39,362 Members 1,486,359 Posts
Topping up Engine Oil
This is a discussion on Topping up Engine Oil within the General Car Chat forums, part of the Members Area category; I know I should check my oil level regularly, and top up when required, but in reality I tend to ...
Go Back   BRISKODA - The Skoda Forums > Members Area > General Car Chat
View Poll Results: What was the reason for your last engine oil top-up?
I checked the dip-stick and it needed more oil 59 89.39%
The oil level warning light came on 7 10.61%
Voters: 66. You may not vote on this poll
LinkBack Thread Tools Display Modes
Old 27-02-2008, 00:47   #1
andy2407's Avatar
Members Car: Yellow Fabia vRS
I know I should check my oil level regularly, and top up when required, but in reality I tend to rely on the dash warning light coming on as a reminder.
So what was the reason for your last top-up?
Edit: I've done a public poll, just to see who else is lazy like me!
The future's bright
The future's mellow
Now with a little zest of Washbrook added
andy2407 is offline
Old 27-02-2008, 01:18   #2
anewman's Avatar
Images: 1
Re: Topping up Engine Oil
The oil light on my instrument panel doesn't turn on when cranking, replaced the bulb so suspect it doesn't work. Didn't come on after oil and filter change neither. Going to swap the instrument panel soon anyway due to faulty mileometer. I guess on the older cars like mine it's more important to check the dip stick every-so-often.
94 Favorit GLXIe Estate
Briskoda "Banger" social group
anewman is online now
Old 27-02-2008, 01:25   #3
cheezemonkhai's Avatar
Members Car:
I do a high enough mileage with a lot of motorway miles so it pays to keep an eye on it as pulling back out from the hard shoulder isn't my idea of fun.
cheezemonkhai is offline
Old 27-02-2008, 08:41   #4
Members Car: Octavia 2.0 DSG
If i could read the damn dipstick..........black shiny plastic dipstick, black shiny oil.......the design team must have been having a tea break.
timjfw is offline
Old 27-02-2008, 14:10   #5
KenONeill's Avatar
Members Car: Octavia TDi110
The last time I had to top up oil it was on a car with a loose rocker cover! So I knew (from the loose rocker cover) that it needed some oil. I have never owned one of these cars that needs regular top-ups between annual services.
KenONeill is offline
Old 27-02-2008, 14:33   #6
musky's Avatar
Members Car: MK1 Octavia 4x4
Never put any oil in since new - now on 47k. Big improvement on my old Sierra 4x4, used to have to fill up engine, gearbox, and transfer box once every month! Oil everywhere
musky is offline
Old 27-02-2008, 14:33   #7
philje123's Avatar
Last time i had to top-up my oil was shortly after the last C&F meet... must have burnt off a fair bit that day somehow!
96 Felicia Laurin & Klement 1.3 spi Hatchback called Nelly
philje123 is offline
Old 27-02-2008, 16:57   #8
ScoobyChris's Avatar
Members Car: Fiat Panda
Never owned a car where I've needed to add oil, but isn't the light on the dash an oil pressure light rather than an oil level light and by the time the pressure is low enough to trigger that you need to stop the engine ASAP and then add some oil there and then?
Chris
ScoobyChris is offline
Old 27-02-2008, 17:45   #9
KenONeill's Avatar
I thought the Octy used it dual purpose; level on switch on, and pressure when running?
Old 27-02-2008, 18:32   #10
dstev2000's Avatar
I wait for the AMBER oil warning light to appear and as soon as it does, the oil goes in. I keep a 1 litre bottle of 507.00 in the rear door pocket.
As far as Skodas are concerned;
Amber = Oil level is getting low, top up or open the bonnet to clear it for 100 miles
Red = Pretty obvious - low oil pressure, pull over and kill engine immediately before it eats itself
So yes, I am a lazy b-stard who relies on the 'electronic dipstick' and not that crap orange handled thing under the bonnet.
MY08 L&K: Black-Estate-Diesel-Sunset Glass-MFD2-W8 Interior light-Colour coded door strips-LED sidelights and Puddle lights-VAG-COM fettled-Lovely!
SWMBO's: MY08
vRS TDI - Standard
dstev2000 is offline
Old 27-02-2008, 19:07   #11
I parked up 1st
ric04vrs's Avatar
Members Car: silver Fabia VRS
very rarely do i ever need to top up the oil , as it is never in the engine long enough , oil change every 2.5k miles , bit overdue at present though (500 miles)
not so bored now
ric04vrs is offline
Old 28-02-2008, 00:05   #12
Vix
Vix's Avatar
Members Car: Fabia VRS
I check my oil every week, just to be on the safe side
Vix is offline
Old 28-02-2008, 00:09   #13
Nuts
anonymouse's Avatar
Members Car: Fabia vRS
Coowee
Am guilty of not checking as often as I should. Used to be weekly when my living depended on it.
