Octavia MK1 Wiring Loom
This is a discussion on Octavia MK1 Wiring Loom within the ICE, Security and Insurance forums, part of the General Motoring Discussions category; Does that look about right? Caraudioentertainment.co.uk – Car audio and in car entertainment. - Fitting Accessories :: Skoda :: PC2-69-4...
Go Back   BRISKODA - The Skoda Forums > General Motoring Discussions > ICE, Security and Insurance
Old 08-07-2008, 09:02   #1
Funkoid's Avatar
Default Octavia MK1 Wiring Loom
Funkoid is offline
Old 08-07-2008, 10:50   #2
cheezemonkhai's Avatar
Default Re: Octavia MK1 Wiring Loom
Don't bother.
Just swap the red and yellow in your new head unit wiring loom and then disconnect the wire that goes to the powered aerial feed (blue one) as otherwise this will put power down the K line (Bad).
You will also need a device to send power to the aerial amplifier in the base of the aerial, but a search on here should give you all the details you need.
HTH
cheezemonkhai is offline
Old 08-07-2008, 12:28   #3
Funkoid's Avatar
I'd much prefer to spend a tenner to ensure i don't fry the electrics!
I hadn't heard about the Arial issue though?
Funkoid is offline
Old 08-07-2008, 12:39   #4
Dr Zoidberg's Avatar
Yep.
There's an amplifier in the aerial base that needs a power feed.
Normally it gets it from the factory fit head unit , but not from an aftermarket one so you need an adaptor to do this.
Without you'll get poor FM reception and no MW at all
I've got one you can have for £4 posted.
Alex
www.drzoidberg.co.uk
Dr Zoidberg is offline
Old 08-07-2008, 12:57   #5
Funkoid's Avatar
£3.50 and you've got a deal
Funkoid is offline
Old 08-07-2008, 18:46   #6
Funkoid's Avatar
Originally Posted by cheezemonkhai View Post
Don't bother.
HTH
Thanks HTH, when you say disconnect the blue wire do you mean from the new loom that comes with the new head unit or from the cars blue line feed?
I'm getting the aerial adapter off Dr Zoidberg which appears to have a blue wire attached to it (presumably for the fm amp?)
So to recap....
SWAP the red and yellow around on the new loom fresh from the pioneer box!
Disconnect the blue cable from the loom fresh from the pioneer box!
Connect the aerials blue cable to the loom fresh from the pioneer box (presumably to the connection we've disconnected in the previous step?)
EDIT ----->
I've bottled not getting an adapter now... better safe than sorry etc I'm seriously confused though!
As I’ve already said I have an mk1 Octavia vRS which is actually on a 55 plate (I think the fact it’s an mk1 from later 2005 is causing the confusion).
Am I correct in thinking this wiring loom is correct?
SKODA OCTAVIA FABIA PC2-69-4 CAR RADIO WIRING LOOM on eBay, also, Terminals Cabling, In-Car Entertainment GPS, Cars, Parts Vehicles (end time 26-Jul-08 11:12:37 BST)
what has confused me even more is the fact that the seller has provided this info...?
hi according to the list the loom for that vehicle should be iso the same as the vw range the loom, the year change from pc2-69-4 (98-) and the pc2-75-4 (02-) hope this helps
.... So according to them I need the pc2754 as seen here...
SKODA OCTAVIA SUPERB PC2-75-4 CAR RADIO WIRING LOOM on eBay, also, Terminals Cabling, In-Car Entertainment GPS, Cars, Parts Vehicles (end time 09-Jul-08 10:18:34 BST)
In the 2nd one though it doesn't look like the blue cable is disconnected, do you have to do this regardless of whether you buy an adaptor or not? To confuse matters more
the PC2-69-4 was the right way to go?!
I don't want to go blowing anything up
I'm starting to think I may just fork out to get it fitted somewhere! I've already bought the unit now though !!
Funkoid is offline
Old 10-07-2008, 19:40   #7
G-slave's Avatar
I have to say I am getting confused too now, only 3 cable to sort out, yet I can't wrap my head around this.
