39,447 Members 1,489,435 Posts
Sat Nav VAG OEM
This is a discussion on Sat Nav VAG OEM within the ICE, Security and Insurance forums, part of the General Motoring Discussions category; Been looking on ebay at oem vag sat nav stuff. http://cgi.ebay.co.uk/ws/eBayISAPI.d...772143704&rd=1 Just out of interest how easy/hard would it be ...
Go Back   BRISKODA - The Skoda Forums > General Motoring Discussions > ICE, Security and Insurance
Old 04-05-2005, 15:01   #1
faboka vrs's Avatar
Sat Nav VAG OEM
Just out of interest how easy/hard would it be to install one of these. Would it be a simple plug n play? Would Vag-com be needed? Where about do you put the GPS thingy?
Thanks in advanced
John
2004 Skoda Fabia vRS - Xenons - Heated Seats - Cruise Control - Passenger Airbag Deactivation switch - Side Airbags
faboka vrs is offline
Old 04-05-2005, 15:09   #2
EddyH's Avatar
Members Car: Audi S8
It's plug and play in the Octavia so can't see the fabia been much different.
GPS aerial is magnetic and goes behind the dash on the metal tubular rail either behind the glovebox or clocks.
Great bit of kit.
EddyH
Audi A6 Avant 2.7 TDI
Audi A3 2.0 TDI Sport
EddyH is offline
Old 04-05-2005, 16:08   #3
jimnpaula's Avatar
Members Car: 02 Yellow Octavia vRS
Is a new centre console required or is it simply a case of removing the tray beneath the stereo in order to fit one of these?
James
James & Paula
jimnpaula is offline
Old 04-05-2005, 16:13   #4
EddyH's Avatar
James
In the Octavia you just remove the standard stereo and the plastic tray. Slots straight in then, helps to take the glovebox off so the wiring can be fed through easily from behind.
EddyH
EddyH is offline
Old 04-05-2005, 16:26   #5
faboka vrs's Avatar
What about the radio code. I thought it was programmed into the ecu?
John
Old 04-05-2005, 16:28   #6
jimnpaula's Avatar
Fantastic!
Oh well - hope one of these is available when funds allow....
James
James & Paula
Old 04-05-2005, 16:29   #7
EddyH's Avatar
You just enter it the first time you turn it on after installing.
EddyH
EddyH is offline
Old 04-05-2005, 16:33   #8
faboka vrs's Avatar
Cheers
John
Old 04-05-2005, 16:45   #9
VT5
Members Car: Fabia vRS
Thanks in advanced
I want one!
Was: 2003 Allard Tuned Fabia vRS VT5 Turbo Conversion
Now: 2008 Audi A3 Sportback TDI
FabiaTDi is offline
Old 04-05-2005, 17:01   #10
faboka vrs's Avatar
Would look
John
Old 04-05-2005, 17:08   #11
Dodgy's Avatar
Members Car: 2007 Octavia vRS TDi
Looks smart, I wonder how much it will go for?
Dave.
Click here to make a clicking sound.
Dodgy is offline
Old 04-05-2005, 18:25   #12
EddyH's Avatar
Dave.
I paid £565 for one from that seller.
EddyH
EddyH is offline
Old 04-05-2005, 18:26   #13
Dodgy's Avatar
Not a bad price, I paid roughly the same for a IPAQ PDA with TomTom3 and bluetooth GPS about a year ago. I'd much rather have an integrated system though!
Dave.
Dodgy is offline
Old 04-05-2005, 19:34   #14
HAve you seen this one.......
http://cgi.ebay.co.uk/ws/eBayISAPI.d...sPageName=WDVW
Its actually a Skoda one, not VW - so should light up green etc, buy it now £400.00
You've been Skoda'taken!
delroy is offline
Old 04-05-2005, 19:59   #15
Dodgy's Avatar
That looks well tatty.
Dave.
Dodgy is offline
Old 05-05-2005, 07:44   #16
jimnpaula's Avatar
Are there any other connections to make other than GPS antenna and ISO plugs?
Looking at another seller's website http://www.satnavsystems.com there is mention of a CAN-BUS interface which gives speed pulse, ignition, illumination and reverse signal outputs, for £129
Just wondering if this is actually needed and if so where it connects to in the car.
James
James & Paula
Old 05-05-2005, 08:52   #17
EddyH's Avatar
You need a plug and play wiring loom but that comes in the kit from the seller of the first auction.
BTW satnavsystems and that first seller are the same person.
EddyH
EddyH is offline
Old 05-05-2005, 13:39   #18
Members Car: Octavia Vrs 2004
Anyone know if the skoda 6-disc changer will work with the 1st sat-nav system?