Now probably every 2nd or 3rd week - was surprised one time because the level had dropped to the 'low' mark so, since then, have checked more frequently.
"Stupidity, if left untreated, is self-correcting." - Heinlein
anonymouse is offline
Old 28-02-2008, 00:31   #14
Ho Ho Ho
Conshine's Avatar
Members Car: Silver Fabia vRS
Chris
I thought it was like the Audi's where the light will come on amber if the level gets low and red if the pressure is down?
It came on on my cousins A3 on the motorway so we pulled in and topped it up.
I put about 500mm per 10,000 miles since about 40,000 miles.
Diesels will tend to use oir during their lifetime.
Ben
Ben
Conshine is offline
Old 28-02-2008, 00:34   #15
Ho Ho Ho
Conshine's Avatar
Does the Fabia have an amber warning for level as the engine is the same as the octy or is it a software thing again?
Ben
Ben
Conshine is offline
Old 28-02-2008, 01:19   #16
charles's Avatar
Members Car: Octavia vRS Mk2
can't understand why there isn't an 'oil gauge' like a petrol gauge fitted in cars rather than just a low pressure warning light! That way you be able tell easily if the engine required oil..
Perhaps its not possible to this?
charles is offline
Old 28-02-2008, 01:20   #17
rider of sharks
sharkrider's Avatar
I have only ever checked the oil, due to the fact that the EU (even tho I never voted for any of them) made us include it in the drivng test.... have never had a warning light on, have never needed to top up, 80k in the fabia vRS (50k with cheap resistor mod) , and 34k so far in the fiat... never seem to loose oil, I think its due to running it in properly, i.e driving it normally, and not babying it....
Fiat Grande Punto Sporting (158 bhp 314 lbs/ft) in Red....
Furby vRS , black magic,passenger airbag de-activation switch, (now gone, but not forgotten!)
sharkrider is offline
Old 28-02-2008, 01:29   #18
anewman's Avatar
Images: 1
Hmmm is that saying what I think it's saying?
Old 28-02-2008, 01:34   #19
Nuts
anonymouse's Avatar
Dunno, but if you wear a red hair net all your problems seem to disappear
The Following User Says Thank You to anonymouse For This Useful Post:
sharkrider (28-02-2008)
Old 28-02-2008, 02:18   #20
KTP
eeeeeeeeevil.
KTP's Avatar
Members Car:
i havent checked mine yet, should really do it, covered 10k so far in the 7months of having the car, but the light has never came on so it cant be that bad yet.
KTP is offline
Old 28-02-2008, 02:28   #21
I'm back...
Mr Grumpy's Avatar
Members Car: Office chair.....
I check my oil and washer fluid once a week, it only takes 2 minutes, so what's the big deal?
Tyre pressures get checked when I top up with fuel if it's not raining.
I sometimes check my tyre pressures if ( like today ) I seem to encounter road planing everywhere, with 'ramps' and raised manholes, which can slightly deflate tyres if encountered unexpectedly ( when going the nsl in the dark, with no bloody warning signs )
S50 VRS Number Plate for sale..ffs someone must want it....
Mr Grumpy is offline
Old 28-02-2008, 03:16   #22
It's all good
Decron's Avatar
Members Car: Vroomster
I check at least once a week, but that could be every 1000 miles. I did 57k in the Fabia and it never needed topping up once. My Golf needed a top up twice in 120k.
Our Punto has a oil level indicator which is displayed when you start the engine. That hasn't needed any oil top ups in the two years we have had it either.
Tyres get check weekly on both cars as does the washer fluid.
Decron is offline
Old 28-02-2008, 09:16   #23
KenONeill's Avatar
Charles, the "Oil level gauge" sounds like a good idea, but where would you set it to? The only time you can get a true reading using the "required contents" method on a wet sump car (almost everything except "supercars") is with an engine that's not been running for at least an hour, when parked on level ground.
Mr G, what's the point in checking every week, when, barring leaks, you know that you'd use more oil checking the level weekly than you'd otherwise lose between services?
Old 28-02-2008, 16:18   #24
rider of sharks
sharkrider's Avatar
yeah my GP has the oil level check when you start up hasn't needed any yet either...
I always check the tyres... visual check every time I get in the car, pressure check every weekend, or before a long run... (meet ect)
Old 28-02-2008, 16:22   #25
Skoda Junkie!
Skodaboy1983's Avatar
Members Car: Skoda Fabia VRS 130
I've check the oil everytime I clean the car but no real issues with it.
My last car a focus had to be topped up with oil at least three times in the year and a half I owned it, the first time I topped it up was a routine check after a couple of days of it being serviced to find the dealer had not topped the oil up.
Always been into a habit of checking the oil on all of my cars on a 2 weekly basis.
Skodaboy1983 is offline
