This is a discussion on Back of the bus... within the ICE, Security and Insurance forums, part of the General Motoring Discussions category; Remember when you were on the bus and your walkman (or walkcoffin) used to pick up the engine note, the ...
| Site owner Join Date: Oct 2002 Location: Hill & Mountains of North Wales
Images: 3 Thanks: 24
| Back of the bus... Remember when you were on the bus and your walkman (or walkcoffin) used to pick up the engine note, the interference from the alternator or whatever... ...well it's back ![]() Although this time using different technology. I have an aux device (battery powered) feeding into the stero, all is fine at this point. Now if I connect a interface (powered from car ciggy lighter) to allow me to forward and cycle tracks etc I pick up the hum as described above. So this is a 12v device, connecting to the battery device (which is fine) instantly adds hum(at engine pitch) to audio. Any ideas for fixing? Inline supressor of <insert capacitor size> on one of the lines? Earthing, it's plastic so thats a no go. Rip it all out and sell on Ebay buy RX8. Thoughts?
__________________ ColinD - 97/100 Limited Edition Octavia vRS < For Sale £3000 www.BRISKODA.net :: Site Owner. E-Mail : webmaster at briskoda dot net Got a comment to make about the site? Please feel free to use the feedback form here, we welcome your views. |
| Briskodian Join Date: Sep 2003
| Is it a constant pitch hum, or does it increase with revs? If constant, I'd recomment sticking a 'scope across the (input? output?, hmmm) and matching a capacitor. If it varies, then you might end up with quite a complicated bandpass filter ![]()
__________________ Si |
| arh bugger...It's variable. Looking up our old haynes manuals I could whack a cap over the alternator, but you know what, I don't think I dare on these things. Nothing inline on the powersupply to help?
| or I finally decided to try and ground the ground of my audio out. That did the trick. Don't understand it really, but it sounds great! Next question...yipee, how do I do that?
| Also am I right in thinking DC connectors now default to a standard negative earthing and / or that negative earth is the outer sheath of any plug connector...got a cunning plan :S
| | #7 | |
| Briskodian Join Date: Dec 2003 Location: south staffs
| Quote:
In very basic terms, the hum was caused by you injecting electrical “noise” into the stereo from the ciggy supply and / or the wires were acting as an aerial picking up electric fields inside the vehicle (from all of those ECUs and the like). Adding the ground connection referenced your “aux device” to the vehicle ground giving a path for the “noise” to go to ground. Quinten, a ground loop is where there is a path (intentional or not) for electrical current (noise) to flow via the grounding into a sensitive piece of equipment eg car stereo. The result is audible noise. For more detailed info, do a search on “groundloops”.
__________________ BFN, Andrew ___________________________________________ Octy II - 4X4 TDI (leather, cruise & 16" alloys) | |
| Jabba sports dp/cat and cat back system for Furby RS | SkodiRS | JabbaSport | 13 | 21-03-2004 22:41 |
| Its BACK!!!!! | ecklad | General Car Chat | 2 | 10-03-2004 14:37 |
| Anyone had one of these?? It's back | Pythix | Off Topic and Chit Chat | 29 | 12-02-2004 10:35 |
| I'm Back But Having Car Troubles | GAFF | Maintenance & Performance | 10 | 09-08-2003 12:32 |
| Back from The Nurburgring | mannyo | General Car Chat | 6 | 25-03-2003 11:39 |