How hard can it be ffs
(and what exactly is meant with "You will also need a device to send power to the aerial amplifier in the base of the aerial")
G-slave is offline
Old 11-07-2008, 18:45   #8
Dan Walton's Avatar
Please don't waste your money on a wring harness!
There is nothing scary about doing this. Your new headunit will have bullet connectors on the red and yellow cables so that they can be swapped. See, even the headunit wnats you to do it yourself! Then, all you need to do is disconnect the blue wire that is labelled up power antenna or something. Just cut it on you're new stereos loom so as to preserve your cars wiring.
I didn't use an ariel booster, mine worked fine without. I've now done the same in my new Golf and again, haven't needed a booster. DIY, it's not hard, honestly.
J'ai douze ans!!
Dan Walton is offline
Old 12-07-2008, 12:03   #9
Funkoid's Avatar
Cheers Dan
The new wiring loom that has come with the HU only has the blue(white) connection to the HU end, not the car end so it should be fine... in fact its just like this one (bar the inline fuses etc)
http://images.andale.com/f2/120/119/...6/PC2_69_4.jpg
Funkoid is offline
Old 13-07-2008, 08:54   #10
Dan Walton's Avatar
Umm, just make sure that you're not confusing that with the remote turn on that you would use for an amp. Often they will come as a wire that is not connected into the ISO block. I'm pretty sure the wire you need to check will be blue, possibly with a white stripe and maybe go into pin 4 of the ISO plug...
J'ai douze ans!!
Old 13-07-2008, 11:40   #11
Funkoid's Avatar
Well its all in now and seems to be working perfectly although you've worried me about this blue one again!
There wasn't any single blue wire coming from the loom, just a blue and white one from either end of the head unit loom. Both had bullet connectors and weren't connected.
Funkoid is offline
Old 14-07-2008, 20:31   #12
Dan Walton's Avatar
Well, hopefully all is okay. Problems that might arise from K Wire problems I think will involve your central locking and electric windows playing up etc. or, blowing up someones VAGCOM when they connect it up!
J'ai douze ans!!
Old 15-07-2008, 12:09   #13
Stu's site has this:
Fabia-vrs.com - Mobile Phone Car kit Integration
On the black block of 8 (ISO connector), the one you want to leave not connected is Pin 3, which is the `Self Diagnosis - K wire`
Full details are on Stu's site at the link I posted above.
Obvious disclaimer that you do all this at your own risk etc etc.
Old 15-07-2008, 13:48   #14
bubba's Avatar
My Wife has bought me an Alpine unit for my birthday tomorrow, so if all goes well using the instructions here, I shouldn't blow my electrics
Neil
Silver MkI Octavia VRS
bubba is offline
Old 12-08-2008, 22:16   #15
G-slave's Avatar
coming from your HU you will find big red and big yellow, on bullet connectors. Swap'em!
coming from your HU you will find A blue/white, which is the remote switch or antenna or P-remote: this cable passes a +12V to your antenna or Amp, when the HU is switched on.
The Wiring loom on Octavia's have this wire going in on the K-wire, so it is important you do not 'pass down' that power. (however you do this, do not allow connection, and make sure it doesn't touch any grounded part of your car.... experience has told me this tends to fry the HU cough cough
G-slave is offline
Old 12-08-2008, 22:17   #16
G-slave's Avatar
my money is on both...
G-slave is offline
Old 12-08-2008, 22:18   #17
G-slave's Avatar
Last edited by G-slave; 12-08-2008 at 22:21. Reason: got carried away with the posting, apologies
G-slave is offline
Old 13-08-2008, 18:49   #18
Funkoid's Avatar
The only changes i had to make to my pioneer deh-p700bt was to swap the bullet connectors for the red and yellow wires. All blue wires were already disconnected. So far i haven't had any issues with windows etc.
edit: i presume if i was going to have issues i would have seen some by now (a month or so after installation)
Funkoid is offline
Old 15-08-2008, 11:29   #19
bubba's Avatar
Mines been in for a month. I swapped the wires around, but then had to by an amplifier for the FM radio (still not perfect reception though)
Neil
bubba is offline
