This is a discussion on Speaker Problems Still within the ICE, Security and Insurance forums, part of the General Motoring Discussions category; Hi i have had a look at changing the front speakers now ideally i want to keep the connector on ...
| BANNED Join Date: Oct 2004 Location: Bristol
| Speaker Problems Still Hi i have had a look at changing the front speakers now ideally i want to keep the connector on there but how do i wire a new set of speakers into this or is the olny way to cut the connector off but there are 4 wires and not sure how i would need to connect these up i want to keep the tweeters as i am just going to replace them with the new set i have. |
| You will need to cut the connector off if you want to use any descent aftermarket speakers. Then replace the big chunky connector with the correct sized connections crimped or soldered onto the oem wiring.
| | #3 | |
| Briskodian Join Date: May 2003 Location: North East
| Quote:
Just a tip but make sure you get speakers that fit in the door recess without any probs. Otherwise you'll have to remove the door panel etc which is a total pain in the ar5e. Hence why mine is still in bits at the moment ![]() | |
| | #4 | |
| Quote:
So do i connect 2 wires of the 4 when i chop the plug off into one crimp and 2 into the other and then connect that to the speaker or would you advis a different way | |
| Briskodian Join Date: Jul 2003 Location: Peak District
| Sounds good to me as long as the two wires you are crimping together are the same colour. |
| Briskodian Join Date: Jun 2003 Location: On the back of an AA truck with a failed turbo
| Kenwood custom fit speakers come with a little adaptor that plugs onto the factory wiring. Might be worth looking at these if you don't want to get busy with the scissors
__________________ Alex "I laugh in the face of danger, then I hide until it goes away" www.drzoidberg.co.uk |
| Briskodian Join Date: Jan 2004 Location: Sheffield
| If you don't want to keep the standard speakers you could try cutting the female bit of the connector out of the speaker basket then trim it and solder on some flying leads. I don't know whether this is possible with Skoda speakers, i've never had the standard ones out, but it worked well with my Saxo. |
| | #8 | |
| Quote:
If you go 2 way on the other hand, you only need to connect the 2 wires that come from the headunit.
__________________ Manny 2005 Octavia 2.0TDi Elegance combi my skoda website http://www.octaviars.co.uk Join the briskoda.net folding team click Here for more info | |
| Briskodian Join Date: Nov 2004
| is there an autoleads spacer available for the front 6.5" speakers or will i have to fabricate my own? i'm trying to fit my KEF midbass in but they are a little too deep. has anyone ever cut the metal behind the door card?
__________________ black octavia v-rs "black ice" |
| | #10 |
| Briskodian Join Date: Aug 2003 Location: Essex
| Why not just solder on a new set of connectors 1 inch down from the factory connector ??
__________________ Black '53' Octy vRS - 18inch RS4 in Graphite Grey - Colour coded front grill - Samco TIP - Carbonio filter - OBD Remap by Mike @ Impossible Performance Coming before the end of Jan 2007 - Audi A4 Cabriolet - Ebony Black- 18inch RS4 Wheels - Red Knappa leather |
| | #11 | |
| Briskodian Join Date: Sep 2004
| Quote:
i hacked a chunk of metal off from behind the speaker. no problems so far apart from the doors bending and then falling off during low bass moments! ...you can safely remove a small chunk of the metal behind the door with no consequences. There's a small bit of overhang that serves no purpose at all. | |
| | #12 |
| it looks like it supports the window runner? surley taking this out will result in problems with my electric windows? i might just make some kick builds and do the job right ![]()
| Fabia vRS front door speaker change - how to (with pics) | tfboy | ICE, Security and Insurance | 54 | 16-09-2008 22:48 |
| Help with speaker sytem | octaviablack | INTRODUCE YOURSELF! First time visitors, say hello here. | 8 | 25-10-2004 01:06 |
| Speaker help | octaviablack | ICE, Security and Insurance | 8 | 13-10-2004 16:03 |
| Fabia vRS front speaker sizes | tfboy | ICE, Security and Insurance | 5 | 17-04-2004 20:23 |
| Speaker improvements | 4x4 | Maintenance & Performance | 2 | 04-11-2002 14:43 |