'04 Silver Octy vRS - Revo 4bar, Miltek SS, Mitek Downpipe, 100cel CAT, RS6 18" Alloys, Forge 007p, ABD lan pipe/green filter, Samco TIP, Autogauge Boost,Oil temp, Oil Pressure gauges, ESP, Xenons, RS3 upper & lower braces
Ic3man is offline
Old 05-05-2005, 13:49   #19
EddyH's Avatar
Yep.
EddyH
EddyH is offline
Old 05-05-2005, 15:22   #20
Members Car:
anyone tried to get a unit from a breakers yard? I cant ven find an Octy let along a decent spec'd one !
I'm after the little spring loaded handle from the central arm rest - mine has broken
Goochie is offline
Old 05-05-2005, 15:29   #21
Yep.
Hmmm....next thing on my shopping list then. I will also put my original and replacement headunits up for sale to fund one of these. N1
Ic3man is offline
Old 08-05-2005, 12:59   #22
hussein's Avatar
Members Car: 2003 Fabia TDI Comfort
Exclamation It does look good...
I bought a DX nav unit thing on Saturday. The owner wrote off his Supurb and thats where this came from. It has an internal antenna, and a wiring loom that is connected to the left and right ABS sensors and reversing switch in the main loom by the passengers left foot. It also came with another loom for a Telephone mute switch, and some other stuff (I see a cable labeled 'C-bus') that apparantly I don't have to connect anywhere. According to him, the 2004 map disc should still be inside.
I put it in without the looms and bits and pieces to check it out and make sure its ok... I got this far:
1. It looks great
2. It sounds better than the Symphony
3. Its a quality bit of kit, great and easy to use (for audio)
BUT... the map disc is not in there. Hmm. I put in some other disc and it doesn't take it. I lift the lid off and find the top part of the spindle obstructing the path of the disc - move it a little and it does swallow the disc. When it is in there it makes horrible slurping noises as it doesn't spin properly.
As much as I'd like to take it apart and try to fix it - I can't really risk it. I took it back to the guy who was selling it, showed him the issues it had and got my money back (he was alright about it). I think the accident shock killed the drive.
I'd love another one, but only at the right price. Tomtom Go is good as well, but again I'm in no rush. I can read maps! Its just that I like my gadgets really.
Ah well.
Hussein Jodiyawalla
mightymouse dot net
fabia tdi comfort, dark blue metallic. fabia mats, fancy bulbs, debadged, pd sound absorber, pd160 intake, stu's cruise control. nokia ck-7w bluetooth car kit, empeg mk2a 40gb mp3 player, jvc digifine 4x40w amp.
hussein is offline
Old 08-05-2005, 16:18   #23
RICHARD
Fabia 12v's Avatar
Please say you only have to take radio and tray out to put this in and all the wiring is already there cause iv just ordered one of these!
Is it ljust a matter of tasking wiring off symphony and plugging it in the back of this and just add the aerial??
First Car: Skoda Fabia MK1 1.2 12v Comfort
Replaced with: Volkswagen Golf MK4 GT 1.9TDI
Replaced with: Seat Ibiza MK4 Sport 1.9TDI
Replaced with: Volkswagen Polo MK6 Ltd. Edition Sport 1.4 16v
Fabia 12v is offline
Old 08-05-2005, 17:28   #24
hussein's Avatar
No, thats not the case.
You will need to remove the glovebox, the trim under the glovebox, the trim in front of the passenger door, run the loom for ABS and Reverse over from the HU to the left of the car and tap into the cables in the main loom there.
And also wire up the GPS antenna onto the dash...
This is what I have been told - I didn't get a chance to find out for myself! I don't know if a "plug and play" loom is going to help anything - none of the wiring for the sensors is there already, and you will need it.
Can someone who has installed this elaborate? I'd like to know for sure. Same with installing a changer - how hard is it to install all the wiring and mount the bracket under the seat?
Hussein Jodiyawalla
mightymouse dot net
hussein is offline
Old 08-05-2005, 17:47   #25
RICHARD
Fabia 12v's Avatar
When you say tap in do you just plug in? or is it case of cutting wires?
Similar Threads
Help Me Out With My Sat Nav Dilema!!! MightyMouse INTRODUCE YOURSELF! First time visitors, say hello here. 8 13-12-2005 19:37
Sat Nav or Not to Sat Nav? Choppa Fabia I 23 08-12-2005 02:33
OEM Sat nav or Audience HU in New Octavia to22 ICE, Security and Insurance 1 29-03-2005 17:25
Sat Nav installation tips helpmedisappear ICE, Security and Insurance 4 06-08-2004 15:45
Sat Nav... dab ICE, Security and Insurance 13 28-08-2003 16:47
