... it actually looks fairly neat, tho i did have a gander under the seat, and if there was some way of fixing it to the underside of the seat tray i'd be game to give that a go ..... as long as it doesn't involve spending money, because that's against my religion :p
and here's a place that could have been designed for it :
Edited by martzweb
