This is a discussion on Haynes Manual for Skoda Octavia within the INTRODUCE YOURSELF! First time visitors, say hello here. forums, part of the Announcements, News, Introductions and Rules category; Hi, I have just checked out the website for Haynes Manuals and it tells me they do not plan to ...
| Briskodian Join Date: Mar 2004
| Hi, I have just checked out the website for Haynes Manuals and it tells me they do not plan to do a manual for the Octavia! I have written to them to ask if they were referring perhaps to an earlier Octavia and await their reply. If I get the "wrong" answer, it might be worth a few more of us wrtting to Haynes! Now the warranty is out, I have just started to do my own servicing of my VRS and have got hold of the interface and software from Ross-Com in the states. This allows me to read fault codes and do a whole host of things similar to the VAG-1552 and then some. However, without the detailed manuals it is difficult to even change the rear pads! I have bought the engine and engine management elements of the official Skoda manual but just those bits have cost me in the region of £90. |
| Welcome to Briskoda, Toolkit. I can't recall any other member having managed to buy the official Skoda manual - or even parts of it - so you are way ahead of the rest of us. Have you got the prices for the various sections which make up the full manual? Perhaps a Haynes manual for an equivalent Golf would give good enough DIY info to get by on.
__________________ Denis 2002 Octavia 1.8T 4X4 turbo Estate - rebreathed on by Jabba ... 31.93mpg2007 Fabia vRS - CC, ESP and full leather trim by Seat Surgeons ...48.09 mpg... |
| BANNED Join Date: Mar 2003 Location: Anywhere but here
| Warning re rear pad changes.. Don't attempt it without the correct piston winding tool. Fronts are easier with this tool too ![]() As for Haynes attitude to the Octavia, i still don't understand this, as there's plenty of them on the road... |
| Briskodian Join Date: Sep 2003 Location: Leicester
| I too looked into this, this week (had a couple of issues with my Octy vRS). I also had a look at the other VAG car manuals which might substitute for an Octy/vRS (Golf, A3, leon, TT*, A4*), and out of all of them, the MKIV Golf was the only one available, only upto 2000 (the vRS was released a little later I believe) and there's no mention of the 1.8t (although the 1.8 20v turbo-less engine is mentioned). Haynes say the A3 (of which a 1.8t or S3 variant might help) is under 'consideration'. I hope haynes can pull there finger out soon, I'm certain there are THOUSANDS of taxi drivers, in England (and Spain), who'd love one of these manuals. Rich
__________________ A wise man always know when to listen [so be wise and let me speak!!]. Last edited by sixman9; 30-10-2004 at 17:08. |
| Ok, thanks for the info, I'll have a look at the Vdub manuals. Now then, don't be put off when the Skoda dealer tells you they can't supply the official manuals even if they are expensive. I met a stone wall the first time I tried so I contacted Skoda direct. They told me I could purchase them and to tell the dealer that!! I did and the dealer checked it out with the visiting Skoda field engineer. He wasn't sure so double checked and found out I was right. The original engine manual was part no: S0051000020 and included the engine info and engine management info for the 1.9l/81kW TDI and the 1.8l/110kW petrol engines. It cost me £53+VAT. The bulletins for the AUQ 1.8l/132kW RS engine and engine management are parts nos: S0051375020 and S0051365020 and are £12+VAT each. The funny thing is that there is a message at the bottom of the inside cover sheet to the lever arch file that says the manual is for use within the Skoda group and that it is not permitted to pass it to Third parties!! That must be why you meet the initial resistance from the dealers. Finally, I discovered that the "Laser Brake Calliper Piston Re-wind Tool" which is only supposed to fit Ford with ABS, Honda, Jaguar, Mazda, Mitsubishi, Nissan, Rover, Subaru, and Toyota also fits the VAG rear callipers on the Skoda perfectly! It cost £19.99 from Halfords. Last edited by Toolkit; 31-10-2004 at 15:24. |
| Briskodian Join Date: Mar 2003 Location: SE
| Are Haynes Mad? Look at the pool of Octavia SDi cab drivers out there who will be minimising running costs ! |
